is this a forged piston ro a standard zetec one??
Old Nov 22, 2008 | 06:16 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
Default is this a forged piston ro a standard zetec one??
can anyone tell me if this piston is a forged one or a standard zetec piston? the bore size is 86mm, i can't see any numbers but hopefully the valve cut out may give it away??
any help would be great
Old Nov 22, 2008 | 06:25 PM
muz's Avatar
muz
Wye Valley Hardcore
whip the sump off and see.
Old Nov 22, 2008 | 06:27 PM
Raj_FRST's Avatar
Raj_FRST
and do what mate?
Old Nov 22, 2008 | 06:36 PM
RS 5tu's Avatar
RS 5tu
std zetec ones dont have a cut out for the valve clearance.
Old Nov 22, 2008 | 06:38 PM
Raj_FRST's Avatar
Raj_FRST
thats exactly what I thought, how can I find out what they are??
thanks for the replies
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Looks like a Vauxhall C20XE piston. Unlikely to be forged, most likely LPC - however this is fine!
There are no OE 86mm Zetec pistons, so that answers that question!
As seen here:
Old Nov 22, 2008 | 06:40 PM
gtit's Avatar
gtit
if its a silver top, can tell u they aint standard 1.6 or 1.8 ones, not sure bowt 2.0, can see they got a ring round them looking like compresion has been lowerd, but have pockets for the valves 2, wat u running,
Old Nov 22, 2008 | 06:41 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
clarkesss004.jpg?t=1221331241
thease are c20let pistons i fitted to my zetec?
Old Nov 22, 2008 | 06:46 PM
clarke5700's Avatar
clarke5700
saying that they do look more like xe pistons ie no dish
Old Nov 22, 2008 | 06:47 PM
woolford's Avatar
woolford
its def not a 2.0l piston. (blacktop) does look like c20let .measure the bore
Old Nov 22, 2008 | 06:50 PM
clarke5700's Avatar
clarke5700
but look at the dish in my lets compaired to the dish in the xe pistons?
Old Nov 22, 2008 | 07:14 PM
muz's Avatar
muz
Wye Valley Hardcore
Originally Posted by Raj_FRST
and do what mate?
It will have a name or code on the backs of the pistons like this,
Mine being Accrilite as you can see.
Vaux piston, IIRC are Mahle so take a look note down the code and check it.
Old Nov 22, 2008 | 09:07 PM
Raj_FRST's Avatar
Raj_FRST
my pistons look identical to sa pjo's, are these any good? im only asking as im rebuilding the car, ive been sourcing parts for the following engine:
refurbished 2.0 (not 2.1) zetec block,
balanced crank and pulley
wiseco forged low compression pistons
farndon h section rods
im building this new engine with the intention of mating it with either a gt turbo or a stage 3 hybrid t3 with the boost set to between 15 - 20psi depending on how the fueling is
Old Nov 22, 2008 | 09:08 PM
Raj_FRST's Avatar
Raj_FRST
i did measure the broes and it is 86mm
Raj_FRST's Avatar
Raj_FRST
one thing i did notice is that there was no decompression plate
Old Nov 22, 2008 | 09:14 PM
woolford's Avatar
woolford
sorry i did mean c20xe.. they are good but depends how high power you want.. not sure the limit
Old Nov 22, 2008 | 09:16 PM
Raj_FRST's Avatar
Raj_FRST
well im after a reliable 200+, 230 would be nice but im more interested with the torque and how it drives, I want it to pull nd pull and pull right up to 6000rpm, i think I will continue with my first plans and sell this block as it is and build the steel one for piece of mind
Old Nov 22, 2008 | 09:20 PM
Red16's Avatar
Red16
i know the pics shite, but these are standard pistons from a 2ltr silvertop zetec
Old Nov 22, 2008 | 09:24 PM
Raj_FRST's Avatar
Raj_FRST
you a star mate, thanks very much, at least I can rule out the possibility of someone just wacking a standard bottom end in, im going to put this block on ebay tonight, should sell for around the400 mark I hope???
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
mgtkr1
107
Dec 6, 2016 04:23 PM
James Porter
Oct 28, 2015 12:17 PM
cossie09
Oct 11, 2015 06:29 PM
Bailes1992
Sep 3, 2015 02:17 PM
