Boost controllers
Old Nov 15, 2013 | 11:36 PM
BRAMMER's Avatar
BRAMMER
Default Boost controllers
Whats good for the money that works? is it better to go for something like HKS, Greedy, Blitz etc as well used on Jap cars
Old Nov 16, 2013 | 06:47 AM
bigluke200's Avatar
bigluke200
I can recommend Apexi AVC-R -Had one on my 200sx.. Fantastic bit of kit that controls boost very well with lots of useable features.
That was 10 years ago though so not sure if there is a modern version?
Also had a Gizzmo boost controller on the 3dr... Was ok but not a patch on the Apexi.. It really is a case of you get what you pay for
Old Nov 16, 2013 | 06:49 AM
bigluke200's Avatar
bigluke200
Yep they still do it...
Have a look through the features!
http://www.apexi-usa.com/store/elect...ler-black.html
There's loads on eBay.
Old Nov 16, 2013 | 07:02 AM
sierrafun's Avatar
sierrafun
i agree apexi the best
Old Nov 16, 2013 | 07:04 AM
sierrafun's Avatar
sierrafun
greedy very expensive and huge size.not need
Old Nov 16, 2013 | 11:39 AM
davidfox280585's Avatar
davidfox280585
turbosmart gauge built in one msd sell them there awesome
Old Nov 16, 2013 | 12:49 PM
Mark Shead's Avatar
Mark Shead
Let the ecu do it.
Mark
Old Nov 16, 2013 | 01:22 PM
Canada1's Avatar
Canada1
Agree with mark,
Most modern (made in the last 10 years) management systems will allow boost control.
Some of these electronic boost controllers almost cost as much as a stand alone management.
Old Nov 16, 2013 | 01:26 PM
sierrafun's Avatar
sierrafun
i have manual with 30 pounds so far no problems
Old Nov 16, 2013 | 03:40 PM
bigluke200's Avatar
bigluke200
Originally Posted by Mark Shead
Let the ecu do it.
Mark
Originally Posted by Canada1
Agree with mark,
This is what I have in place now
Although Brammer is on L8 hence why he is asking I guess..
You binning the air injectors Chris?
Old Nov 16, 2013 | 04:26 PM
J1mbo's Avatar
J1mbo
B1mbo
Air injectors controlled with ecu
Old Nov 16, 2013 | 04:43 PM
jaiscossie's Avatar
jaiscossie
Have been looking at getting a boost controller for my evo 8 and after doing a bit of reading it seems your better going for 3 port boost solenoid and letting the ecu control the boost. So if it's anything like the evo then more than likely the same.
Old Nov 16, 2013 | 05:22 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
so what ecus can control boost?
i take it you buy the airinjecotor setup and then send it all off for mapping?
Old Nov 16, 2013 | 05:32 PM
grant_xr's Avatar
grant_xr
I may be selling my turbosmart eboost street boost controller shortly. Was bought from MSD and only covered 3k miles.
I'm now going with OFAM management so will be controlling boost via the ECU.
I will be keeping the boost solenoid, so all you would need is a new boost solenoid and you would have a complete kit mate.
Let me know if you are interested.
If you look up MSD's site you can see the spec, pretty sure James runs the same in his new Cossie!
Grant
Old Nov 16, 2013 | 05:56 PM
stevieturbo's Avatar
stevieturbo
C**t
Any decent ecu can control boost....although boost control on all ecu's is most certainly not the same.
More importantly, what exactly do you need the controller to do for you ?
Old Nov 16, 2013 | 07:30 PM
scoooby slayer's Avatar
scoooby slayer
I had air injectors on my old t4 saph at 33 psi boost. a plug got knocked off one of the injectors and I was running 40 psi of boost !
that is the reason I don't like air injectors, if my greddy controller fails it just sits at wastegate pressure.
the best ive had so far is an apexi one in my first r32 that was awesome.
Old Nov 16, 2013 | 07:44 PM
stevieturbo
C**t
Wasnt there any overboost protection in place ?
Old Nov 16, 2013 | 08:04 PM
scoooby slayer
I don't think so mate.
it was just set up to run 33 psi in the ecu I had no control over it myself.
I seem to remember they work opposite so when they fail there is no connection to the wastegate at all and its just held shut constant hence I ran 40 psi of boost for a bit until I noticed.
Old Nov 16, 2013 | 08:12 PM
stevieturbo
C**t
Yea, but when running a boost control setup like that, it's even more important for the ecu to have overboost protection.
If it doesnt then it's madness.
I can see little sense in a boost control setup, where the fail scenario results in huge boost, and no means of preventing it or shutting down to ensure engine safety.
Old Nov 16, 2013 | 08:45 PM
scoooby slayer
I have no idea mate it was a while ago, it was only on a 3 bar map but running 2.2 bar with the 2 bar pegged for fuelling at 2.2 bar, I assume because of that it couldn't cut boost as map sensor was flat out and it cant cut what it cant see.
Old Nov 16, 2013 | 08:54 PM
James @ M Developments.'s Avatar
If it runs over 2 bar of boost on.a 3 bar map sensor then the ecu cannot see the boost over 2 bar to use any form of protection.
All the ecu knows is that it's at it maximum.
Aftermarket ecus have the required scaling and break points to use a 5 bsr sensor which is far more ideal, but the webers are not very nice on the 5 bar map sensor.
I use the turbosmart controllers quite a lot and as long as they are mapped on them they work very well and do have over boost protection built In.
Old Nov 16, 2013 | 08:57 PM
scoooby slayer
that's exactly what I said but you worded it much better
Old Nov 16, 2013 | 09:23 PM
stevieturbo
C**t
If there can be no overboost protection in place, then it's quite inappropriate to be running it that way. Especially considering it's using a boost control setup where high boost is the default scenario.
Old Nov 16, 2013 | 09:27 PM
It's not always the default.
By choice on big power stuff I would use an external waste gate with a soft spring using the air injector to pump air onto the gate to keep it closed. This way if the injector fails it returns to spring pressure, which is soft.
It's one of the reasons I used an aftermarket controller, but in my scenario I will run the turbo flat out so I wouldn't notice if the gate stayed shut anyway
so in the smaller turbo aplications they are run near flat out anyway so the fuelling is generally safe without boost control at high rpm as we are demanding the gate is closed up there anyway
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
