engine revving
Old Apr 11, 2012 | 06:15 PM
rammer's Avatar
rammer
Default engine revving
Hi All
I have a slight problem with my MK2 mondeo,
every now and again when changing gear the engine revs its nuts off and then the revs drop down again, someone has said its a seal thats gone, so 1 if so which one ,
2 is it easy to repair
and 3 do we know the average cost and where the best place to get them
Many thanks
rammer
Old Apr 11, 2012 | 06:41 PM
martysmartie's Avatar
martysmartie
VSS sensor I should think, yes fairly and Ford's or motor factor, the bay etc.
Martin
Old Apr 11, 2012 | 06:55 PM
rammer's Avatar
rammer
Thank you martin will have alook
are they easy to replace, also what is the VSS and where is it please
george
Old Apr 11, 2012 | 06:58 PM
martysmartie
VSS (Vehicle Speed Sensor) it's fitted to the box, not not particually difficult to replace.
Martin
Old Apr 11, 2012 | 07:07 PM
botters's Avatar
botters
competant bodger
this happens on focus and fiesta as well but is caused usually by the clutch switch on those
Old Apr 11, 2012 | 07:13 PM
rammer's Avatar
rammer
Thank you Martin and Botters
Will have a look tomorrow and try and get this sorted, always seems to rev up in the middle traffic and clouds of black smoke for and instant, a bit embarrassing but would like to sort it ,
Thanks again
George
Old Apr 11, 2012 | 07:20 PM
GVK.'s Avatar
GVK.
Is it a diesel, and when you say it revs up, does it rev flat out, black smoke and knocking from engine?
If so -There is a capsule on the diesel pump with a long thin pipe that's connected to the turbo, inside the capsule there is a diagphragm, if it splits it can suck diesel through the pipe straight into the turbo
Old Apr 12, 2012 | 06:20 AM
rammer's Avatar
rammer
Morning GVK
Yes it is a diesel 1997 MK2 I have checked this pipe and there is no splits but it fills up with diesel, What is the technical name for this diaphram , where will I get one from and is it easy to change, Thaks in advance
George
Old Apr 12, 2012 | 12:32 PM
martysmartie
Now we know it's a Diesel, ignore what I have said.
Martin
Old Apr 12, 2012 | 01:41 PM
rammer's Avatar
rammer
Thanks Martin
I have senior moments here in France. OK so where do we find this Diaphram any pics. and how do I rectify the problem,
I am sure there was an issue on this forum 18 months ago or more but I cannot find it,
Any suggestions please
George
Old Apr 12, 2012 | 05:02 PM
GVK.'s Avatar
GVK.
It's called a 'boost capsule' - from memory, it's not available from Ford, but seem to remember having one done by a local diesel specialist. CF Parkinson in Boston, Lincs.
http://www.parkinsons.co.uk/Boston.aspx
Disconnect/block the pipe as a temporary measure.
Old Apr 12, 2012 | 05:15 PM
rammer's Avatar
rammer
Thank you Gary there must be a Guru on here somewhere that would know how to change this diaphram, hopefully someone will reply.
I will give them a ring tomorrow fingers crossed
George
Old Apr 13, 2012 | 11:24 AM
rammer's Avatar
rammer
Has anyone ever changed a boost diaphrm before and whats the best way to tackle it,
On a Mondeo diesel MK 2 1997
Thanks in advance
Rammer
kosienutter
31
Aug 22, 2015 09:55 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
Adam-M
22
Aug 10, 2015 10:46 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
