Focus T230 emission failure
Old Feb 25, 2012 | 10:37 AM
mustang001's Avatar
mustang001
Default Focus T230 emission failure
hi, ive a 2002 Focus T230, recently failed the mot emission test due to CO being way above limit, this indicating it is running very rich, anyone have any idea the cause of this ?
also there is no catalytic converter in the exhaust system, this im certain is not the reason for high CO but just wondering are all the montune developed T230's without them ?
many thanks in advance for any help !!
Old Feb 25, 2012 | 10:39 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
what readings, and it defo wont pass the test without a cat unless its a friendly MOT due to no cat then it shouldnt fail...... lol
post the data and let us have a spy dude
Old Feb 25, 2012 | 10:50 AM
mustang001's Avatar
mustang001
ah well can work around cat prob if can get readings fairly near
low idle CO - 5.79% above 0.50% is a fail
high idle CO - 3.04% above 0.30% is a fail
Lambda 0.92 not between 0.95 and 1.09 is fail
HC - 178ppm above 200ppm is fail
as you can see CO is way to high, Lambda only slightly out, HC are ok
any ideas of likely prob ?
Old Feb 25, 2012 | 12:02 PM
oldford's Avatar
oldford
What signal is coming from the front Oxygen sensor?
Any fault codes present?
Do you have the CO2 and O2 numbers from the exhaust gas test?
Old Feb 25, 2012 | 12:22 PM
GVK.'s Avatar
GVK.
These cars have non-Ford ECU as far as I'm aware, Pectel.
So diagnostics are not as easy....
Old Feb 27, 2012 | 04:48 PM
mustang001's Avatar
mustang001
going to check oxygen sensor when i get a chance in the next couple of days
yes it has pectel ecu along with the ford ecu, the pectel controls the engine management while the ford ecu controls all the rest of car
Old Feb 27, 2012 | 05:13 PM
oldford's Avatar
oldford
Even Pectel ecu's can be read. For codes and data.
You may need a tuner to do that for you.
Old Feb 28, 2012 | 06:51 PM
kneller's Avatar
kneller
Ford Nut
I'm sure the fact that you're running no cat is the reason for the high readings, they're the sort of readings I get one mine with a decat.
Mine were well within limits when I had the sports cat on, so I'd say that's probably your issue.
Old Mar 9, 2012 | 11:25 PM
t230's Avatar
t230
Default t230
Hello , i also have a T230.
Been advised that they are supposed to run rich so pistons dont melt (unless you have forged bottom end then i wouldnt know).
I believe they have been mapped to run a cat if you wish untill then you have to find a 'friendly' MOT tester.
more advice and t230 friendlyness
https://www.facebook.com/pages/GMD-F...88363341184171
and also
https://www.facebook.com/pages/Ford-...25413097473708
good luck!
any pics?
Old Mar 9, 2012 | 11:42 PM
langer's Avatar
langer
Iam sure it's an mot failure now if your cars been decatted too even if it passes it's emissions.
Old Mar 29, 2012 | 06:20 PM
shikari chaos's Avatar
shikari chaos
I've got a T230 and like you say they came de-cat. Ive just purchased a sports cat so I can swing that in for the mot. I've found friendly test centres are far and few between. It'll be interesting to see how much effect the sports cat has. If its fine then I'll keep it in but being a turbo it might suffer...
Old Mar 29, 2012 | 08:57 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Mines running decat (T190) so has to be "friendly" tester. Sure they should have one though as I asked Justin (had a mad T190 running 300+bhp) and he said they were mapped without hence no eml but need one for MOT. Couldn't see Mountune releasing a car that needs a cat without one tbh. Get some pics up of it though
Old Apr 1, 2012 | 08:57 PM
mustang001's Avatar
mustang001
hi guys, quick update, fitted a cat but had little effect on improving the emissions, brought it to local garage and he says prob is due to fueling, he gona re-install a standard 2.0 fuel rail and injectors to see will this help to get past test, will keep yee posted !
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
