Eccentric Top Mounts and a Part-time road car
Old Aug 7, 2006 | 12:13 PM
AdamB's Avatar
AdamB
Default Eccentric Top Mounts and a Part-time road car
Right, i have a fiesta as a project car, the aim of it is to be a road-going car that is built for the track
i'm currently looking into alloy top mounts (Concentric or eccentric, i haven't decided yet) but have heared they're not the greatest when using them on the road, why is this?
i'll literally be using the car at weekends, and then occaisionally driving to and from shows and track events.
would they be ok for my car? i'll be doing less than 5k per year
Old Aug 8, 2006 | 06:27 AM
AdamB's Avatar
AdamB
bttt
Old Aug 8, 2006 | 10:58 AM
Mr 19"'s Avatar
Mr 19"
Hello! I have used eccentric topmounts for ten years on my Sierra without any problems. One thing to think about is that you get a set that doesn,t shorten your suspension travel too much, or raise the car. Many top mounts is made of a plain disc that doesn,t allow the upper spring platform to be in the same place as it is standard.
Old Aug 12, 2006 | 10:48 AM
AdamB's Avatar
AdamB
thats not too much of an issue... as i'm having my turrets extended
anyone else got experiences of using them on the road?
Old Aug 13, 2006 | 10:50 AM
AdamB's Avatar
AdamB
i'm sure there are plenty of knowledgeable people here, i wanna hear your opinions
Old Aug 15, 2006 | 06:11 PM
AdamB's Avatar
AdamB
bttt
Old Aug 20, 2006 | 10:23 AM
AdamB's Avatar
AdamB
i really am needing some advice guys
Old Aug 20, 2006 | 11:14 AM
ian sibbert's Avatar
ian sibbert
Hi Adam,
The top mounts will be fine, its the tranferal of road noise when using anything solidly mounted to the shell/chassis that people take a dislike to, you will hear and feel more through the steering wheel and through the car iteself, good in a competetion car, not so good on a full time road car. The shell will suffer a little more stress and you might think about some additional torsion/strengthening to compliment the top mounts, but overall for any track cars i'd say they were beneficial.
Ian
Old Aug 27, 2006 | 11:04 AM
AdamB's Avatar
AdamB
cool, well it'll have strut-braces and at least a 6 point cage, i aim to get the engine bay seam welded whilst the engine is out
Old Aug 27, 2006 | 05:23 PM
raymondo's Avatar
raymondo
Where or how are you modifying the existing turrets to take the eccentric top mounts, if you dont mind me asking. Im quite interested in this.
Old Aug 29, 2006 | 11:58 AM
AdamB's Avatar
AdamB
if you look at this pic:
you can see that the strut tops have been extended (basically a piece of CDS tubing has been welded in with a flat pate welded to the top)
he has fitted fixed alloy top mounts, but i can go for eccentric if i wish...
Old Aug 31, 2006 | 07:22 PM
raymondo's Avatar
raymondo
ah ok, thanks for letting me know. So is it a mk5 your fitting it to? The mk3 ones are already a similar shape but the extension bit would probobaly need to be made bigger. Are you doing the work yourself?
Old Sep 1, 2006 | 12:01 AM
AdamB's Avatar
AdamB
mk4
tbh, thats what you'd need to fit it to yours too
Old Sep 1, 2006 | 06:47 AM
JanDK's Avatar
JanDK
Any difference between alloy/eccentric other top-mounts?? what to choose??
I know some of them are adjustable.
Old Sep 1, 2006 | 09:11 AM
AdamB's Avatar
AdamB
basically it depends on certain things
if you want to keep a relatively standard suspension geometry, then the fixed version are fine
if you want adjstability, then you will need the eccentric ones
(they allow you to move position of top of strut and therefore adjust suspension geometry)
the only other option is if you want 1 or two piece top mounts
two piece are easier to service/replace bearings, but 1 piece are the norm.
Old Sep 1, 2006 | 09:26 AM
JanDK's Avatar
JanDK
Okay.. and I guess that adjustable not is that much of a must on a roadcar as mine??
Is sound like exiting upgrades when my topmounts need replacement, cause they do make a little noice when driving on paving stone and similar.
Old Sep 5, 2006 | 06:49 PM
AdamB's Avatar
AdamB
they will cause more road noise and a harsher ride quality
tbh you'd be best off with new ford top mounts
mines only having this because i'm fed up of having bump steer issues on my coil-overs (down 80-90mm) and also because mine will be a road legal track car so need more adjustability
Old Sep 5, 2006 | 08:34 PM
JanDK's Avatar
JanDK
oki... I understand.. my must be a driveable roadcar
Thanks
matman
Sep 9, 2015 05:45 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
COLEYST200
Aug 3, 2015 08:55 AM
