More bits for project ' Queen '.
Old Feb 17, 2015 | 08:47 PM
  #481
Jay,'s Avatar
Jay,
Sponsor
thats right Rod and Piero at expower engines does the brackets
http://www.ebay.co.uk/itm/COSWORTH-C...item2a4c0be4d4
and cam trigger
http://www.ebay.co.uk/itm/COSWORTH-C...-/181570053337
Give him a bell Rod his is a really nice bloke
Old Feb 18, 2015 | 03:05 PM
  #482
s1cosse's Avatar
s1cosse
That cam trigger in the link does not look Wright it's got a lob missing.
Old Feb 18, 2015 | 03:19 PM
  #483
Mark Shead's Avatar
Mark Shead
It is correct for aftermarket management that does not have the stock trigger pattern in it.
Mark
Old Feb 18, 2015 | 05:14 PM
  #484
MK MOTORSPORT's Avatar
MK MOTORSPORT
Mark
hi mark
I think its 2 for stock and 1 for aftermarket ,the ones we make have 2 and 1
I know t6 uses 1
mark
Old Feb 18, 2015 | 05:18 PM
  #485
Jay,'s Avatar
Jay,
Sponsor
Piero does both that was just a example for Rod
Old Feb 18, 2015 | 06:02 PM
  #486
Mark Shead's Avatar
Mark Shead
Originally Posted by MK MOTORSPORT
hi mark
I know t6 uses 1
mark
Correct.
Mark
Old Feb 20, 2015 | 03:52 PM
  #487
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Made progress on the fuel system today. Protec wish to get involved in this project so we will have info from the experts. They are going to test there P1 Veyron pumps @ 16v with 115psi pressure & report back. It may mean we can get a single pump to cope with fuel supply. They will also make sure the Dyno company have the correct fuel system to support our bhp at these enhanced boost levels. All he wants is publicity & a small sticker on the back of the car . Its a case of you don't get if you don't ask . Oh yes & be there when we run.
Im waiting for the parts to arrive for the cam trigger mod & then will get the cover drilled to suit & the Cam modified to take the trigger.
There is a Vmax in mid October & that looks the best bet for an attempt to secure 3 records. Fastest Cossie, Fastest Ford & Fastest 4 pot. We need to exceed 210.4mph to achieve that so that's the target, time will tell how realistic that is.
Old Feb 20, 2015 | 04:26 PM
  #488
cozzy jeff's Avatar
cozzy jeff
Rod has your rocker cover been machined yet?
I have a rocker cover machined with sensor and holder i might sell.
Old Feb 20, 2015 | 04:53 PM
  #489
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I have purchased all the parts & Cover is about to be machined. But thanks for the offer. 3 days ago I would have been interested.
Old Feb 20, 2015 | 06:00 PM
  #490
cozzy jeff's Avatar
cozzy jeff
I have a cam cover machined for sensor,comes with sensor and holder if your interested rod?
Old Feb 20, 2015 | 06:21 PM
  #491
smiley's Avatar
smiley
Amazing achievements already rod dream spec ultimate spec call it what you will its great watching you do what your doing i hope you do it just awesome!!!
Old Feb 20, 2015 | 08:26 PM
  #492
Focosmitch's Avatar
What parts did you go for in the end for the cam trigger rod? This is something il be doing very soon also!
Old Feb 20, 2015 | 08:41 PM
  #493
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
As recommended by Jay in post 481.
Old Feb 20, 2015 | 10:01 PM
  #494
Jay,'s Avatar
Jay,
Sponsor
Piero is ex mountune and supplies alot of bits that are very useful
Old Feb 26, 2015 | 05:04 PM
  #495
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Been over to Marks today to take the cam trigger parts. Went to try & simplify what we are trying to build. Fat chance ended up with more bits to do . The DBW is now dead & forgotten & the 'push' bottle will be removed from the Nitrous system & it will go back to a single fogger that frees up the ITB's. Wanted to cut back on the complex Traction Control that Mark wants but he is bigger than me so it stays. Other sensors will be added to go with the multitude of other sensors & alarms if a dog farts in Iraq my ECU will know & take action . A 4th Plug is now in play on the ECU with wideband Lambda so much for wanting a simpler system.
Also got looms to make for an Escort & a Lancia Intergrale so fat chance of having a rest over the next couple of weeks. Its the first cars with the new Emtron SL series ECU's, Marks preferred solution on a Cossie these days.
I wish to run the car in mid October so we have 8.5 months to get the car ready.
Old Feb 26, 2015 | 05:20 PM
  #496
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
haha i genuinely lol'd at this
Old Mar 23, 2015 | 07:53 PM
  #497
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Well I built a loom for my new engine some time back, lets say that was not a good idea. With lots of changes & add-ons it was simpler & probably cheaper to build a new one. Started today I will finish the in-car part as that's fixed & leave the rest ubtil the engine is built.
Im not sure it happened (cue Mark) but my Block & Sump should have gone out for yet more mods this week. When they return the build will start in earnest.
Old Mar 23, 2015 | 07:59 PM
  #498
Caddyshack's Avatar
Caddyshack
Nice, what make heat shrink do you use?
Old Mar 23, 2015 | 08:08 PM
  #499
cossiestu's Avatar
cossiestu
Tidy job that! I take it wiring looms are your forte Rod?!
Old Mar 23, 2015 | 08:12 PM
  #500
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Use RS Components for most things.
