Mk6 JWRC fiesta cosworth
#4842
Well the trackdays went well
Snetterton was awesome, nice dry and sunny, drove it hard all day and no issues
Brands was wet and slippy as hell, got better in the afternoon so was able to push a bit but not fully as did not have the confidence in the conditions
BUT........i broke another gearbox!
I have broken 2 now as i just shift too hard it seems, both have snapped the 3rd/4th selector fork and all the little shifter inserts on the 3rd/4th syncro break up which definitely happens first causing the gear change crunching and then going on to cause the snapped fork
I have now opted for a Brand new 5 speed close ratio sequential box from a company called PGS TRANSMISSIONS in Finland, my casings will be going off to Olli this week and then they can get on putting the box together for me and then shipping it back probably end of Feb to begining of March time
The input shaft is a larger diameter Hollinger size rated to huge bhp, the selector forks are billet and guarenteed for life, the gears and dogs etc are guarenteed to 800bhp so hopefully i should have no issues with this, i just need to order the gear knob load cell from KA Sensors so we can control the clutchless flat shifts via the ecu and clutchless down shifts with throttle blip
On removing my gearbox i found a crack in the bellhousing, luckily i have caught it early and it is only approx 1" long, this has happened to every single skyline box conversion it seems, so like Mark Knight and Coley i will joint the webbing supports and probaly add some other supporting straps if i can and then see how it gets on like that,
The Sequential box route was mainly due to the fact you can not buy all the parts for the skyline gearboxes easily unless its just syncro's you need, but i would probably only end up breaking it again so wanted something that can cope with some serious abuse without any worrying at all
Thanks
Marc
Thanks
Marc
#4845
A few images of my 2 broken gearboxes,
First 1 with fork damage from 2 years ago and the second with the completely snapped fork is what happened to my second box at brands in November
#4846
These are the little shifter inserts that you need on the 3rd/4th gear syncro part, when these break up i beleive this is what starts the crunching and then if you carry on with it things get progressively worse until it just doesnt want to go in gear and you force it and break the selector forks like i did?
#4849
It seemed to be mate
i have been in the shed and repaired the crack and built up and joined the central webbing then welded on some bracing straps from 5mm flat bar and tied it all in together
#4854
Looks great, big bux on the new gearbox no doubt but should be brilliant. I would be tempted to send the bellhousing off to have a 1 piece casting made. It’s a shame that a one piece billet would be so much money.
#4855
Like this technical cad drawing I made
Wouldn’t the straps be better going past the first weld back on to the skyline bellhousing to avoid the first weld in the Cossie to skyline joint being weakest point.....I know nothing about this sort of thing but it made me ask when I looked.
#4856
Cheaper than your Oppliger box. That's why the Skyline box was a great conversion. Gearkits don't have Cosworth tax
#4858
When my bell housing cracked the chap that welded it up told me the problem is with the Ford casting as the alloy is shit . And no the uver hand the skyline part is good alloy . So the only way to try and get round it is to do wot you have done . But don't forget the inside of the bell housing as that's the next problem the difference in the sizes of the cases you need to get as much weld and gussets in there as possible .
#4859
#4860
I preferred the option of 2wd and 4wd but I didn't like the extra weight and noise of the pump though.
#4861
The problem is that regardless of the quality of the material it is a large circumferential weld being put under "Shear stress" with the weight of the box hanging off it and the engine and gearbox mount movements so not ideal, the bracing others and now i have done will help and as toby pointed out it was probably better to tie in further onto the skyline case at the top for more support so i done that quickly this morning.
I spoke to 2 company's at Autosport regards 3d scanning the hybrid casing then having casting molds machined, after the molds are paid for the casings would be approx Ł150 each then there is the machining of each casing which would probably be another Ł500 but the cost of the scanning 3d to cad file and the moulds came in at approx 8k so just not worth it
I hope that with these bracing supports now welded in i wont have the issue again but only time will tell on that 1 i suppose
Turnover - The bolts sit flat and straight, well as good as per the original casting which is only ok at best with these old things. the engine and gearbox mountings are rubber bushed still on my car
#4863
The casing has warped again slightly with all the welding, i bolted it down to my dummy block and sump and you can slip a 0.30mm feeler gauge under the casing between the 2 top bolts, im happy with that as that is measured without the steel dust guard in place so that will be fine
#4865
Nicely done. I was only asking, lol...you know millions more than me about this stuff but glad my idea may help.
i too looked in to the 3D scan and it was expensive but I did find a foundry who would make a sand casting for not a lot but you need one per bellhousing. It was hundreds, not 000’s.
#4867
I don't think you could buy a donor box, have it cut and welded, all the ancilliary bits such as pump, ECU controller (to do it properly like ETS pro) then have the box stripped and rebuilt with a sequential gearkit then gearbox mount and do it for any less than the oppliger. Add in the cost of tunnel adaption and then new props (althogh you may need different rear prop on an oppliger)
The active centre was a must. And considerably less than 6k.
#4868
Does weight not affect your type of racing? I would have thought 20kg from the centre of the car and maybe 5-10 kg of pump and reservoir elsewhere savings would be a competitive advantage but then where do you stop...dieting before a race?
Are you on ETS pro to control the centre diff? I cannot remember?
#4869
But that is non sequesntial for that cost and Marc has broken 2 of the normal ones.
Of course weight matters if you are chasing 100ths of a second, but weight means nothing if you don't finish.
I don't use ETS I use a different system.
My car is close to minimum weight but my weight split is damn near 50/50 front/rear and side/side.
If I wanted the biggest weight change I would be better going on a diet and losing 30kgs. 😌😌😌😌
#4871
4 years on !!!!!!
still have the car but not done anything with it apart from mot it
it has the full skyline sequential now
I’d sell it if someone come up with about Ł75k as I just don’t have time for it anymore really, wife, 2 small children and my own business just doesn’t give me the spare time but part of me wants to get some use out of it
who knows, maybe one day lol
#4872
4 years on !!!!!!
I only need to use it every now and again and remember why it sits there.
Still worth good money if I ever break it apart.
Park it, stick a sheet over it and call on it in 10 years time.
#4873
#4874
Still here
been doing a few bits with it lately with the view of maybe driving it once in a while
just fitted a new Ecu master ADU 7 dash display with gps to can and wheel speed to can
also swapped out the clutch and flywheel for a more user friendly one
the car has not got an mot currently but maybe next week or week after I will get it done
s1cosse (20-03-2024)
#4875
Inquiry
Hi, despite this being an old post, I'm interested to know if your car is still available.
I'm planning a similar conversion and would like to ask a few questions regarding the suspension modification.
Love the jwrc kit, Here's a few pics of my mates old one
Attachment 120645
Attachment 120646
Attachment 120647
Attachment 120645
Attachment 120646
Attachment 120647
TPM961
15-01-2018 11:50 AM
