problem with tracking
Old Jul 13, 2010 | 10:56 PM
dcsinclair's Avatar
dcsinclair
Default problem with tracking
hi im new to this site and just wondered if anyone knows about the problem i have with my 1998 1.8 escort gti,i recently went to get tracking done but couldnt do it because they say something has been knocked or bent under car,had a look myself and couldnt see anything wrong eg suspension arm wishbone ect but d/side tyre is balled on inside,help!
Old Jul 13, 2010 | 11:02 PM
phil_focus's Avatar
phil_focus
they prob mean your track rod is bent and it will need a new one. best check with them exacly what is bent and needs replacing and get it sorted. tyres has worn like that because tracking is way out!
Old Jul 13, 2010 | 11:10 PM
dcsinclair's Avatar
dcsinclair
also car is chugging when i put my foot down in 2nd and 3rd gear could this be due to the new induction kit just fittef (k&n)just fully serviced car but boticed slight hole in manifold and i think this is probably the cause of it,fuckin car!
Old Jul 13, 2010 | 11:15 PM
dcsinclair's Avatar
dcsinclair
cheers mate will do that tomorow just hope its not gonna work out to exspensive lol cheers
Old Jul 14, 2010 | 09:32 AM
As said should be able to see what is bent, use a straight edege if necessary, but bottom arms and track rods are the favourite, the track rods can simply be replaced by screwing into the rack end, very easy job, note we are talking about the track rod between the rack and the end joint.
It is also perfectly possible to straighten these, but should only be done with heat, ie glowing red, but if in doubt I would guess they would be about Ł20 or so new from fords.
Old Jul 14, 2010 | 07:10 PM
dcsinclair's Avatar
dcsinclair
yep can also get from ebay for arounda tener,cheers mate
ossie cossie
57
Nov 21, 2022 10:05 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
BRAM
Sep 8, 2015 07:11 AM
routemaster
Sep 7, 2015 05:27 PM
