Info required Exhaust tailpipe manufacturing
Live long and prosper!!
I'm still after a 3" rolled out stainless tail pipe.
12" long
As every one on ebay etc are 8" so I'm after a Manufacturer of these parts to contact direct as I don't want a 8" with a bit welded on.
Tried most of the exhaust fabrication places but again I can weld u a bit on sir. Even tried mongoose BUT they didn't want to help even thru one of there suppliers.
Any info would be great thanks.
Paul
12" long
Paul
Really need the company that actually manufactures the mongoose exhausts. They also manufactured a exhaust for woodford garage motorsport but Sue bless her got her knickers in a twist about it so that was the end of that.
All I want is a tailpipe how hard can it be?
I have steve and yes the weld option is there as said by many exhaust fabricators.
just only wanted the one weld to the back box.
Just being fussy I guess don't want the 4" slash cut on it anymore
There would be only one weld on the back box...the other would be 4" away lol
Just grind the weld down with a flap wheel and it would become invisible anyway
Maybe try Simpson Race Exhausts, OJZ Engineering, Chris Tullet ?
Or maybe if you contact Mongoose they can supply you with something
Thanks for you input
Hi , I wanted a straight cut 3inch tailpipe instead of the 4inch rolled so I had the rolled 4inch pipe cut off at the original weld at the backbox and a 3inch pipe section to correct length welded on so no additional welds.
Maybe an idea.
Cheers. Tim
Maybe an idea.
Cheers. Tim
Thanks guys think my first port of call will be blueflame as this system was I think made by them and the tailpipe I require they should be able to sell me one (hopefully)
Then I can get the boys at work to tig it on for me.
The only other costly solution is to buy a mongoose back box and have a mounting flange welded on to match my system.
surely any local metal engineer/fabricators ,rather than exhaust fabricators, should be able to make you that up ? an exhaust specific manufacturer will probably only use off the shelf stuff they buy in rather than making the tailpipes themselves? don't need to complicate matters by telling them what it is, just give them a drawing with dimensions and finish and they'll make anything you want.
surely any local metal fabricators ,rather than exhaust fabricators, should be able to make you that up ? an exhaust specific manufacturer will probably only use off the shelf stuff they buy in rather than making the tailpipes themselves? don't need to complicate matters by telling them what it is, just give them a drawing with dimensions and finish and they'll make anything you want.
True fuzzy but most hav'nt got the tooling to do a rolled end. Ive plenty of 3" stainless I could use too
Have you tried piper paul?
When i was down there some years back they made a system onsite for my old puma.
But i suspect they buy in the tail pipes so you may still not have a resolution.
Or simpson etc?
Or simpson etc?
Indyrs
04-12-2022 12:39 PM
TPM961
15-01-2018 10:50 AM
Si B
12-09-2015 06:49 AM
CrOwSoN15
10-09-2015 07:33 PM
