Cars and stupid designs.
Received 1,044 Likes
A lad at work has just bought a mk5 golf gti edition
30. He said to me guess how much it is to change the high level brake light on the golf. I thought it was gonna be about 40 quid at the most. He said the dealers want 350 quid to change it cause you have to smash the spoiler off to get to the screw that hold the light in.
What a shit idea.Why couldnt they put some screws on the outside.He said you can just smash the light lense and change it that way and sylicone the lense in.
Same mk5 golf - to change the door glass, you have to take the OUTSIDE of the door off. Not the door card as per nearly every other car out there, the outside panel. Which means door lock, handle, and everything comes off.
Well, that's if you want to do it properly anyway....
Porsche Cayanne/VW Toureg is the same too.
Stupid cunts
Stupid cunts
Stupid cunts
Stupid cunts
Worst bit about this design is there are a row of torx headed bolts along the front edge of door skin and the bottom edge to attach it to the door, the screws are very similar...
BUT if you put the bottom edge screws in the front edge, they are slightly longer and will dent the door skin.
Luckily I was warned about this before I took one off!
big floppy donkey dick
taking late Golf door skins off is a brilliant idea, takes less than 2 minutes realtime and access the whole innards with no fuss,
putting the screws in the wrong place is just bad workmanship, simple as that.
i do prefer old skool sometimes but late golfs are piss easy campared to that.
(i dont own one and never will! golf wise as they are gay wheel drive)
Changing the battery on a diesel B5 passat is also ridiculously overly complicated.
The batteries are so big to do it properly it's wipers off and plastic scuttle off. The scuttle has to be prized off slowly or is easily snapped if you're not careful.
Also changing the main beam bulb means removing the headlights unless you have alien like fingers!
Edit - actually 3 different screws!
to change an upper front control arm on an a4 means you have to remove the scuttle panel/cover inside the engine bay, undo 3 bolts to remove the strut from the top mount, to drop the mount inside the wheel arch down enough to get the bolt out, when they could have just put the bolt in from the other side.....wtf?!
To change the alternator on a mk1/2 Mondeo V6 you have to take all day as its a complete arse of a job, it's easier if you take the offside driveshaft out for access!! the top bolt has to be undone from the nearside wheelarch using about 4 ratchet extensions... Never again!
Steve
Steve
To change headlight bulb on my mates rover we had to remove the whole airbox and front bumper!
Week after that the other side went!
I didn't answer my phone that day
To change a front indicator bulb in a facelift Vectra c you have to drop the bumper off one side and remove the headlight!!!
Changing a starter motor on a 1.3 corsa/combo. There is a hole at the top of the gear box that you put your allen key through to remove the bolt.If you catch the bolt on the way out the bolt will drop inside the bell housing of the gearbox. So the gearbox will have to come out to retreave your bolt lol.
This is why I want a mk2 escort, so simple to work on.
Don't touch the back bolt at all, remove the front bolt and bend the ARB bush bracket up, swap the bush, bend the bracket in place, put the bolt in. Done.
What is shite is on a lot of newer Fords (I mean the latest Mondeo with ecoBoost and 200ps diesels) simple service items such as oil filters are becoming quite inaccessible, hidden between intake manifolds etc.
Steve
Steve
Ford labour time take the piss...1.4hrs!
Not a hard job but the placement of the starter motor on a 51 transit. Right below the power steering pump and water pipes so if either leak it ruins the starter!
I'm not a fan of much of these new cars....in terms of there ability(or lack of) to be worked on. Such poor design sometimes.
I was never fond of taking the front end off vw/audi's to do timing belts, just because you have to disturb things that are clearly not meant to be removed and replaced all too often. After a few goes you always find shortcuts but my patience is thin at the best of times.
I heard a story about the vauxhall tigras. That when they first came out and you slammed the boot lid it used to blow the side windows out so they modified one of the windows to drop down to let the air pressure out when the boot was opened.
When the K series Rover engine first came out there was an urban myth going round that the headbolts held the crankshaft in the block.
It was bollocks.
It was bollocks.
This is one of my favourite threads so far EVER.
I love the do's,donts and "oh F*cks" its Ace
Some one always finds a short cut whether it be right or wrong.I am not one for bending things.Dont like to bend things out of the way.You bend them back and they are weaker with a chance of snapsvile lol.
Has no one mentioned a Rangey yet
Fixing the bloody car...
That said, the Stilo has to be one of the worst designed Fiats for just about any job on it.
N/S headlight bulb on a JTD,
Front window regs,
Upper glovebox hinge- wanky plastic thing that's always breaking with crappy shallow torx screws that round off if you're not 100% square-on
I'm sure there's more.
