finding TDC on Zetec
Old May 19, 2008 | 02:23 PM
b_kennedy's Avatar
b_kennedy
Default finding TDC on Zetec
Are there any markings on a zetec block for TDC like there is on a CVH. Thanks
Old May 19, 2008 | 02:32 PM
I don't know about ALL zetecs but know there isn't on the early ones ie silver top.
There is a pin that is inserted into the base of the block and it butts up against a flat section on a crank web inside.
tabethae
Old May 19, 2008 | 02:34 PM
b_kennedy's Avatar
b_kennedy
DAMN IT!!! Never mind. Thanks for your help
Old May 19, 2008 | 03:16 PM
JesseT's Avatar
JesseT
There's a mark on the alternator pulley (at least on the silver top) just as on the cvh.
Old May 19, 2008 | 05:47 PM
3i_gaz's Avatar
3i_gaz
the crank pulley has a mark on the zetecs. lines up with a casting mark on the sump or the block, cant remember off the top of my head
but as said before can use a locking tool too which threads into the front of the block
Old May 19, 2008 | 05:51 PM
JamesH's Avatar
JamesH
www.ford-force.com will be on there
Old May 19, 2008 | 06:39 PM
b_kennedy's Avatar
b_kennedy
Thanks guys. Much appreciated!!
Old May 19, 2008 | 06:48 PM
MJ_RST's Avatar
MJ_RST
tabethae
where about on the front of the block??
is there a bolt to remove to gain access to this first??
Old May 19, 2008 | 06:58 PM
magentasafchris's Avatar
magentasafchris
Take number one plug out put a cable tie down and turn it til it hits the highest point, works every time.
Old May 20, 2008 | 05:47 AM
Yes on the front forward facing part of the block, ther eis just above the bottom of the sump a lonely 10mm headed bolt, this is removed and a threaded pin of a precise length inserted, when engine is at TDC you can actually hear/feel the pin and crank web contact each other, take plugs out and it's a lot easier to turn.
Most car accessory shops will sell a zetec cam timing kit, whihc is a flat bar(5mm) to go in the rear of the cams, slot is offset so that it only fits correctly one way, and the pin, about £10 or so.
Old May 20, 2008 | 03:51 PM
b_kennedy's Avatar
b_kennedy
Will check it out in a min!! I think I actually got one of those pins somewhere. Hope so anyway lol :-?
JK12
33
Apr 26, 2021 12:09 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
