is 360bhp safe on a std cossie fuel pump??
had my saff rollin roaded and hesaid the pump was on its limit at 20psi on greens,would the sweedish style manifold cause it to do this or would you recomend to check wiring it peaks at 20 and holds 19 347 bhp but only 320 lb of torque.even thought of running 2 std pumps as i,ve allready got them
Norris Motorsport
Basky more than likely wiring, check working voltage at pump I bet you will be suprised!!!
On my own car I run 4 gauge cable direct from battery to boot, where it goes through two relays and a pair of 8 gauge cables to power my two 044 pumps. Over kill it may seem but what price do you put on reliability!!
just finding my feet
so the price on reliabilty is 500 quid
ive just got a 044 a while ago and am gonna be uprating the wiring,,,,, wondering if a power cap is a idea for em too or is that REALLY over kill
i dont mean 1 farad to btw , just enough to allow there to me a constant and regular voltage,,,,,,, and so it looks pretty
[quote="Karl"]Basky more than likely wiring, check working voltage at pump I bet you will be suprised!!!
On my own car I run 4 gauge cable direct from battery to boot, where it goes through two relays and a pair of 8 gauge cables to power my two 044 pumps. Over kill it may seem but what price do you put on reliability!![/quote
will be runnin relays on pump shortly as its only a track toy
been told to run it of the altonator is that right or will the relays be better
wots the working voltage please!!!
Norris Motorsport
B19 bal you do talk some shite!
A power cap is used on car audio systems to allow for excessive current draw for the amps during heavy bass from large subs.
A bosch 044 fuel pump on the other hand draws a pretty constant current under load so some sort of cap is totally unecessary?
Where do you get these weird ideas from?
i never ment a actual audio cap,,,,,, just a form of a voltage regulator to keep the power consistant so the pump dont actually worry about surges ect
its just a thought of other ideas,,,,,,,,,, its no different to the comment about having 17 fuel pumps for reliabilty
remember im just looking into ideas and what potentially can cause a problem,,,,,,,,, i dont need more flow rate at all,,,,,,, but im sure a genuine voltage is a good thing surly
so i dont get the talking shite,,,,,, or is it the tuners job to think of all other ideas,,,,,,,, ocasionally some people from out of the tuning game have ideas that can work im sure
no need to belittle,,,,,, im far from a hater and so a comment like that makes me wonder what kind of a person YOU actually are
a simple " that would be pointless as the fuel pump dont draw 1 normal current but is actually varied so it wont work" might have been better
or just explaining where im looking wrong at it would have been nice
seriously some people FORGET they used to be mere mortals who was learning about engines,,,,,, they all seem to find where they are and then act like they was born with a gift and never actually learned it by asking silly questions
being told stuff aint how you learn but looking into ideas IS the best way to learn i tend to find
cheers for the nice comment though
Norris Motorsport
Ginge you give you fair quota of shit to everyone including me. Im just getting you back for taking the piss out of my looks. (i.e. I look young)
Now pop yer dummy back in and calm down.
I did as suggested.
I used the original pump feed as the trigger for the relay, and then used 8 gauge cable off the mid-mounted battery to the relay, and then 8 gauge power and earths off the pump.
on a serious note i dont give shit to people i have a good natured pisstake that i honestly dont have a issue when its done back at me
just like everyone calls me ginge,,,,,,,, im cool with that BUT when a dick calls me ginge as a insult i take offence,,,,,,,,, even though its the same word its the contex its taken
back on the fuel pump i was genuinly thinking that a proper regulated ecu and fuel pump voltage would be a good idea,,,,,,, otherwise if the alt was failing or the bat aint too hot wouldnt there be a voltage drop that could make the ignition/fueling drop or not be acurate like it should
that was my thoughts on the matter,,,,,, again its just a thought so i could be talking shite
and my dummy aint spat,,,,,, just mentioning what i was thinking
btw when you see mr patell ask him if he can cancel april 17th for me as i think im going away so wont need the beano that week
Norris Motorsport
Ginge, just use some nice aeroquip lines and fitting, a swirl pot, lift pumps, 2X044s etc mount it all in the spare wheel well and top it off with an nice clear acylic lid and circular pink neon. That will look bling!!!
Originally Posted by Itsmeagain
If i bought a s/h cossie pump and did some decent wiring etc etc, how likely is it to work ok for about 340bhp?
surely theres not way to know that
have thought of 2 pumps though but its not really over kill,,,,,, more pointless on my car
DEYTUKURJERBS
Football Cwazy
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
