Oil temp sensor
Old May 2, 2010 | 05:44 PM
Marcyg's Avatar
Marcyg
Default Oil temp sensor
I'm putting a few gauges into my DOHC saph, and one is an oil temp sensor. Where can I fit the sender? Can I just T off the pressure switch or will that inhibit it's operation? I don't have an oil pressure gauge, so I don't have a filter sandwich plate. Cheers
Old May 2, 2010 | 05:54 PM
actualsilver's Avatar
actualsilver
RS TURBO NOVICE
I used the sandwich plate way between the oil filter. I run both Oil Temp and Pressure from that sandwich plate and it seems to work ok.
Old May 3, 2010 | 01:05 AM
boost mad's Avatar
boost mad
Or you can get sensors that fit in place of your sumpnut
Old May 3, 2010 | 09:08 AM
saph_Al's Avatar
saph_Al
You shouldnt have a problem using a t peice off your pressure switch , u can get them off ebay iirc
Cheers Ally
Old May 3, 2010 | 04:25 PM
Marcyg's Avatar
Marcyg
Cheers fellas, will go with the sump bung idea (it's leaking anyway) Will get a truer idea of oil temp as it's away from the really hot part of the block
Old May 3, 2010 | 06:27 PM
Reading will be less true, as it isn't absorbing heat from engine in the sump and being cooled by ambient air flow, personally I would use a adaptor in the oil pressure hole, can retain the std pressure switch also that way.
If you want to use a temp sensor in the drain plug, drill a 11/32 hole, then simply tap 1/8 NPT-27, the drill and tap will most likely cost less than a ebay one already done.
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Ben26
Sep 3, 2015 07:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
