Peugeot 205 with 4wd cosworth engine and running gear.
Old 10-01-2018, 04:48 PM
  #1721
markk
markk's Avatar
Originally Posted by ajamesc
If you have to make an input like that on the road chances are you have got it very very wrong somewhere and it’s not going to end well anyway lol
Not if you are coming in and out of a big sideways lol
(Not that i condone that on the road)
Old 10-01-2018, 04:56 PM
  #1722
c20tbo
c20tbo's Avatar
Is the new engine Steven Mackay's old unit from the fiesta?
Old 10-01-2018, 05:51 PM
  #1723
Caddyshack
Caddyshack's Avatar
Received 1,033 Likes on 945 Posts
Yes, it's not like the steering locks out, you just feel a lag of weight, the wheel and wheels still move, it is just a reduction in assistance.
Old 10-01-2018, 05:52 PM
  #1724
Caddyshack
Caddyshack's Avatar
I do not know the full origin of the engine as it is coming to me via MK, I will obviously check the background before it arrives.
I do not know how many strikers have been built, I bet there are not many
Old 10-01-2018, 05:56 PM
  #1725
Caddyshack
Caddyshack's Avatar
I have had the car sideways quite a few times, a couple of times it was just under power and hit a wet patch.
My dad made me get our 528i BMW e28 sideways in the wet all the time with L plates on when I was learning to drive...his theory was teach me to control a car when he was there to help me and teach me than let me learn after passing my test. We used to also take our 16 sport mk2 escort on to army land and get that very crossed up.
Old 10-01-2018, 07:31 PM
  #1726
Caddyshack
Caddyshack's Avatar
Proper WRC breather will do away with un sightly hoses-tanks in the bay, thats what i have, i had a funky breather twin tank made by spec r to replace my original PS tank on my escos for my rack and gearbox, im running corsa EPS
Im also on a 7670 efr internally gated unit with turbosmart actuator, so i could retain my oe heatshield (moddified a little for turbo positioning) MAD manifold Zircotec coated
MIS inlet on the cold site
I understand that the WRC breather may not be up to the stroker unit but I may have that the wrong way around. I don't like the breather on my car now as I sometimes get smells in the car even though I made sure the bulkhead was really well sealed.
I also have a mad exhaust although mine was made a little different I think to fit the 205 engine bay, I had it zircotec coated too.
Old 11-01-2018, 06:18 AM
  #1727
c20tbo
c20tbo's Avatar
If your sticking at around 600 then the WRC breather (proper made one) should cope no problem, i have my atmos line hose routed a good distance underneath, plenty people run them at that power with no issues
Also i presume your car is prodomently road used and not a track car, that would be the deciding point for me
Its far too easy to get caught up with all this fancy stuff that really isnt needed for what the car is intended for
Old 11-01-2018, 06:24 AM
  #1728
Caddyshack
Caddyshack's Avatar
Thanks, I will bearound 500 /520 initially as I will try the small turbo for mega response.
Old 11-01-2018, 01:54 PM
  #1729
FLAT TRACK
FLAT TRACK's Avatar
hi robert
all these parts that are not needed is that a mis plenum ,sequential gearbox ,trick dash etc lol
and its not the hp that dictates the breather a stroker moves a lot more air around plus its the rpm
mark
Old 11-01-2018, 02:11 PM
  #1730
c20tbo
c20tbo's Avatar
Originally Posted by FLAT TRACK
hi robert
mark
Personal preference on my parts Mark, as i was starting from scratch, see it time and time again and have been in that boat myself with all this WRC stuff etc it ended up ruining my project due to various reasons and something i would never do again as quite simply its not needed for road purposes, yes i have a few spunky parts on my Escort but i have drawn the line there with the car now and what it has now will be its final spec, the sequential box may even come out.......
This Pug is a great little car but i see it changing spec on a weekly basis
Old 11-01-2018, 03:22 PM
  #1731
Caddyshack
Caddyshack's Avatar
You are right about my spec changes, the problem as I see it with modified cars is that life is always a compromise. Manufacturers now spend millions of pounds developing cars to make them easy to live with. I want my Pug to be great to just jump in and drive all the time...at the moment I cannot as there are things that niggle me.
