Zetec Turbo exhaust smoke!!!!!!
Old 23-04-2005, 05:54 PM
tonyturbo
tonyturbo's Avatar
Default Zetec Turbo exhaust smoke!!!!!!
ever since the turbo'd zetec engine has been built it has always been quite smokey! I put this down to the turbo as it was a second hand t3 i got for cheap. today i replaced it with a t34 (new) and it still smokes like a bitch. now what else could it be?
breather?
valve stem oil seals?
on an escort cossie bailey oil breather what is all the pipes for?
2 on top obviously go to engine but underneath there is a small 1 and a large 1.
i take it 1 of them is a return to the sump but which 1????????????????????
Old 23-04-2005, 07:39 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
sounds like valve stem seals mate
Old 23-04-2005, 09:35 PM
tonyturbo
tonyturbo's Avatar
the engine is a fresh build! is anything worth checking before i rip it to bits??????
Old 23-04-2005, 10:17 PM
©hatter Box
©hatter Box's Avatar
make sure ur breather vents to air ok if not it will make ur ar smoke
Old 23-04-2005, 11:07 PM
Rippers
Monte Geek
Rippers's Avatar
My Fiesta's ZT smoked like a bitch when I first got it..
Solved it by first sorting a proper Bailey Cossie breather, 2nd its seemed to prefer the oil level to be just above the minium, no idea why?? but it worked
After that it was always fine
Old 23-04-2005, 11:49 PM
mattbibs
mattbibs's Avatar
after fitting a new turbo to mine it smoked for a while until it was settled in. was fine then until the engine blew!
Old 23-04-2005, 11:57 PM
wildheart
wildheart's Avatar
And when did you own a ZT
Old 23-04-2005, 11:59 PM
mattbibs
mattbibs's Avatar
engines an engine isnt it?!
Old 24-04-2005, 12:01 AM
wildheart
wildheart's Avatar
NO
Old 24-04-2005, 06:30 AM
tonyturbo
tonyturbo's Avatar
what are the 2 pipes on the underside of a bailey oil breather for?
i take it 1 goes to atmosphere and 1 goes to the sump is the small 1, the 1 that goes to atmosphere cos right now its going to the sump!!!!!!!!!!!!!!!!!!!!!
Old 30-04-2005, 12:45 PM
tonyturbo
tonyturbo's Avatar
problem solved. cheers Alex. you were correct. took pipe off underside of breather and no smoke. couldnt believe it. well chuffed.
i bought a new t34 first tho cos i thought it was the seals in the turbo at first. never mind. laggy as fook though.
Old 30-04-2005, 04:20 PM
jaypen
jaypen's Avatar
my 16v zetec turbo FRST use to smoke like a bitch,blocked off breather outlet i had installed in back of the block,then just left it to breathe off rocker cover,catch tank,atmosphere,....problem solved
heard loads of people say them do smoke if you over fill with oil or if it is right on the max
T34 how to blow best part of £800???????
glad you got it sorted
robnock
21
13-05-2019 05:29 PM
robnock
22-08-2015 10:51 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Zetec Turbo exhaust smoke!!!!!!
