More bits for project ' Queen '.
Old Dec 20, 2014 | 06:28 PM
  #401
Mark Shead's Avatar
Mark Shead
Originally Posted by JamesH
Rod/Mark,
I thought with the 106 or 108 fuel you've used before, you could get a lot more spark in on Evos and they loved it, but the Cossie would just pop the head gasket? If so, how is it going to be different on the purple?
When I looked in to the race fuel I wanted something that made more power without the need for lots of extra timing, The FTW seems to fit the bill on that side,
We could run Vp import but to make that really work it would be better to run circa 9.5-1 rather than just adding extra timing.
Mark
Old Dec 20, 2014 | 06:35 PM
  #402
Mark Shead's Avatar
Mark Shead
Originally Posted by Fullflush
The AG focus runs 50+ psi, I'm sure they don't use that funky fuel either. Why not chat to their engine builder as they have already achieved what you are trying to do?
Why would we do that, Remember we are doing on a pure YB block and head and not the higher flowing Smith and Jones head and taller block for better rod angles,
It is harder to do the 1000hp on a YB for that reason,
Also I hear they are now having to rev it to 9k as it does not have the response lower down,
Rods engine is in his road car and need to still respond like that, We could easily make the power easier with the change on head and block but this will add a circa of 10k on top of what we have already spent.
Mark
Old Dec 20, 2014 | 08:19 PM
  #403
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Rod/Mark,
To add to what Mark has said. We now fit 55% higher shear strength bolts & have done block mods to aid head gasket integrity. However Mark does not want to add extra ignition than we did on the 838 engine that proved safe. The Purple does not need extra ignition just extra fuel to make a 10% increase over 106. The vibration mods will be more critical at this Power level than gasket integrity im sure.
Old Dec 20, 2014 | 08:48 PM
  #404
JamesH's Avatar
JamesH
Ah ok that makes sense. Sounds like good progress! Would be really interesting to know the peak cylinder pressure at high compression, high boost and decent fuel!
I really hope it goes well
Old Dec 21, 2014 | 12:33 AM
  #405
Fullflush's Avatar
Fullflush
Mark - I didn't appreciate the differences. One question, why is revving to 9k + a bad thing?
Old Dec 21, 2014 | 05:29 PM
  #406
opposite lock's Avatar
opposite lock
i think he may be saying Its not road friendly unlike rods engine.
Old Dec 21, 2014 | 06:11 PM
  #407
Caddyshack's Avatar
Caddyshack
Everything else also struggles, add 1000 rpm at the top end and oil pumps, water pumps, cams etc are all stressed.
Engines that need loads of revs to make the power are hard work. If you drive a 330i or 328 BMW then try an e36 m3 it s amazing how hard you have to work to release the extra power.
Old Dec 21, 2014 | 11:17 PM
  #408
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
My last engine revved to 9k but it didn't need to be driven like that. Mark would read the riot act if he read my data log & he saw I was using too many revs Mark don't like rev cuts so it was down to me to be sensible, in mine changing at 8.2k gave best progress but sometimes I used a lot more. Bit shocked to see 193mph (8.8k) in 4th on the Newbury Bypass but its recorded although it wasn't me Mark . Ive a dry sump fitted to this new engine just in case I start using all those revs again . Its not a bad thing but will shorten the life of a road engine.
Old Dec 22, 2014 | 06:59 AM
  #409
JamesH's Avatar
JamesH
Old Dec 22, 2014 | 01:05 PM
  #410
opposite lock
193 in 4th ........... Once done , we need more road footage thats just bonkers lol
Old Dec 22, 2014 | 02:23 PM
  #411
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mark looked at my Data & asked what speed was 8.9k in 4th I said 193mph on the Stack if you do the maths on gearing its actually 190.0 .
Old Dec 22, 2014 | 03:10 PM
  #412
opposite lock
Mind blowing stats.
what with the extremes and nessasity for the calculations, would any extra weigh 'hurt' that last few horsepower for top speed?
how much heavier will it be if at all.
cheers
mike
Old Jan 1, 2015 | 12:56 PM
  #413
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Well its 2015 & my New Years Resolution is to finish the car this year .
Start next week with a trip to Vibration free to pick up pistons & cams. Will also get the sump sent out for a mod so the dry sump will suit my application. THEN NO MORE EXCUSES FROM MARK OR MYSELF.
Old Jan 1, 2015 | 06:06 PM
  #414
costina's Avatar
costina
Live long and prosper!!
Happy new year to you Rod be interesting to read about the build.
Regards
Paul
Old Jan 1, 2015 | 09:44 PM
  #415
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mind blowing stats.
cheers
mike
No weight is not really a factor its just bhp v aero brick wall. Gain 100m at the start with less weight & that's only 1 extra second on the throttle at 210mph when you are deffo struggling to acclerate. Stability from the extra weight as speed goes over 190mph more than compensates. These cars were not put in a wind tunnel to see what happens at 190+mph they move about a lot is all I can say. The car will be slightly heavier I suppose but we always run fully loaded so it will make no difference.
