Peugeot 205 with 4wd cosworth engine and running gear.
#361
I am tempted to still run the car to check the box is ok as I do not know if the syncros are ok or not and then get a new bellhousing made up.
What are your thoughts, will it greande the bellhousing straight away? The crack is between 2 webbing points.
#362
![](https://cimg4.ibsrv.net/gimg/passionford.com-vbulletin/2000x1504/arrgh_crack_9a5bea4684bb1b0ed6ed51165e7579bdcf41fec6.jpg)
Here you can see the crack under the bolt at the top of the bell housing....thoughts? I want to run the car to make sure everything else works but how long would this hold even with gentle use? 500ftlb is a lot of twist!
#363
![](https://cimg5.ibsrv.net/gimg/passionford.com-vbulletin/2000x1504/diff_cover_on_ca3cab397038a687647577af6d510cee77994481.jpg)
Atleast the diff cover looks good and should not break!
#364
![](https://cimg6.ibsrv.net/gimg/passionford.com-vbulletin/2000x1504/bay_painted_0415_b8620b6a9bb3ca30463e7dc1c13062497819e278.jpg)
I did a vry quick primer and repaint on the bay as was keen to get the engine back in, it can go to a body shop when the engine is rebuilt
#365
![](https://cimg2.ibsrv.net/gimg/passionford.com-vbulletin/2000x1504/bay_painted_2_0415_3711865716ba30b990ae1d496040c292ba6b5862.jpg)
#367
I am tempted to get a new bell housing done and swap it later, the engine out is only a couple of hours work.
I could repair this for now with jb weld like scooby slayer used on his truck engine.
I have found a close ratio kit in the states which gives a long first then tightly stacked 2nd and 3rd but retains the std 4th n 5th
#368
Hi mate as you no I bid reply to you today a bit slow as I'm on holiday in Crete and loving it . The more I think about it the more I'm hoping that this bellhousing was modded right as you no I did all my stuff my self so I had to check every thing I did . And Wots funny is it all bolted up ok befor all the clutch went in . I had to check all this out befor I started cutting the bell housings up as the skyline input shaft sticks out aprox 15mm and
A Cosworth one sticks out aprox 10mm all this has to be taken into acout when working out ware to cut and shut these gear boxes I just hope all this has been done right . As said I will ring you in the week when I'm home and see if we can sort this problem over the phone as if the input shaft is pushing hard against the crank shaft / clutch when the motor is started it could try and weld it self togever . We need to no 100% why the bellhousing cracked
#369
#370
You need this to repair your gearbox mate,
http://www.lasertools.co.uk/item.aspx?cat=0&item=4197
http://youtu.be/SwyglwkZcCU
Ł30 in machine mart
I was just in there queuing for the tills and was watching the demo on TV. It's exactly what you need to fix it.
Ł30 in machine mart
Caddyshack (29-04-2015)
#371
Ł30 in machine mart
Ł30 in machine mart
Big thanks also to coley as he called me today to add some advice.
I have bolted the bell housing up today and it does seem that just the top corner ear is out as all other bolts faces sit flat and as you do up that corner the crack opens so the plan is to drill the end of the cracks to stop the split, bolt it all up tight with the crack open and fill the crack with a repair, then unbolt and reinforce from below, I will drill the crack a little in other places to let the repair fill the crack.
If this works as even a temporary measure then I can check the car runs fine on the new shafts, that the syncros are ok and the ets pro etc works, then mot the car and see if the box breaks....if it does then I will have to pay someone to make me a new bell housing whilst I get Bara to fit a close ratio 1st to 3rd kit n new syncros.
Thanks all, could not have carried on without the forum helpers!
#372
I hope it works for you mate.
It looks really promising in the video.
Is it weird that while I was watching the vid in the shop I was thinking I need to post it on here for you lol.
I did it in the car park before leaving so I didn't forget lol.
#373
I was just telling my wife that you had been really thoughtful...forums are great like this, instead of people arguing!
Caddyshack (30-04-2015)
#375
Thank You, it looks like there are a lot of modern solutions now. I was looking on an electric bike forum and it seems the Americans are glueing bike frames together etc with good results.
#376
I have just had a PM with a very kind offer from a well known trader on here to weld it up for FREE, top man and Thank you for the PM.
#377
cossie fan (unluckerly)
Far better to get it welded! At a guess you would have said something must have been bound up or very slightly out for it to have split as you did the bolt up. If you glued or bonded it it would just brake in the same way. Very kind offer for someone to weld it up for you
#378
if you weld it you can add strengthening webbs at the same time. but as said, you need to see whats put the strain on that bit of housing. it really should be able to take its weight, i think id recheck alignment and supports
#379
HI
I think what has happened is ,toby said the guy he bought it off had it rewelded or something and I bet they never skimmed the face after welding ,which would have probably warped it ,so it was just a case of uneven surface trying to clamp to flat race of block
mark
mark
#380
HI
mark
mark
Mark (MK) and I are working on a plan
![smiley_abuv.gif](https://passionford.com/forum/images/smilies/smiley_abuv.gif)
If it does not fail spectacularly then the new box can be ready for the engine rebuild at the same time which allows me to save up as this thing has been drinking money recently....in fact since I bought it.
#381
The box and engine are back together now, I used the ally repair weld stuff, it is very much like solder but you have to heat the metal for ages and get it really clean, I dremmeled a v in the crack and drilled right through in a few places, I welded it up from the inside and it looks pretty good, all bolted up fine, went on realy well.
I will refit the engine and box tomorrow and run it up.
#384
Mark
#386
I have filled up the transmission with heavy weight shock proof and filled the transfer with atf fluid and started to belled the clutch and attesa pump.
I think the boost pipes will need some work due to the new hart inlet.
Front prop is in and rear will be in this afternoon, then oil change for the engine and reconnect all the wires.
When Mark mapped the car he found that the water expansion tank didn't have a pressure release, it popped the expansion tank....I have now noticed that my expensive high flow alloy pug rad is an oval shape so it must have really built up the pressure with nowhere to go. Just in case I am going to get the waterless flush and waterless coolant as that doesn't expand at all and have a new header tank made with pressure release valve. It would be nice to get a new intercooler in there soon.
#391
Yes, thank God. I think I will get another bell housing done as a precaution and might then take it to a company to see what cost to cast some using the new one as a guide. Billet would be great but a waste of material I guess?
#392
Nice mate cracking on with it
are you gonna run it or go for new build? Nice 200 block on bay studded
#393
The 200 block would need to be very cheap for me to buy it right now and just store it.
Caddyshack (04-05-2015)
#395
Mark
#396
Ah learn somthing everyday
which size is correct mark?
#397
#398
Ok cheers mark
![](https://passionford.com/forum/images/smilies/roi.gif)
#399
Well my custom made exhaust was done when it had an mt75 box and 4x4 rear diff, it touched the supra diff on a corner, the mk mounting kit and one small part on the gearbox but after some heat and a persuading stick I managed to massage the exhaust and ground a small bit off each part. Now it fits better than it did originally...I even managed to polish up the rear box...will post pics soon.
#400
![](https://cimg0.ibsrv.net/gimg/passionford.com-vbulletin/2000x1504/img_0146_c00565a76fbf96e42644145db3e95d8f06689c95.jpg)
Rear box made as a replica of the original T16, it is upside down in the pic so the exit is actually on the passenger side of the car.
