Cars and stupid designs.
Old 22-12-2013, 08:47 PM
  #161
Received 1,044 Likes on 998 Posts
Originally Posted by dojj
what a fuckig palava
It looked like a newish car to me cause there isnt any rusty bolts.
Old 22-12-2013, 09:27 PM
  #162
studabear
studabear's Avatar
they are a total nightmare, on the 2 I've had grief with, both were 1997 audi A4's I had to take the entire leg/hub etc off so I could get it all in a vice and smash the seized in bolts out using a firking great big hammer.
If the top suspension arms are getting renewed a good dose of heat may help get the bolts out.
Old 22-12-2013, 09:31 PM
  #163
richard youll
richard youll's Avatar
W12 Audi a8 ecu coolant temp sensor 20hr job , I accepted the challenge as is was some famous football managers car, I pissed it in just under 2 hours and had already done the deal of taking the job on for a grand as Audi Preston wanted 3k for doing it, I'll happily do them all day long , and I didn't bodge it or break anything 100% job done proper!!
Old 22-12-2013, 09:34 PM
  #164
studabear
studabear's Avatar
I would offer to do them for Preston Audi.
Old 22-12-2013, 09:41 PM
  #165
richard youll
Already have !
Old 22-12-2013, 09:42 PM
  #166
What do you have to do to chance the cts.
Old 22-12-2013, 09:44 PM
  #167
I remember replacing a front spring on my mates passat years ago and this had the same suspension set up as this. Them top arms were a nightmare to get out. Im sure I struggled to get the top arm back bolts out. It was about 6 years ago when I did it so my memory isn't the best.
Old 22-12-2013, 09:50 PM
  #168
richard youll
Car is designed around the engine right as fuck supposed to drop engine box suspension etc but you don't need to!
Old 22-12-2013, 09:51 PM
  #169
rhinopower
rhinopower's Avatar
Where is the sensor actually located then?
Old 22-12-2013, 09:57 PM
  #170
richard youll
At the very back of the engine on the passenger side bank behind the head in a water pipe
Old 22-12-2013, 10:20 PM
  #171
s1cosse
S1cosse
s1cosse's Avatar
you can get away with doing them in place with gear box off you get quite alot of room thank god
Old 23-12-2013, 07:26 AM
  #172
Take the gear box off to change a cts...what a carry on ha ha.
Old 23-12-2013, 09:40 AM
  #173
mark m
mark m's Avatar
Originally Posted by Thrush
Same mk5 golf - to change the door glass, you have to take the OUTSIDE of the door off. Not the door card as per nearly every other car out there, the outside panel. Which means door lock, handle, and everything comes off.
Well, that's if you want to do it properly anyway....
Porsche Cayanne/VW Toureg is the same too.
Stupid cunts
easyest job in the world on these door skins comeoff in less tahn 2 minits rather than messing around with stuborn door cases i used to love the idea but heard they scraped it as in cold countrys the skins ere debonding from the brackets
Old 23-12-2013, 07:39 PM
  #174
richard youll
If this is in reply to the w12 job you don't need to take box out either!
Old 23-12-2013, 09:56 PM
  #175
jamie's
jamie's's Avatar
i'm thinking it was the timing chain he's talking about
Old 23-12-2013, 10:01 PM
  #176
Mark_
Mark_'s Avatar
I heard the rear bumper needs removing on bmw 630's to change the reverse light bulb.
Old 24-12-2013, 12:15 AM
  #177
The Youth.
The Youth.'s Avatar
just watched that and you right what a fuck on!!
steve
Shows & Track Days
26-08-2015 05:11 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
Bobby9779
11-08-2015 06:47 PM
Quick Reply: Cars and stupid designs.