The shell is much smaller than a Sierra or Escos, not just shorter, it is much thinner so packaging is hard. for example the track width caused me a night mare, it was running huge camber (like over 2.5 degrees neg) just to get the front wheels tucked in the top of the arches, that was daft on a road car and after trying lots of different things I went with the WRC front to allow me to put the wheels where I wanted them.
The 6 degree beam improved the car massively but I would still like to tuck the wheels where I want them and as my coilover strut towards are basic to say the least and by doing a Cradle I can run front shox on the rear and have proper adjustment and get the track how I want it.
I expect my spec will move many more times yet.
The big engine is actually a cost effective way of avoiding a rebuild, my stock engine is pretty good but ideally I want head work, cams and long studs by the time I put some pistons in it and a crank it is easier to sell mine and buy the new one.
Old 11-01-2018, 03:52 PM
  #1732
Caddyshack
Caddyshack's Avatar
The reason I have gone elec power steering is to get me more space around the pulleys for better cooling as the fan was struggling in the very hot weather, I want to be able to sit in traffic jams without looking at the temp every 5 mins in full summer.
Also the biggest thing for me is having fun building it.
Old 11-01-2018, 04:22 PM
  #1733
Adam-M
Adam-M's Avatar
I suspect your gonna have some traction issues lol
Old 11-01-2018, 04:28 PM
  #1734
Caddyshack
Caddyshack's Avatar
Yes, that has already raised its head in the cold and wet weather. I have recently bought 8x16 comps to replace the 7x16 so that I can go from 195 tyres up to 215 and then swapped from Toyo proxes to Yokohama track day rubber in the hope that the sticky, softer tyres are better. (I have another set of 8 inch comps to try some tyres better suited for winter)
The 8's are really tight on the rear to fit under the arches and I am still trying to get the spring rates and geo where I want it before tackling the damping.
The 6 degree beam helped traction massively though.
Old 11-01-2018, 08:37 PM
  #1735
smiley
smiley's Avatar
A project car is sombodies personal vision of what they want to build and achieve its a journey i n my case a very long distance one lol will be epic mate i want a ride
Old 11-01-2018, 08:51 PM
  #1736
Caddyshack
Caddyshack's Avatar
Thanks, you totally get it and can have a go whenever you want
Old 11-01-2018, 09:09 PM
  #1737
smiley
smiley's Avatar
Likewise mate hopefully alot will start to happen this year
Old 11-01-2018, 09:33 PM
  #1738
jonfoc
jonfoc's Avatar
It'll need a bigger turbo!
Old 12-01-2018, 05:38 AM
  #1739
smiley
smiley's Avatar
Go pro's anasley bypass brother lol
Old 12-01-2018, 06:11 AM
  #1740
jonfoc
jonfoc's Avatar
I do like a bit of annasley bypass.
smiley (12-01-2018)
Old 12-01-2018, 03:10 PM
  #1741
Caddyshack
Caddyshack's Avatar
I think curiosity will make me go for the 7670, do not worry mate, if I do not lose much response I will want to know what Maclaren F1 power to weight ratio feels like.
Old 12-01-2018, 03:18 PM
  #1742
Caddyshack
Caddyshack's Avatar
I had a quick measure up today and if I cut 10mm out of the back of the lower part of the bumper and fill what is left with fibreglass to put the strength back I can shunt the intercooler 10mm forwards, I then can shave 10mm off the front pulley on the crank as no longer needed as have deleted the power steering hydraulic set up, I then need to cut a tiny bit of the front panel and can then fit the spec r top feed intercooler along with the much bigger rad that the 2.2 was run on with twin slim line fans (I think it is spec r too), this still leaves a gap for the air filter to sit right inside the front grille sucking fresh air.
Old 12-01-2018, 10:26 PM
  #1743
jonfoc
jonfoc's Avatar
Now that sounds like it's got all the right bits. When are you picking it up?
Old 13-01-2018, 08:14 AM
  #1744
Caddyshack
Caddyshack's Avatar
Not 100% sure yet. Mark is making me a big wing sump for it at the moment with all the connectors on it (the one that was on it has been liberated) he has found me a mint sump to start with too so I can keep my one on my engine for when I sell it.
