Problem starting Fiat Punto.
Old 28-03-2014 | 06:04 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Default Problem starting Fiat Punto.
My friend has got a 07 Fiat Punto, not sure of the model but I think it's just a 1.2 litre or something like that. The problem she has is when she tries to start it it just makes a horrible whining sort of noise. The only thing I can compare it to is the noise you get if you try to start your car when it is already started. She says she has had the starter motor changed and also the ring gear but it still does it. Sometimes it will do it 3 or 4 times and then it will start, other times it will start ok 1st time. Any suggestions what she can try looking at next without it costing her a fortune?
Cheers peeps.
Old 28-03-2014 | 07:36 PM
When did she have the starter changed last. The starters are really common for nacking up.
Old 28-03-2014 | 08:10 PM
STAFFY OWNER
Not sure Glenn, I'll find out.
Old 28-03-2014 | 11:00 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Could be wrong starter and only just catching the edge of the ring gear, also check to make sure the dowel is there as the starter could be slightly off
Old 29-03-2014 | 10:24 AM
STAFFY OWNER
The starter was changed last October Glenn.
Old 29-03-2014 | 03:44 PM
STAFFY OWNER
Come on all you mechanics, any other suggestions?
Old 29-03-2014 | 03:47 PM
Carlos-Titx's Avatar
Carlos-Titx
I'm no mechanic but it being a Fiat is the main problem.
Old 29-03-2014 | 03:50 PM
andrewmctiernan's Avatar
andrewmctiernan
starter motor, whack it hard as it may be stuck
Old 29-03-2014 | 04:12 PM
gingerturbo
Oh fuck I forgot common problem, I've done loads check the earth strap that goes from the battery to the body then to the starter, that will be your problem 100% I would put a beer on it
Old 29-03-2014 | 04:24 PM
gingerturbo
Also check to make sure the plastic clip that seperated the main live feed and the trigger is ok and that the spring washer is not corroded
Old 29-03-2014 | 04:34 PM
GVK.'s Avatar
GVK.
Common fault on Puntos etc!
Old 29-03-2014 | 08:12 PM
STAFFY OWNER
Cheers mate. Would that cause it to make the horrible noise that it makes when it fails to start?
Old 29-03-2014 | 08:35 PM
gingerturbo
It would if all its doing it spinning the starter and not throwing it out
Old 29-03-2014 | 08:39 PM
STAFFY OWNER
That's excellent mate, thanks again, hopefully you've been a great help.
Old 29-03-2014 | 08:58 PM
gingerturbo
No worries good luck hope you sort it
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
muffster
13
03-09-2015 09:40 PM
nick8saff
16-08-2015 05:35 PM
Sjieter
05-08-2015 09:47 PM
Quick Reply: Problem starting Fiat Punto.
