Peugeot 205 with 4wd cosworth engine and running gear.
Old 22-04-2018, 07:33 PM
  #2041
markk
markk's Avatar
Lots if loose and gravel at Anglesey 😁👍👍👍
Old 22-04-2018, 08:31 PM
  #2042
Caddyshack
Caddyshack's Avatar
That’s the stuff I like. I have tried rallying in a 205 and loved that, I enjoyed ice racing and wet handling. I don’t like drifting much as it is fake oversteer in my opinion.
Old 22-04-2018, 08:45 PM
  #2043
markk
markk's Avatar
Drifting lol. Shittest motorsport going.
Old 24-04-2018, 05:50 AM
  #2044
smiley
smiley's Avatar
The drug dealer has been tempting me with some 7075 lightweight flanges, the 4 that hold the wheel studs, I had not heard of 7075 before and it was secretly developed by the Japanese years ago and is now used for the undercarriages of aircraft, it is very light and quite resistant to corrosion whilst being as strong as steel....we will see what we can get the cost down to.
I am working on the doors today and adding some ally bar behind the hinge points and check strap as I know these will break in a gust of wind if the door is left open if not.
He mentioned this when I asked him about custom flanges, you having them? Does he get them broached by somebody else? My uncle was explaining to me about broaching for the splines very interesting he was saying it's done chemically I think
Old 24-04-2018, 07:06 AM
  #2045
FLAT TRACK
FLAT TRACK's Avatar
never heard of that
Old 24-04-2018, 08:01 AM
  #2046
smiley
smiley's Avatar
Originally Posted by FLAT TRACK
never heard of that
How do you do it? He designs and makes underwater Rov's and winches for the oil industry he says he outsources to a company to do his
Old 24-04-2018, 08:36 AM
  #2047
FLAT TRACK
FLAT TRACK's Avatar
there done on a machine
Old 24-04-2018, 09:16 AM
  #2048
Caddyshack
Caddyshack's Avatar
Can you explain what "broaching" is as I do not know what bit it refers to?
My Dad was in the Engineering side of ROV's etc, he worked for the Institute of Oceanographic Sciences, under National Environment Research Council on the RRS Discovery ship. They did things like the Antartic Survey
Old 24-04-2018, 10:53 AM
  #2049
costina
Live long and prosper!!
costina's Avatar
Broching is done by a stepped tool which is pressed into a bored hole to almost chisel a step into the hole to make a keyway or splines.
That's the simplest way i can explain. I done it many years ago when in engineering.
you can spark erode too I believe
Caddyshack (24-04-2018)
Old 24-04-2018, 11:00 AM
  #2050
Caddyshack
Caddyshack's Avatar
7075 hubs, hard anodised
Lightened CV joints WRC style, these will also have titanium bolts too.
Hubs on the bench
Just realised that you can see my front WRC suspension strut towers in the pic too ready for the top mounts
Old 24-04-2018, 11:23 AM
  #2051
smiley
smiley's Avatar
I think it was what you mention spark erode he was explaining he must've mentioned both ways the chemicals would be for cutting was a while back lol this is his company makes some pretty cool stuff
http://www.alloceans.co.uk
Old 24-04-2018, 11:25 AM
  #2052
smiley
smiley's Avatar
Hubs on the bench
They look awesome weres mine mark? Lol
Old 24-04-2018, 12:10 PM
  #2053
costina
costina's Avatar
plenty of videos on YouTube about broching etc.
smiley (24-04-2018)
Old 24-04-2018, 12:29 PM
  #2054
FLAT TRACK
FLAT TRACK's Avatar
hi
there not broached
Old 25-04-2018, 11:57 AM
  #2055
Caddyshack
Caddyshack's Avatar
New rear strut towers
You can just see the tiny boxes from<br/>Before, these did not leave any room for adjustment and probably were moving as the shell didn’t have much strength there before and the old cage only bolted in where the back seats would have been
Old 25-04-2018, 02:54 PM
  #2056
Caddyshack
Caddyshack's Avatar
5.7 kilos of weight saving across standard to normal flanges...(for the 4).that is a BIG saving in unsprung weight. Very happy
Old 25-04-2018, 02:59 PM
  #2057
Caddyshack
Caddyshack's Avatar
Should be around 8-10 kilos lighter than a normal rear beam plus no diff fitting kit.
Dummy supra diff in the T45 cradle, I have the supra billet diff cover to go on already
Clever little mod by Mark, (nice surprise today) easy to remove the diff using just two rear and two front bolts then unbolt the prop. We have been discussing a windowed diff cover.
Old 25-04-2018, 04:54 PM
  #2058
smiley
smiley's Avatar
Comming together now mate you must be happy
Old 25-04-2018, 05:02 PM
  #2059
Caddyshack
Caddyshack's Avatar
Very happy, just want it back and done ready to rebuild though
Old 10-05-2018, 12:41 PM
  #2060
Caddyshack
Caddyshack's Avatar
Floor should be welded in this week.
I have bought some FIA Carbon seats, about 7kg each, plus the seat bases. I think my old seats were about 35kg for both all plus the bases.
Still debating if I should add the Roller Barrel Individual Throttle bodies, Mark Shead and Mark Walker say that will really aid throttle response which is probably the worst part about Turbo cars in my opinion...even if the EFR makes a huge improvement over the old skool turbos.
