New battery time?
Mrs fired up the fiesta this morning, let it run for a few minutes to get it warmed up and he kids strapped up before taking them to the old mans house about 100 yards up the road
Parked it up, dropped them off, then went to start the car again and nothing
Just a click click
So does this mean the battery is bolloxed? Or did she just not give it enough time to charge up again?
She did mention that the wipers were really slow as well so I'm think the battery is on its last legs
It's been on the car for at least 3 years
Doubly gutting because she was taking the car so she could come home quick enough to see the school play, so it's all obviously my fault
Just a click click
Zee Germans are coming
Stick a multimeter on the battery and see if its getting a charge
I'd be looking at the alternator my self
3 year ols battery ain't old
My wife's escort gti , r reg still has the original battery and alternator from new
If wipers are slow with engine running then it could be a sign tht the alternator isn't doing its job. However with wipers on, lights on, heaters blowing, heated screen on etc then the alternator is already at full stretch, especially if the car is only doing 100 yard trips.
I'd get the battery drop tested first I'd be suspecting the alternator could not be charging properly.
PassionFORD Member
With the current weather conditions I would've said battery but the alternator could also be the culprit. It would certainly be one of the two anyway.
100 yards to take the kids then drive 100 yards back home? Sorry but that is very fucking lazy. Serves her right tell her all the short trips have knackered the battery and she has to pay for another one
She was dropping the kids off before travelling to work, and then she was going to use he car to come back home early to go to the kids nativity play at school so it's not lazy parenting in that sense ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
As for getting a battery for the Mondeo, it's fine the way it is![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
So get home, jump it, stick a meter across the top to see what it's reading with nothing on, then whack all the buttons to see if the alternator is keeping the supply high enough, which should either condem the battery or the alternator, or both?
Just tested it the battery reads as follows:
Bonnet open - 11.98v
Starts with no jump
Running with no loads other than the engine - 14.3v
Running with everything on, radio, blower on max, both front and rear screens, all the lights plus the air con - 14.09v
My money would still be in the battery unless those readings are lower than expected?
Starts with no jump
Sling a battery on it Dojj. After being left for a while a battery does 'come up' on it's own which is why it probably started. Same thing if you take a battery powered torch that is flat, leave it for a while and turn it back on it will go bright for a few seconds before dying again.
cossie fan (unluckerly)
Multi meter will only tell you if the battery's good as it sits! Could still be fucked to test it properly you need to load test it with a drop tester then put a multi meter on it
got a battery, went to fit it, +ve came off no problem, but the -ve terminal is fucked as the nut just spins and spins and spins
closer inspection seems to show that it's the thread thats fucked as there are 2 nuts on the bolt, and you can't get to the second one as the first one is one of them nut-with-a-washer on them types and the washer has flared over the second nut![Wall](https://passionford.com/forum/images/smilies/wall.gif)
3 years after buying the car there are still some cowboy antics coming to light from the previous owner![Wall](https://passionford.com/forum/images/smilies/wall.gif)
still, the mrs has sorted a lift out in the morning as it's cold so i can probaly leave this job till the weekend
When I test all my batteries at work I check voltage 1st and not thing under 12.5v I charge before even testing them... If your misses does loads of short journeys I'd be tempted to give the battery at Leady a 12hr charge and try that.. If it fails again within a few days buy a new 1.
Steve
Steve
