two head gaskets?????
Old Feb 27, 2009 | 06:56 PM
Phil2002's Avatar
Phil2002
Default two head gaskets?????
Hi people i'm at the final stages of my zt build i'm using a 2mm decomp plate on standard pistons on an 1.8 brand new zetec block.
the question i have is it better to run 2 head gaskets or use a none setting high temp sealant on the block to decomp plate surfaces.
i'm not aiming for any higher than 220bhp.
what are peoples opinion on this any horror/success stories???
thanks in advance for any input.
cheers,
Phil
brief spec:
brand new 1800 zetec block
1800 head re-skimmed and valves re lapped
2mm decomp plate
2.0l cams
2.0l throttle body
rs 1800 inlet manifold
FRST charge carrier
ERST exhaust manifold(on adaptor plate)
brand new T34 turbo
collins -31 actuator
200sx injectors (320cc)
megasquirt 2 v3.0
large front mount intercooler
Old Feb 27, 2009 | 07:00 PM
RS 5tu's Avatar
RS 5tu
use 2 head gaskets.
Old Feb 28, 2009 | 10:46 AM
cosrep's Avatar
cosrep
Yeah you'l need two heads gaskets, the de-comp plate thickness also requires the depth of two head gaskets to reduce the compression to the correct ratio
Old Feb 28, 2009 | 10:50 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yes you want two MLS gaskets to seal as best as possible...
With regards to the rest of your spec.. seems a bit of a mis-match.. have you uprated your valve springs? If not you wont be going anywhere really..
The Nissan injectors don't fit in the zetec rail properly.. that is if you understand how o-rings are supposed to work..
You don't really need the 2L TB or cams.. 1.8 stuff is fine..
Old Feb 28, 2009 | 05:14 PM
Phil2002's Avatar
Phil2002
i changed the bottom o rings of the injectors in order for them seat properly in the zetec rail the tops were fine. i have not changed the valve springs as i aint gonna be running major boost if they cause a problem then i'll change them. i only used the 2.0l tb and cams as they came in a doner engine that i bought off flea bay for sump, pick up pipe and ally stat housing etc etc.
if valve springs are that importatant who makes a decent set and what sort of cash are they???
thanks for advice
cheers,
Phil
Old Feb 28, 2009 | 05:34 PM
creator's Avatar
creator
ian howell/ area six for your valve springs mate belive you would be looking at £120
http://www.area-six.co.uk/
danny
Old Feb 28, 2009 | 05:50 PM
crazycage's Avatar
crazycage
danny
the standard caps wont fit on the springs tho! so your looking at the springs and caps and there about £250
Old Feb 28, 2009 | 06:47 PM
Milkybar Kid's Avatar
Milkybar Kid
your better off asking the person you got the decomp plate off as i only used 1 on top of the decomp plate and it lasted 2 years before the bottom end went .
Old Feb 28, 2009 | 07:26 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Phil2002- you can't get o-rings the right size, trust me I spent a loooooooong time looking. Well, not an ISO standard size, anyway. If the o-ring is tight in the groove on the injector, or isn't flush against the shaft, then it's not the right fitment.
You will need the valve springs above about 170bhp.. I know a guy who supplies some - pm me if interested.
Old Mar 1, 2009 | 10:31 AM
Phil2002's Avatar
Phil2002
i had to have the orings ordered they cost me 80p each got them from a hydraulics specialist he measured the injectors and compared orings and recommened them in his proffesional opinion so we'll see how they will get on.
thanks for the advise.
cheers,
Phil
Old Mar 1, 2009 | 10:34 AM
Phil2002's Avatar
Phil2002
what about focus rs valve springs can you not use them?????
Old Mar 1, 2009 | 10:40 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
i bought a 2mm decompression plate from ferriday engineering.and a felpro headgasket for my old black s2.it worked but when car went in to be set up at jamsport,jamie advised me to throw it away.reason i got it was because head had been skimmed way too much.it was sat on the block with some sealant and the head gasket laid on the top.in the end we put a different head on it and threw compression plate away.
think it would be better to buy low comp pistons or maybe have slight skim off the pistons if your on a budget mate.
the plate cost 160quid with the gasket,id rather have spent that towards new pistons tho really.
Old Mar 1, 2009 | 04:27 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
cheers,
Phil
It'd be interesting to know which ones they are then?
Old Mar 1, 2009 | 04:54 PM
Phil2002's Avatar
Phil2002
i'm sure i've got a few left in my tool box at work some where as i ordered 6 if i find them i'll post you one up.
cheers,
Phil
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
