Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
focus st doesnt start
Old Nov 11, 2011 | 09:50 PM
iky's Avatar
iky
Default focus st doesnt start
hi guys im new on here ive just bought a focus st3 56plate bought it as mechanical problem from an insurance company.. ignition comes on it says on the dash-acceleration reduced also says engine system faults can some one help me plz it doesnt turn over just clicks??
Old Nov 11, 2011 | 10:34 PM
Cosworth Lad's Avatar
Cosworth Lad
Iky theres a specialist ford car elec that i now from brum i had a same problem turned out to be a wire burnt ill get you his num and he is mobile and comes out to you .
Old Nov 11, 2011 | 10:36 PM
iky's Avatar
iky
thaks alot mate that would be very helpfull
Old Nov 13, 2011 | 07:44 AM
oldford's Avatar
oldford
Battery empty?
When it clicks when you try to start: what happens to the lights on the dash?
Just to be sure: do you have a spare key? Tried it?
Old Nov 13, 2011 | 09:55 AM
martysmartie's Avatar
martysmartie
As said it could be a faulty battery or a jammed start motor etc. Have you checked the battery voltage etc?
I can't see any EMS related fault would prevent it from starting, if the battery was a problem this can also cause EMS related problems.
An easy test is to turn the headlights on, if they stay bright after several seconds theres a good chance the battery is ok, if they start bright then go dim then suspect the battery!
Martin
Old Nov 13, 2011 | 11:00 PM
iky's Avatar
iky
Originally Posted by oldford
Battery empty?
i dnt have the spare key, ive changed the battery its doing the same thing..
i think either my flywheel is broken or the clutch because when car is in gear and i push in the clutch it doesnt move forward and the clutch feels dead..
any ideas if the flywheel has a sensor on it?
Old Nov 13, 2011 | 11:42 PM
dug112y's Avatar
dug112y
passionford pro
does the engine turn over by hand??
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Fordmad!
Sep 26, 2015 05:24 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
