External wastegate locaiton and mounting place
I want to ask where to mount external wastegate? Will it be ok to mount on 2 cylinders on 2wd manifold (on one side of the header)? As you know 2wd manifold is of 2 parts and them are divided. One side flows from 1 and 4 cylinder, another side is 2 and 3 cylinder. will it be ok to waste only form one side? in other words from 2 cylinders only?
What are the disadvantages of such setup?
Thanks
Thanks
why o why do i do it!!!!!
i hav seen a cast item that has the mounting for a external wastegate it wast in ff or pf will hav a look 2nite i think it may of been collins ?
i found reyland one, the wastegate is attached in the middle of divided manifold sections, so it wastes from all 4 cylinders. The main questions is: can I waste the exhaust gases only thgru one side of the manifold? Simple to say from 2 cylinders only: from 1,4 or 2,3 cylinders?
http://reyland.co.uk/images/mainfold...l_wategate.jpg
it would be easier to mount in one side, more free space for wastegate, etc.. but i want to get information from specialist, what are pros and cons of such mounting. thanks
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
Andypandy260
23-09-2015 10:28 PM
