Disaster changing stem seals on CVH
Old Jun 13, 2012 | 12:16 PM
simon68's Avatar
simon68
Default Disaster changing stem seals on CVH
Had a disaster trying to change my oil seals on my mk4 escort
Using a compresser(forked shaped thing)I've snapped one of the 'bolts' that the rockers are bolted to.
Does anyone know if these 'bolts' can be extracted?
Any help much appreciated.
Old Jun 13, 2012 | 12:28 PM
martysmartie's Avatar
martysmartie
It all depends, anythings possible with the right tools etc.
Does it have anything protruding etc?
It's if it resorts to having to drill it out etc, you may run into problems.
Martin
Old Jun 13, 2012 | 12:34 PM
simon68's Avatar
simon68
Thanks for your reply Martin.Yeah there's about an inch or so still exposed.
I couldn't work out if they come out or not?
Is it worth trying some mole grips on it?
Old Jun 13, 2012 | 12:40 PM
martysmartie
Tbh I don't know for sure but surely if you have snapped a threaded bolt then it should unscrew normally? If so then you could try the grips just be gentle and see how it goes.
You have extractors etc as well for this kind of problem.
Martin
Old Jun 13, 2012 | 12:45 PM
simon68's Avatar
simon68
Thanks,will have a look at extractors.
Old Jun 13, 2012 | 12:49 PM
cossiestu's Avatar
cossiestu
I can't remember how much thread there is on them, but not wanting to state the obvious, but if there's enough thread, could try a 'double nut' on it?
Old Jun 13, 2012 | 02:26 PM
simon68's Avatar
simon68
Thanks for that Stu.No there's no thread left.Will try & get a photo later.
Old Jun 13, 2012 | 02:49 PM
E980VTJ's Avatar
E980VTJ
tap that inch of stud then use a 2 nut's
Old Jun 13, 2012 | 02:58 PM
the mk1 kid's Avatar
the mk1 kid
I managed to removed a head bolt from a friends car that he rounded off (the muppet!) via welding a nut over the top. It took two goes, as the bolt was very tight, and the weld gave way on the first attempt, but i managed to find a huge nut (size escapes me now) that fitted clean over the head of the damaged one, and that held firm
Do you have a welder?
Tom
Old Jun 13, 2012 | 03:09 PM
simon68's Avatar
simon68
No welder Tom
Old Jun 13, 2012 | 03:54 PM
cossiestu's Avatar
cossiestu
Arse. Not much meat left on that to do much with...
Old Jun 13, 2012 | 03:57 PM
simon68's Avatar
simon68
No Stu Just seen Burton sell the rocker studs for about a fiver each.
Think i'll have to risk it & get some mole grips on it.
Old Jun 13, 2012 | 05:42 PM
fraser9764's Avatar
fraser9764
Mole grips should get that out no problem or a small pair of stilsons.
Old Jun 13, 2012 | 05:45 PM
cossiestu's Avatar
cossiestu
Guess it shouldnt be mega tight...
Hope you can sort it easy!
Old Jun 13, 2012 | 05:54 PM
liam-rst's Avatar
liam-rst
shit happens
that should easy come out with a decent set of grips mate, also check the studs you have used the spring compressor on already as they have a habit of undoing when you remove the spring compressor
Old Jun 13, 2012 | 06:12 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
get the grips on there very very very tight
welder will bring it out best tho
or an exrtractor like this
but space is tight
i have one of these and its taken out dozens of snapped and rotten cvh headbolts
http://www.ebay.co.uk/itm/Sealey-Stu...item5adb4f11b7
Old Jun 13, 2012 | 06:42 PM
simon68's Avatar
simon68
Default thanks
Thanks to everyone for help & advice.Got it loose with my pair of cheapo mole grips Than my neighbour leant me some snap on ones & managed to get it out
Such a relief.Will order replacement from Burton tomorrow.
Cheers again to you all.
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Russp
Escort Range
Sep 18, 2015 07:39 PM
marky_g
Sep 12, 2015 04:26 PM