Old 13-01-2018, 09:12 AM
  #1745
smiley
smiley's Avatar
Get some pictures up when you can
Old 13-01-2018, 01:34 PM
  #1746
Caddyshack
Caddyshack's Avatar
Will do, I plan to repaint the block and also weld up any holes in my engine bay that are not used and then have the engine bay painted as it was the only bit of the shell not done when I repainted it as the engine was in.
Old 13-01-2018, 01:40 PM
  #1747
smiley
smiley's Avatar
Old 14-01-2018, 11:31 AM
  #1748
Caddyshack
Caddyshack's Avatar
What’s your opinions on these wheels, personally I think I need to have the outlets made silver like the old fronts. These are Yokohama Road and track tyres, pretty sod 205/45/16 on 8 inch rims et28. I tried 215s but they were too big as the 45made the diameter too large. I prefer they way they look from the rear as the 195,s on 7 inch looked too skinny and the new engine is going to need all the rubber I can get.
New wheel and tyre side view
New wheel and tyre rear view
Old front wheel and tyre
Old rear 195
Old 14-01-2018, 11:34 AM
  #1749
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I think there look good in white but you would end up cleaning them all the time lol
I think no matter what you do your going to have traction issues if it’s not a hot sunny day on 888’s
Old 14-01-2018, 11:38 AM
  #1750
Caddyshack
Caddyshack's Avatar
Funnily enough I have a set of the same wheels in white, they are et25 so need Mark Walker to spin them up in his big lathe to take 3 mm off the mounting face but may drop them off when I pick up the engine.
I pretty much clean the car every time I drive it so don’t mind a lot of wheel cleaning
Old 14-01-2018, 11:43 AM
  #1751
ajamesc
ajamesc's Avatar
Yeah I like them I’d want it too look at tough as possible a bit group b looking after all it will certainly move like one
Old 14-01-2018, 11:44 AM
  #1752
ajamesc
ajamesc's Avatar
Th2’s
Old 14-01-2018, 11:46 AM
  #1753
Caddyshack
Caddyshack's Avatar
Cool.
I have been thinking of trying to get some carbon fibre dive plains for the front air dam, nothing over the top just a subtle nod to group b, plus still looking for a roof spoiler for it. I will speak to Dimma but I think it may not work with my kit. I have found one in carbo fibre but the side mounts look too Max power
Old 14-01-2018, 11:47 AM
  #1754
Caddyshack
Caddyshack's Avatar
Yeah I like the th2's, that is Terry Pankhursts car who owns Dimma, Mark Shead mapped it as it is a Mitsubishi Evo underneath, it is for sale for Ł38k at the moment.
The wing is a true group b rear wing off a t16, he had it for years and always wanted to build a car to put it on.
Old 14-01-2018, 11:57 AM
  #1755
Caddyshack
Caddyshack's Avatar
I am surprised being such a light car how well it does grip on the 195's, I think it is down to the 6 degree, lsd front and rear and the uprated v/c.....maybe lighter cars do not struggle as much as there is less inertia? If I hit a damp patch under full load in 2nd it will spin a bit but it is more like a torque steer which can be frightening. When the rear lets go on a bend it is quite controllable for such a short wheel base (22m shorter than a Sierra on the rear prop) but I think that is down to the softening of the suspension too.
It has 500ftlb now, it's gonna get 50 to 100 more plus 50 to 120 more bhp depending on the final turbo.
Old 14-01-2018, 12:47 PM
  #1756
Mark Shead
Mark Shead's Avatar
I didn’t map it in the end as Terry didn’t go ahead with the Emtron upgrade Mark
Old 14-01-2018, 12:55 PM
  #1757
Caddyshack
Caddyshack's Avatar
Oh, I thought he had it down at your place, sorry for the duff info. Love the car though and highly approve of the running gear in it
Old 14-01-2018, 01:38 PM
  #1758
Caddyshack
Caddyshack's Avatar
Just been out for a run, elec power steering feels good and car rides better on the softer springs.
Old 14-01-2018, 01:52 PM
  #1759
boost monster
boost monster's Avatar
Wheels look great but I prefer them in white
Caddyshack (14-01-2018)
Old 14-01-2018, 01:57 PM
  #1760
Caddyshack
Caddyshack's Avatar
Looks like I will be going white then
Quick Reply: Peugeot 205 with 4wd cosworth engine and running gear.
