f.a.o Cossie owners on coilovers
Old 28-04-2005, 07:44 PM
SPADGE
SPADGE's Avatar
Default f.a.o Cossie owners on coilovers
Just out of interest what settings do you use for general use for both front and back? Also what springs are you using??
Cheers Spadge...
Old 28-04-2005, 07:48 PM
Niall.b
Niall.b's Avatar
Got ledas all round, dampers wound off as far as possible. Front springs 350 lb and rears 225 for the road.
Old 28-04-2005, 07:50 PM
SPADGE
SPADGE's Avatar
Cheers Niall
I should have also asked in the original question if you are running 2wd or 4wd?
Old 28-04-2005, 07:53 PM
Niall.b
Niall.b's Avatar
3 door Spadge. find this setup much better than the konis i removed. much tighter on the road. though rose joints & compression struts with alloy top mounts help yoo
Old 28-04-2005, 08:00 PM
SPADGE
SPADGE's Avatar
Thanks again Niall
All i am trying to do is to find out what set-up is the most popular for the road/track in general. I only have avo's on this saff atm as its not worthy of anything else
Old 28-04-2005, 08:50 PM
ESCYSCOTT
ESCYSCOTT's Avatar
i've got Gaz on mine and run 325lb front on half hard setting and 225lb rears on full soft setting and they are mint
Old 28-04-2005, 10:14 PM
GUZZLER
GUZZLER's Avatar
not really bothered with the 3 door yet,,, but on the 4x4 (avo's) i left them in the middle untill they bed in, then started to tinker...........
after trying loads of differant combo's, i left the fronts a couple of clicks
soft of the middle, & the rears a few clicks hard of the middle.
it drives nice like that & because the back is a bit harder (& slightly higher than the front) it stops it from 'diving' as much.
Old 29-04-2005, 04:36 AM
Ian3dr
Ian3dr's Avatar
As per Scott mate, medium on front, full soft on rear.
Old 29-04-2005, 05:58 AM
Niall.b
Niall.b's Avatar
will start tweaking mine then
Old 29-04-2005, 06:05 AM
alan rainbow
alan rainbow's Avatar
got gaz on mine mate 350 's front and 250's back found the back abit to hard for general use and fitted 180's alot better now front is on about middel setting and rear is just above soft
Old 29-04-2005, 07:03 AM
Eagle
Super Moderator
PassionFord Gold Member (Male)
Super Moderator
Eagle's Avatar
leda's on mine .. think 350 front and 250 rear ... would like to try a bit harder front as i think on track it wallows a bit .. normally have em 2 clicks on front and 3 on rear for road but 12 front and 10 rear on track
Old 29-04-2005, 07:45 AM
Jim Galbally
Jim Galbally's Avatar
gaz coilovers:
325 front - full soft
150 rear - full soft
bounces a bit after a bump, takes a while to settle, and still feel every bump somewhat, still infinately better than it was with the 225 rears
as for handling, it is still fairly wallowy, but then i like mine comfy and dont care about a bit of bodyroll
Old 29-04-2005, 10:32 AM
CozzyBrom
CozzyBrom's Avatar
track use
fronts
500/200 billys with 9 inch 550 lb spring
rears 300/120 10 inch spring 320 lb
may need to go less on the rear when its on track cuz of my wrc rear pick ups totally diffent
good road settings we found
250 on rear 370 fronts
a little hard but stop the wallow and back wheel lifting on hard bends
Old 29-04-2005, 10:38 AM
SPADGE
SPADGE's Avatar
Thanks fellas i'll have a meddle and see if i can get it to my liking
Old 29-04-2005, 11:34 AM
Ryan
Ryan's Avatar
Brom you got any 12" or 16" springs lying about.
looking for around 400lbs 12"
and around 250lbs 16"
For Road\Track
Using 500\200 Fronts
Using 260\90 Rears
Old 30-04-2005, 01:38 PM
CozzyBrom
CozzyBrom's Avatar
yes should have we got loads n loads of sprigs
Old 30-04-2005, 02:18 PM
Ryan
Ryan's Avatar
Could you PM me a price please buddy when you got time and along with those bilstein bits and bobs i was talkign about
Want to get my struts finished so i can get the shell rolling when it comes back from being sprayed
Old 30-04-2005, 04:33 PM
Neil
Neil's Avatar
rwd xr4i dohc turbo
running 400lb 9 inch front springs set to 1/3 hard
running 325lb 10.5 inch rear springs set to 1/3 hard
A.t.p
29-09-2015 05:04 PM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
Russ Payne
25-09-2015 08:29 PM
IainRS1700T
25-09-2015 06:44 AM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: f.a.o Cossie owners on coilovers
