Adjustable Topmounts
Old Jul 2, 2016 | 02:25 PM
carbon1993's Avatar
carbon1993
Default Adjustable Topmounts
Would Burton power adjustable top mounts fit on a sierra with stock springs and dampers? Or would it fit on race suspension only?
Old Jul 2, 2016 | 10:36 PM
Oldrustyfords's Avatar
Oldrustyfords
Think there be to fit on coilovers mate.......only ever seen them on coilovers......worth giving them a shout
Old Jul 3, 2016 | 10:36 AM
carbon1993's Avatar
carbon1993
I could give them a try there not that expensive. Would these from compbrake be Any good? Cant find alot of info about these. Only that it isnt a great company. Got adjustable tca's from compbrake which are decent.
Old Jul 4, 2016 | 12:10 AM
robrs2's Avatar
robrs2
fitted the top mounts to mine before changing to coilovers.
The top spring cap needs to be spaced out a little from the top mount to allow ti to move. i used flat washers that were welded together, but a spacer would be a better idea.
Old Jul 4, 2016 | 08:02 PM
rooos's Avatar
rooos
these ones looks fine for track use.
but i wouldn't ride 'em too fast on shitty roads...
that 2 bolts connection looks pretty weak for it.
i'm not talking by direct experience though...
but that's why i purchased a couple of eccentric ones, maybe i'm putting 'em on in a week or two.
(so again, robrs2, many thanks for the useful tip!)
it's told they lift up the front end by a inch or so... i'll tell you when i do it.
Old Jul 4, 2016 | 09:37 PM
carbon1993's Avatar
carbon1993
thanks for the info! Wouldn't have thought these would fit on stock suspension. Will be ordering eccentric ones soon!
Old Jul 5, 2016 | 07:51 AM
Marc sierra's Avatar
Marc sierra
Why do you want to change the top mounts? You will loose the rubber/poly bush at the strut top, which in my opinion will make the car very harsh on the road. I would only use them on a track car.
Old Jul 5, 2016 | 09:47 AM
rooos's Avatar
rooos
driving habits => tyres are talking.
actually i do need more negative camber, due to excessive wear on the outside tire tread, (with a fine toe in and at any tyre pressure, even when overinflated).
(i know, i drive like a d*ckhead)
i'd also like to see if, more caster makes steering wheel turning back quicker.
this would be while drifting, (or just trying to), my daily welded 1.8cvh saph...
[ opened a build thread about this one in here:
https://passionford.com/forum/restor...-thinking.html ]
... but you're right, the situation's going to be harsher on the road.
let's hope not so bad.
Old Jul 5, 2016 | 06:42 PM
carbon1993's Avatar
carbon1993
i replaced my TCA's form stock to adjustable ones. because the originals were broken.
I always wanted to have some more camber but the TCA's didnt adjust much. I believe the car's handling could be a bit better when i just have that little more camber.
It's lowered and the aligning of the TCA isn't ideal as i chose for 2WD hub instead of 3dr hubs. The TCA's made the car a whole lot better tho!
Old Jul 6, 2016 | 09:21 AM
_Jimmy_'s Avatar
_Jimmy_
They usually come with 4 bolts (I know as I have some for my car sitting on the shelf), bit daft how they took the picture with only 2 on though.
800bhp
Feb 23, 2017 10:44 AM
2wdsaph ben
11
May 15, 2016 11:15 AM
oilman
Trader Parts for Sale.
May 12, 2016 09:11 AM
3dr cossie
Apr 28, 2016 06:35 PM
M K
Apr 19, 2016 08:38 AM