Old Mar 23, 2015 | 08:13 PM
  #501
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Only because Mark Shead forces me to make his looms .
Old Mar 23, 2015 | 08:23 PM
  #502
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Well I hope I can say this is the final solution ( well until Mark changes it again tomorrow. It does not include closed loop Lambda thats on a seperate loom.
THE CAR DIAGRAM
THE KV8 DIAGRAM
THE MAIN LOOM
  #503
Jay,'s Avatar
Jay,
Sponsor
I had to threaten to take his stilts away to do my loom
Old Mar 23, 2015 | 08:57 PM
  #504
foreigneRS's Avatar
foreigneRS
Testing the future
proper job
Old Mar 23, 2015 | 09:15 PM
  #505
markk's Avatar
markk
What program do you use to draw your looms in Rod?
Looks great
Old Mar 23, 2015 | 09:34 PM
  #506
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Looks great
AutoCAD the drawings are very basic a lot of cutting & shutting from other loom files no time to draw the looms or Diagrams from scratch. Ive around 80 different Diagram/Loom files that ive done for M.A.D the latest is for a Lancia Intergrale it keeps the brain active or something like that. Not sure what happens when I get too old but apparently im good till im 90 so a few years yet.
Old Mar 23, 2015 | 09:47 PM
  #507
cossiestu's Avatar
cossiestu
Surprised my dad didn't collar you to rewire his alarm when that packed up?!
Old Mar 23, 2015 | 09:48 PM
  #508
markk's Avatar
markk
I have not tried to draw a loom yet, I can use AutoCAD and Inventor though so should be ok.
Thanks
Old Mar 24, 2015 | 01:04 PM
  #509
ossie cossie's Avatar
ossie cossie
Nice work Rod. I am looking at getting an emtron ECU for my track escos, they are local to me here in Australia. How do you find the ECU. May need to pick your brains about it all. I have also been told the ECU can work the skyline R32 4x4 box i am also putting in?
Old Mar 24, 2015 | 05:46 PM
  #510
Caddyshack's Avatar
Caddyshack
I think Mark mainly does emtron now and it can control the skyline diff....yes.
Old Mar 24, 2015 | 06:27 PM
  #511
Mark Shead's Avatar
Mark Shead
It's the best ecu I have used by quite a margin
Mark
Old Mar 28, 2015 | 07:52 AM
  #512
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Finished the loom as far as I can, now need a built up engine to finish. Have taken unused input/outputs + all Voltages & Sensor Ground to a couple of Spares connectors for future expansion. Its bulky with twice the wires to the looms I normally produce.
Old Apr 6, 2015 | 09:42 AM
  #513
Jay,'s Avatar
Jay,
Sponsor
Any progress Rod ? mine is booked in at Marks for the 18th to get mapped in its current state ! Be a while yet before the other engine is done and need to get it out and drive it
Old Apr 17, 2015 | 07:12 PM
  #514
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Progress today after 2 weeks of not being able to work on the car I went over to Marks & stripped down the Block & fully cleaned it. The mods to the dry sump were finalised so those 2 parts can be modded. The sump to be welded to fit this application & the Block for more oil supply mods above those that Mark does at big Power.
Today I also met Nick who owns the 180mph Capri & asked if he would drive my car if I was not allowed to drive (will explain) he said it will be a
privilege Rod .
Around Christmas time I started to notice a problem with my right eye, I don't wear glasses so was very surprised it got a lot worse over the next month or so went for an eye test. Ended up seeing a Specialist & it was confirmed 2 weeks ago that I have Macular degeneration. It cant be cured & I know what will happen in a few years as my Mum had the same & it started at my age . I have to wear Dark Glasses for driving as its caused by Sun damage. They say commuting for 30 years driving into the Sun may have caused it not helped by a Viscous detachment of the Retina a few years back. Im fine at the mo as my left eye is just fine.
Old Apr 17, 2015 | 07:30 PM
  #515
costina's Avatar
costina
Live long and prosper!!
Still very impressive that you can squeeze a get deal of power out of a 1970's pinto derived block.
When do you think it will be ready Rod? RS coombe?
Paul
Old Apr 17, 2015 | 07:43 PM
  #516
gjh's Avatar
gjh
privilege Rod .
Bugger! Sorry to hear that about your eyes Rod, people take their health for granted, (me included). Hope some sort of treatment will be possible in the near future (never give up hope)
Old Apr 17, 2015 | 07:50 PM
  #517
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Paul
Yes ready for Coombe 2016 but it may be tight .
Old Apr 17, 2015 | 07:56 PM
  #518
costina's Avatar
costina
Rod was that Nick's green capri that vbh drove against clarkson?
If so that is one of my fav cars.
Sorry to hear about your sight.
Paul
Old Apr 17, 2015 | 08:12 PM
  #519
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Paul
No. This is Nicks Capri. 503bhp YB fitted it will return soon with a chunk more Power.
Its one of my sons favourite all time cars the other is Martins green Mondeo. Mine is old hat compared to those he told me. It also makes my list of the best ive seen.
Old Apr 17, 2015 | 08:13 PM
  #520
Caddyshack's Avatar
Caddyshack
There are new drugs for Mac deg, and a company close to you have been done for holding back the good stuff, do not let it get you down, stem cell research are making massive gains in this area and more field hospital are right at the front.
If you need any other hot shoes to drive it I have had some Experience and car control is in the bag of tools.
