Water wetter,work?
Water wetter,work?
I've used water wetter in the past. Usually on cars that seem to have issues with cooling in common.
I have never actually tested to see if 'it does what it says on the tin'. I have, However, never had a cooling issue when it's been in! That could be coincidence though.
So does it actually work?
I believe it does but you should always make sure the cooling system works in the first place.
I have just gone over to Evans waterless where you flush the engine with a prep fluid then refil but you cannot use any water for that. I runs a little hotter at normal but does not increase and does not pressurise.
Sinbad (16-12-2015)
I'm sorting the know issues out on my current car, including stripping all the coolant related items out and properly cleaning the old crap out. New water pump, stat etc. I just like a bit more peace of mind as they're renound for overheating. Capri 2.8i.
I ran it in a computer water cooling setup in the early 2000's
from memory, it dropped water temps 4-5 degrees at 30-40 degree temps so i can confirm it does what it says on the tin, and this is running a system that I benchmarked without, and put it in the loop whilst still running and benchmarked
That looks mint lee mate. I have been on the look out for a wee project as well.
Get more pics up when you can bud. If your ever selling let me know.
cossie09
23-12-2015 04:04 PM
Mark V8
Wheels and Tyres
31
22-12-2015 09:44 PM
