Cosworth engine making strange noise
Old Dec 24, 2011 | 08:29 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Default Cosworth engine making strange noise
My YB is making this strange noise, it's been doing it for last 5-6 months probably (I got the car in june this year), I don't remember when exactly it started making it since it got gradually little louder, but the noise level has been same for 5 months i'd say. I haven't driven it much after summer but it worked and still works perfectly though the noise remains. It doesn't drink oil or any other liquid, and coolant is also bright and clear. I have receipt from previous owner that cambelt, water pump, tensioner and engine oil (Castrol 10W-60) have been changed in march 2011, and the cambelt's teeth look very fresh indeed. I changed new oil (Castrol 0W-40) after 6000 km of driving, few weeks ago. This didn't have any effect considering the noise whatsoever.
Strange thing is, that it only makes the noise when its warm. When I start the engine and outside temperature is 0 celsius, it takes minute or two until the engine starts to make the noise, it gets slowly louder as the engine warms. I can't exactly tell where the noise is coming but seems like its coming from the head. Camshaft bearing, valvetrain?
Here's a video if anyone could help..
http://www.youtube.com/watch?v=K3RmywTRGc4
Old Dec 24, 2011 | 12:20 PM
Alvyn's Avatar
Alvyn
imo sounds to me that it may not be timed up correctly??? also see how tight the timing belt? try taking off the cam belt cover and see if that's the rubbing sort of noise!
Old Dec 24, 2011 | 12:32 PM
Turbosimpsons's Avatar
Turbosimpsons
As said check tension of the belt.
Old Dec 24, 2011 | 09:12 PM
RobertM's Avatar
RobertM
Timingbelt too tight!!
Old Dec 26, 2011 | 03:53 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
I checked the timing belt today, it doesn't rub anything and I tried to stretch it with finger to see the tightness, and it seemed to be quite tight. Im no expert I don't know how tight it should be though, I should prolly post new vid or let mechanics to check the tightness. Also timing marks were OK when I last time checked them. I also double checked the source of the noise and it seems to be coming from the head, near camgear.
e: Ye, it might be too tight, heres a video with same kind of noise as I do..
http://www.youtube.com/watch?v=vLNYqaslvPY
Old Dec 27, 2011 | 04:27 PM
wes's Avatar
wes
As a ROUGH guide, when the engine is COLD you should be able to twist the cambelt 90 degrees on the long section between the inlet cam sprocket and the auxilary shaft. Once the engine warms up the slack in tghe belt will go. If it is quiet when cold then makes the noise when warm then the belt is too tight when cold.
Old Dec 31, 2011 | 02:11 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
I tried to twist the cambelt but it didn't bend 90 degrees, not even close I think.
Old Dec 31, 2011 | 04:43 PM
Turbosimpsons
It's too tight and its going to snap soon.
Old Jan 1, 2012 | 02:08 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Im gonna get mechanic to check it soon.. Should get the timing belt loosened and it should make the noise to disappear.
Old Jan 1, 2012 | 04:42 AM
botters's Avatar
botters
competant bodger
i would also say you have a noisy cam bearing as well as an overtightened belt by the noises its making
Old Jan 1, 2012 | 08:06 AM
Stu @ M Developments's Avatar
PassionFords Creator
Problem = The camshaft drive belt is too tight.
Solution = Change the belt, the tensioner and the two camshaft front bearings.
Old Jan 2, 2012 | 09:12 PM
forevaford's Avatar
forevaford
just slacken the belt, job done
Old Jan 3, 2012 | 10:17 AM
And drive along praying that the bearings you have damaged by applying too much lateral force to them dont eventually fail and destroy all 16 valves and 4 pistons... at best. You could be on a winner and save a few quid.
Old Jan 3, 2012 | 10:21 AM
mattman1234's Avatar
mattman1234
agreed with stu,
Old Mar 24, 2012 | 10:34 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
OK, took some time to get situation updates because im currently serving in the (Finnish) army right now and I don't have much free time. Nevertheless Stu and other were right, the belt was too tight. It got loosened and the noise decreased drastically. I did little test drive after and came back just to hear the noise was back.. I opened the bonnet and tested the cambelt, and it seems to be too tight again. So somehow the belt tightens itself. But after all the culprit and solution is found and as I have time I will order new cambelt kit and camshaft bearings just to be safe as Stu said.
By the way should the camshaft bearing change be easy job or is there anything important I need to take into account?
Old Mar 24, 2012 | 10:50 AM
KSA-Cossie's Avatar
KSA-Cossie
Just so happens MSD are having a spring sale just now too mate !
Old Mar 25, 2012 | 07:15 AM
The belt tension needs setting with a hot engine as the engine gets taller when it gets hot.
Old Mar 25, 2012 | 09:26 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Thanks for the advice Stu!
Old Mar 25, 2012 | 11:04 AM
martysmartie's Avatar
martysmartie
Ok, By the way should the camshaft bearing change be easy job or is there anything important I need to take into account?
You have to TDC the engine, remove the cam cover and the camshafts, doing so requires removal of the cambelt and so you will have to correctly time the engine afterwards, which unless you are 100% compentent doing, then don't even attempt it as you will ruin your engine.
Also things like cam caps have to be tightened to a specific torque which requires a torque wrench.
I believe you may need a "bearing removal tool" as well?
Also you will need new gaskets, i.e. cam cover, "Half moon seals" etc.
Martin
Old Mar 25, 2012 | 08:53 PM
daz1968's Avatar
daz1968
Just as another side issue, I would drop the 0w40 oil and put in something thicker, not that it's causing this issue but long term the oil is to thin for an old engine like the yb
Old Mar 26, 2012 | 12:13 PM
martysmartie
+1 absolutely agree, I wouldn't even use 5W/30!
Martin
Old Mar 27, 2012 | 05:14 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Martin
Me too!!
Old Apr 18, 2013 | 08:06 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Camshaft ball bearings have now been changed, as well as tensioner and timing belt. The engine is now a lot quieter. Here's a video of the engine running:
http://www.youtube.com/watch?v=gQzpT...ature=youtu.be
Sounds pretty healthy now?
big_Rad
Sep 15, 2017 09:36 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
Bezzy41
Aug 3, 2015 10:31 AM
