2.0 twin cam efi into sierra 1.6 pinto
Old Feb 20, 2018 | 06:23 PM
evolution2's Avatar
evolution2
Default 2.0 twin cam efi into sierra 1.6 pinto
hi all as in my last post i wrote up about my new granada i bought
i also have a 1.6 pinto sierra
i bought it but never got around doing anything with it
so since a have the granada it just hit me would,nt it be a great idea to swap with engine out of the granada into the sierra
its a 2.0 doch efi great running engine going very well
i have changed engines before but it was just bolt in bolt out job never on a ford
my sierra has the type 9 gear box i think as its a 1.6 pinto
will it bolt up the the 2.0 engine as the granada is automatic
also i will need an efi petrol tank i dont think the granada one is the same as the sierra
or will the sierra one do or will i need to go look for another one
wireing wouldnt be my strongest point put from with i gather in my own head is that i will just swap the loom over from the granada into the sierra with the ecu and so on
any help to me would be very much appreciated
thanks
Old Mar 2, 2018 | 08:22 AM
Csm's Avatar
Csm
I did this conversion with a 2.0 twincam efi into a 1.8cvh carb both sierras on 91/92 reg years J+K plates the twincam engine was an automatic unit
From what i remember this is what was needed........
You will need the MT75 gearbox, you will need the propshaft also and a flywheel and go to ford for the small spiggot bearing on end of crankshaft area it is needed.
convert the wiring loom and ecu into the car and a petrol tank and all i had to do was add a fuse into the fusebox in engine bay for the fuel pump to run.
I am positive i had a slight issue with the vacuum pipe that runs from master cylinder but i had a blast in that car for what it was
hope some of that hekps
Old Mar 3, 2018 | 09:15 PM
evolution2's Avatar
evolution2
thanks very much thats all the info i need top man
Old Apr 12, 2018 | 08:10 PM
evolution2's Avatar
evolution2
hi i just need a bit more info csm. will i need to swap the all the wiring loom of the granada into the sierra
will i need to swap the granada fuse box over to the sierra as well
is it a plug in job
or has there to be lots of wires cut and joined to get it running
had you any problems
also you where using a automatic loom like i will be
sombody told me i will have to join two wires so the car will think its in neutral to get the car started???
is it a hard conversion or handy
many thanks
i will be posting up photos as i go along cheers
Old Apr 13, 2018 | 12:39 AM
dojj's Avatar
dojj
Resident Wrestling Legend
you will need the manual starter motor as the autos were different
you'll need the flywheel form the dohc as well as the clutch
but other than that it's plug and play
Old Apr 13, 2018 | 08:48 AM
Csm's Avatar
Csm
its plug and play as above fella
Old Apr 15, 2018 | 10:25 AM
evolution2's Avatar
evolution2
thanks guys im fine with the mechanical side of things
just the wiring side of things i wouldnt be great
but if its a plug in job should be ok
do i need to swap the fuse boxs
Old Apr 22, 2018 | 05:45 PM
evolution2's Avatar
evolution2
hi everyone made a bit of a start to day
Old Apr 22, 2018 | 05:48 PM
evolution2's Avatar
evolution2
Old Apr 22, 2018 | 05:53 PM
evolution2's Avatar
evolution2
Old Apr 22, 2018 | 06:02 PM
evolution2's Avatar
evolution2
this is the sierra that im fitting the twin cam into
it will need a small tidy i have a new rear bumper ordered for it.over all shes in good nick< 28 years old>
and i have a fog light front bumper for it that i got of a twin cam sierra a few years ago
im going to use the the type 9 gearbox and clutch and flywheel i think it will work with the l4 engine <the granada is automatic>
my biggest problem will be with the wiring
will i need to swap over the fuse box etc etc
cheers guys!! let me know what you think
Old Apr 23, 2018 | 05:47 PM
turbo m's Avatar
turbo m
Loving the old school 7 spokes on the granny
Old Apr 23, 2018 | 08:30 PM
evolution2's Avatar
evolution2
cheers yeah there rs one,s never seen them before but they are on it since new as its got the spare alloys as well
i will but them on the sierra when its finished
ill have to swap over the hubs and stuff granny is 5 stud sierra is 4 as you know
Old Apr 23, 2018 | 10:13 PM
mk22door's Avatar
mk22door
Fart of the Purniture
I don't think your type 9 box/flywheel/clutch etc will just bolt up and work without a fuss - speedo drive etc is something to think about.
Your mk3 Granada DOHC has an auto sump, if you were to use an MT75 RWD manual gearbox to convert the granny to manual you would need a manual sump as the starter motor is on the other side.
But as your going to attempt mixing that into the Sierra with type 9 stuff I think it might be awkward?
Good luck
Old Apr 23, 2018 | 10:23 PM
mk22door's Avatar
mk22door
And I think your fuel lines will be on the wrong side too.
Old Apr 23, 2018 | 10:26 PM
mk22door's Avatar
mk22door
By the way I'm not neigh-saying but just trying to help you think of the problems before you get to them.
Old Apr 25, 2018 | 06:48 PM
Csm's Avatar
Csm
You need the MT75 box fella
Old May 20, 2018 | 08:40 PM
evolution2's Avatar
evolution2
hi guys a bit of an update
Old May 20, 2018 | 08:51 PM
evolution2's Avatar
evolution2
i have the engine out of the granny not a bad job but was hard to get out of the engine bay
because of this hugeeee torque converter
Old May 20, 2018 | 08:54 PM
evolution2's Avatar
evolution2
so i removed it i should have done it before i removed the engine but i was to lasy
Old May 20, 2018 | 08:58 PM
evolution2's Avatar
evolution2
Old May 20, 2018 | 09:03 PM
evolution2's Avatar
evolution2
as above you can see i removed the engine loom and ecu
from what i can see i have remover all that i think should make the car run
all the sencers etc etc i have never done it before so please if anybody can see anything i have done wrong say it as i am just learning here
i also removed the main engine loom to i didnt get a photo of
it unplugs from this loom
Old May 20, 2018 | 09:09 PM
evolution2's Avatar
evolution2
Old May 20, 2018 | 09:16 PM
evolution2's Avatar
evolution2
i know some of you told me i need the mt75 box
but i think the type 9 box will fit if i use the 1.6 fly wheel clutch etc
the type 9 box would not fit if i used a twin cam fly wheel because they are massive <1.6 flywheel is smaller>
i could be fully wrong here but im going to chance it and see i hope it will work
Old May 20, 2018 | 09:25 PM
evolution2's Avatar
evolution2
Old May 20, 2018 | 09:26 PM
evolution2's Avatar
evolution2
this sierra is soon to become a 2,0 efi
Old May 20, 2018 | 09:31 PM
evolution2's Avatar
evolution2
Old May 20, 2018 | 09:44 PM
evolution2's Avatar
evolution2
poor granada i have destroyed it it will never see the road agen
i am going to beak it so it may help another granada live on
if any1 whats bits of it give me a bell
cheers guys
eddyj
Dec 11, 2015 11:23 AM
N.Saph
Sep 15, 2011 07:18 AM
grooge
Jun 10, 2010 02:58 PM
sierra_2008
Oct 3, 2008 06:04 PM
johnnysash
Aug 23, 2005 09:27 PM
