starting issue
Old Jul 11, 2011 | 06:45 PM
steve_o's Avatar
steve_o
Default starting issue
hey guys, help needed getting my s2 rs turbo going, i have replaced the fuel pump relay as it was melted, now the fuel pump runs as it should, the car cranks over but just wont fire, the only way it fires up is if u just hold open the flap on the metering unit slightly and it will start, rev up nicely and all that, soon as u let it shut, the car cuts out and wont start, i have replaced the metering unit with another one but still no joy, exactly the same, just dont understand it, any help would be massively appreciated. cheers
Old Jul 11, 2011 | 07:15 PM
steve_o's Avatar
steve_o
anybody help?
Old Jul 11, 2011 | 07:33 PM
escoskmv's Avatar
escoskmv
hi mate, remember havin same problem on my old rs. make sure there are no air leaks in the system and its all piped up as it should be. then you can try an adjust the screw by the flap. screw it in to push the flap down then try it mate
tony
Old Jul 11, 2011 | 07:38 PM
steve_o's Avatar
steve_o
hi mate, i have checked over everywhere on the car, seems to be no air leaks anywhere that i can see, i will try and adjust that screw see if it makes any difference, is there anything else common to go wrong that could cause this?
Old Jul 11, 2011 | 08:08 PM
escoskmv's Avatar
escoskmv
have you had the car in bits for rebuild and now wont start or has it been stood for a while? if you keep your finger on the plate does it tick over ok an rev up fine? could just need alittle settin up to get it right mate
Old Jul 11, 2011 | 08:19 PM
steve_o's Avatar
steve_o
when i bought it the car was in bits, head off of it, turbo was fucked, it was sat for about 18 months, i bought it, totally rebuilt the engine, new pistons bearings the lot, i put a fresh tank of fuel in it cos i didnt wana start it on old fuel, if u keep the flap pressed down a tiny bit then yeh it will run ok and rev up fine, as soon as it shuts it doesnt wana know, just cranks over forever and wont fire.
Old Jul 13, 2011 | 09:14 PM
escoskmv's Avatar
escoskmv
any joy with it yet mate?
Old Jul 13, 2011 | 10:21 PM
steve_o's Avatar
steve_o
not yet, i've left it alone for the minute, just havent had time to play with it, hopefully have a look friday, i'm hoping just adjusting the metering head screw is gona sort it, its gotta be something simple, once it runs its fine, it revs up sweet, just doesnt wanna idle or start without that metering head flap open slightly.
Old Jul 14, 2011 | 09:01 PM
escoskmv's Avatar
escoskmv
it will just need setting up i think mate, when you addjust the screw on the meaterin head addjust the tic over aswell if it needs it. screw with a spring on it on the throtal body. i no, my spellin is shite but you no wot i meen lol. let us no how you get on bud
Old Jul 14, 2011 | 09:12 PM
steve_o's Avatar
steve_o
yeh i know what u mean mate, which way do i need to turn that screw on the throttle body to raise the idle speed? i guess i turn it clockwise to raise it?
i'm gona have a play with it tomorrow afternoon, half day at work so plenty of daylight left to play, hopefully i'll get it sorted, defo keep u posted mate.
Old Jul 14, 2011 | 09:18 PM
H.RST's Avatar
H.RST
is the cold start injector plug on ok? have you checked cap and rotor, can also cause that sort of thing?
Old Jul 14, 2011 | 09:22 PM
steve_o's Avatar
steve_o
yeh its got a brand new dizzy on it with rotor arm, if i turn it to tdc, the rotor arm is sat at number one, so i know thats all ok, its got a good spark, i have checked the cold start valve, plugged in ok, but even if i disconnect it, it doesnt make a difference, hopefully its just a case of setting up the metering head.
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