Old Jan 2, 2015 | 04:41 AM
  #416
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
great to hear this legendary car will be back out again this year look forward to seeing how you get on
Old Jan 7, 2015 | 08:22 PM
  #417
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
This is a long shot.
I need a 80mm 4bar Boost gauge. Only one I can find is a Stack which would be perfect. Problem is they have not been made since 2009 .
Ive asked in the Wanted section as well
Cheers Rod
Old Jan 8, 2015 | 06:15 PM
  #418
CrOwSoN15's Avatar
CrOwSoN15
Ben
Just had a look around and I see what you mean, everything is 3 bar! Do you reckon a company such as Stack would be interested in doing a one off for you?
Old Jan 8, 2015 | 06:19 PM
  #419
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Can you not just use one of the smaller spa digital ones
Old Jan 8, 2015 | 06:52 PM
  #420
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I could but my present one is 80mm to match the Rev Counter/Speedo/Odometer.
There are still a few Stack 3 bar ones around despite not being made for 5 years.
My present set-up a 3bar Elliot gauge the Stack 4bar would look so cool I must find one.
Old Jan 8, 2015 | 07:13 PM
  #421
costina's Avatar
costina
Only one i could find is on the cossie dolly ALG 1K .
Good luck finding one.
Old Jan 9, 2015 | 07:43 PM
  #422
costina's Avatar
costina
Shame I found a 3 bar
http://www.mardigras.co.uk/sale.htm
Old Jan 9, 2015 | 09:14 PM
  #423
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Originally Posted by costina
Yes !!
Mike R has one as well but the 4bar version is difficult to find.
Old Jan 9, 2015 | 09:19 PM
  #424
Thanasis's Avatar
Thanasis
http://www.speedhut.com/gauge/GRM258...ic-(w--warning)
http://www.speedhut.com/gauge/GRM-BO...ic-(w--warning)
Old Jan 10, 2015 | 09:49 AM
  #425
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
There are lots of 4 bar gauges at that size. Im looking for a 80mm (3 1/8") gauge & cant find any .
Old Jan 10, 2015 | 09:54 AM
  #426
costina's Avatar
costina
I will keep looking never know eh.
Paul
Old Jan 10, 2015 | 10:39 AM
  #427
lee2cossies's Avatar
lee2cossies
Yes !!
Rod, wasn't miker breaking his car? He did put a advert up on the escort forum a while back may be worth giving him a pm.
Old Jan 10, 2015 | 09:47 PM
  #428
jamie956's Avatar
jamie956
Cheers Rod
Slightly bigger than your after but close,
http://www.speedhut.com/gauge/GR338-...si-(w--warning)
Old Jan 11, 2015 | 12:17 PM
  #429
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
http://www.speedhut.com/gauge/GR338-...i-(w--warning)
Interesting. Bigger would be OK.
Old Jan 11, 2015 | 06:39 PM
  #430
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
That's a solution that site. Can design what you want its 91mm OD against the Stack 88mm.
Obviously the first design is my preferred one.
Old Jan 11, 2015 | 06:44 PM
  #431
Jay,'s Avatar
Jay,
Sponsor
My god some of the faces on those dials
Old Jan 11, 2015 | 07:15 PM
  #432
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Jay you can design what you want that's just 4 I dreamt up. Will probably go with the 4th one as it nearest matches the Stack.
Old Jan 11, 2015 | 07:17 PM
  #433
jamie956's Avatar
jamie956
Have you looked at the GPS speedos unsure off accuracy but got to give you a better idea at top end over the std speedo, 52mm as well for pod mount.
http://www.speedhut.com/gauge/GR2-GP...r-Gauge-200mph
Old Jan 11, 2015 | 07:18 PM
  #434
nixon_2wd's Avatar
nixon_2wd
I agree. Send them your Stack tacho and make them match your new boost gauge.
Are we getting to see some more pics of the engine coming together soon?
Old Jan 11, 2015 | 09:05 PM
  #435
Jay,'s Avatar
Jay,
Sponsor
Ah ok mate
Old Jan 11, 2015 | 09:39 PM
  #436
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I have a Stack it was 2mph out from Datron at 206mph as its calibrated to tyre diameter.
Old Jan 13, 2015 | 05:05 PM
  #437
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Can a 800bhp be driven on the road without any probs. These 2 vids were made by a Ferrari owning friend. One ive never seen the other maybe at the time. Love his chuckle on the 2nd Vid.
Old Jan 13, 2015 | 05:08 PM
  #438
ajamesc's Avatar
ajamesc
Crazy how fast that is rod! I clocked 150 on my r1 up that road from roundabout to roundabout he just called 140 half way up there lol
Old Jan 13, 2015 | 05:12 PM
  #439
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Well before the bridge as you can see. He did it in his Ferrari & saw 92 on the Speedo at the bridge. Mind you its a shite Ferrari .
Old Jan 13, 2015 | 05:47 PM
  #440
Caddyshack's Avatar
Caddyshack
You know people have been prosecuted on the strength of these types of videos....great to see but do be careful quoting speeds and certainly do not show the speedo.
