Zetec turbo conversion help
Old Apr 1, 2012 | 10:11 PM
HirenRS's Avatar
HirenRS
turbovh
Default Zetec turbo conversion help
Nearly finished my zetec turbo conversion in my fiesta rs turbo trying to figure out where to connect temperature sensor and also the trick behind alternator do I need a new one or can I use rs turbo one which is near on new with a Etec pulley Also how would I connect the temp plug so t dash works the rs one is a single wire the zetec seems to have two and there is a extra water plug leading from the thermostat housing where do I route this to or can it be blocked off
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
