cosworth internals into pinto block??????
Old Jan 22, 2010 | 01:59 PM
rosie's Avatar
rosie
Default cosworth internals into pinto block??????
my question is?
i have a 205 cosworth engine with a cracked cylinder block on std bore
i can get hold of a 205 pinto block on std bore
so can i fit all cosworth internals into the pinto block????????
cheers
Old Jan 22, 2010 | 02:01 PM
lead_foot's Avatar
lead_foot
is awesome
I believe so yes.
Old Jan 22, 2010 | 02:07 PM
The Youth.'s Avatar
The Youth.
My pinto has cosworth crank, rods, pistons and flywheel fitted with a pinto head
steve
Old Jan 22, 2010 | 03:15 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
I thought the pinto block had less main caps?
Old Jan 22, 2010 | 05:18 PM
rosie's Avatar
rosie
yes itve been told u can swap all bits ova but wanted 2 make sure 1st.
ive checked & a std pinto bore is the same size as a std cosworth bore so should be a simple swap ova
agreeed???
Old Jan 22, 2010 | 05:22 PM
Alvyn's Avatar
Alvyn
all fits!
Old Jan 22, 2010 | 05:24 PM
martysmartie's Avatar
martysmartie
Yes you can the Cosworth block (205) is a Pinto block these were just simply selected for there bore tolerances (Stamped by the dizzy you will see four numbers your Cosworth one will consist of 2's and 3's and also have a YB number stamped on the front of the block.
Martin
Old Jan 22, 2010 | 06:18 PM
Toe Knee's Avatar
Toe Knee
As said will all fit, there is this debate that their not good enuff etc but many people have used normal pinto blocks with no problem!! If your worried about using it you can run liners but thats personal prefrence.
Old Jan 22, 2010 | 06:28 PM
rosie's Avatar
rosie
cheers 4 the info, busy day 2morra then lol
Old Jan 22, 2010 | 06:33 PM
T3ORA's Avatar
T3ORA
i would so yes
my mate has one in hes sierra cosworth runnig a gt30
Old Jan 23, 2010 | 10:13 AM
pacificzetecturbo's Avatar
pacificzetecturbo
I too need to know whether its possible, the numbers by the dizzy on mine say 2323 or it might actually be 3232 but one of those, does this mean it could have been a selected block but not used? Thanks
Old Jan 23, 2010 | 10:34 AM
martysmartie
They are exacly the same, selected as I said for the bore tolerance, external difference being YB followed by a number stamped on front of block, remember this is only as good as the block being on standard bore, once the block is rebored those dizzy figures become totally irelavant.
Martin
Old Jan 23, 2010 | 09:10 PM
rosie's Avatar
rosie
to answer anyones querys yes it all fits straight in & works fine, i swapped all my internals ova 2day & got it all finished about an hour ago & it drove home perfect & sounds sweet
everything is direct fit
Old Jan 23, 2010 | 09:27 PM
saph_Al's Avatar
saph_Al
Glad to here it all went well for u buddy
Old Jan 23, 2010 | 09:36 PM
rosie's Avatar
rosie
cheers mate, when i picked up tyhe pinto 205 bottom end it also has the 2222 above dizzy same as cosworth engine
u can fit the cosworth internals into any pinto block but they say the 205 is the stronger block but the 202 is also ment 2 be a strong block
Old Jan 23, 2010 | 09:44 PM
saph_Al's Avatar
saph_Al
yeah i heard bout theres 202 blocks and that there stronger than 205's . as i think martin said they were chosen because or there tolorences not because they were machined or infact cast any different. Not a suject i know a lot about . strange that they didnt just machine one block with the same tolorences for the whole yb,pinto range . surley i would have been cheeper
Old Jan 24, 2010 | 11:29 AM
Kverna's Avatar
Kverna
Virgin-popper
How many of you have cracked a block due to boost ?
Guys run cosworth rods and pistons with pinto crank with an excess of 400bhp all day long over here. Was out on the ice yesterday with one, ran 1.5bars and up to 2.0bars all day, used 150L E85 and a few rally studded tires
No prob fitting the internals, but will have low compression, around 7 iirc.
EDIT: That's 400bhp on pinto head with cossy rods and pistons
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