Old 10-05-2018, 10:23 PM
  #2061
visa_broke
visa_broke's Avatar
Your in it this far you might as well continue
Caddyshack (11-05-2018)
Old 11-05-2018, 06:15 PM
  #2062
COLEYST200
COLEYST200's Avatar
Come on then toby you said the floor should be in this week we all love photos . It would be nice to see some updates on this as it all ready seams to be slowing up on the fabrications side . And I fort you said it was going to take about 3 months for the fab work to be done that clock must be ticking now .
Old 11-05-2018, 06:58 PM
  #2063
Caddyshack
Caddyshack's Avatar
Yes, Ian, I sent a very similar message to Mark earlier today, waiting for an update now. His press brake went very wrong but that has been replaced with a shiny c n c so should all be done now. I am itching to get it back.
Old 11-05-2018, 07:10 PM
  #2064
Mark V8
Mark V8's Avatar
Very cryptic Mark!
Can you index on the CNC lathe and broach them individually with a form tool ?
Old 14-05-2018, 10:08 AM
  #2065
COLEYST200
COLEYST200's Avatar
Well I hope it does get done asap . As you have backed up mark on every thing he has done . even stepping in to get a part to France
but deep down I think your going to be yet a nuther upset customer . We all love the end product that mark makes and no one can ever take that away from him . It's just the excuses leading up to getting it is the problem .
We all all look forward to seeing the update photos soon
Old 14-05-2018, 10:46 AM
  #2066
Caddyshack
Caddyshack's Avatar
Let's not let this go in to one of "those" threads. I keep adding to the spec so the timeline will have to shift a bit. We get on very well and we chat all the time.
Old 14-05-2018, 11:31 AM
  #2067
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
People on waiting for Mk to let him down end of the day you choose the person you want to do your work and you go with it. As long as it gets done so what if dead lines go over at the end of the day when it’s done the workmanship will be second to none. Cars having some serious work put into it
Caddyshack (14-05-2018)
Old 14-05-2018, 11:44 AM
  #2068
Caddyshack
Caddyshack's Avatar
Originally Posted by ajamesc
People are waiting for Mk to let him down end of the day you choose the person you want to do your work and you go with it. As long as it gets done so what if dead lines go over at the end of the day when it’s done the workmanship will be second to none. Cars having some serious work put into it
Yes, I have dealt with him many times before and it was an active choice to go to him. The car will be superb when it is done and "good food takes a while to cook"
Old 14-05-2018, 04:14 PM
  #2069
FLAT TRACK
FLAT TRACK's Avatar
shame toby
i think he just wants to mess your thread up ,instead of being interested in your build but its like you said jealousy
Old 14-05-2018, 04:19 PM
  #2070
FLAT TRACK
FLAT TRACK's Avatar
hi
i think its a very good answer and toby can defo stick up for himself ,we speak weekly and we both know whats happening .some people just want to throw a car together as quick as poss and for Ł12 lol then wonder why it breaks and packs up all the time .do it once take your time do it right your happier in the long run, it used to be a good forum but all the traders have gone ,i dont think it will be long before the forum is and people bothering making parts for cosworths which will be a shame
Old 14-05-2018, 05:04 PM
  #2071
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
hi
Ignore
Old 14-05-2018, 05:15 PM
  #2072
Caddyshack
Caddyshack's Avatar
shame toby
"Jealousy" was not aimed at Ian / coley, that was someone else. Ian is a mate and I know he is just concerned.
Old 14-05-2018, 05:33 PM
  #2073
Caddyshack
Caddyshack's Avatar
No arguing on this thread please.
Old 15-05-2018, 01:39 AM
  #2074
visa_broke
visa_broke's Avatar
when are you going to forget about this Toby and get back to the more important project, that nice red 944 of yours
I like both threads tbh, always a good read. I should hopefully in the next day or so have the starting parts of the engine swap for mine
Old 15-05-2018, 06:27 AM
  #2075
Caddyshack
Caddyshack's Avatar
We need to have a 944 build off race lol
Old 16-05-2018, 01:51 AM
  #2076
visa_broke
visa_broke's Avatar
I'm still waiting to hear about when I can pick up my one
Though I did just buy a custom sump/bell housing/mounts for an engine conversion tonight
Old 16-05-2018, 06:15 AM
  #2077
Caddyshack
Caddyshack's Avatar
What engine mate?
Old 16-05-2018, 08:20 AM
  #2078
800bhp
**RS COSWORTH**
800bhp's Avatar
What rear and front diff do you have fitted.
Old 16-05-2018, 09:42 AM
  #2079
Caddyshack
Caddyshack's Avatar
Hi, I have a quaife ATB 3.6 in the front with strengthening plate, plus I use the 2 support brackets to help support it on the block....bara said that the weak point is the crown wheel and pinion...if it breaks I will stick a 3.9 R&D in it and add drop gears to the oppliger box.
The rear is the Supra diff mounted directly in to the WRC (improved) lightweight T45 cradle. Supra diff is weir kitted with the MK cover and rebuilt by bara.
Bara checked my box and it was a bent selector fork on 4th making it pop out, he thinks it is the quick shift kit that bends 4th and recommened a different shifter OR trying some rubber bushes on the quick shift.
800bhp (16-05-2018)
Old 16-05-2018, 12:35 PM
  #2080
smiley
smiley's Avatar
Your front diff is good enough Jonathan gambles saph running over 700 runs one and he runs at at a pod alot
Quick Reply: Peugeot 205 with 4wd cosworth engine and running gear.
