bmw e60 wheel bearing change
just had the mot done on the car and have been told the o/s front bearing has a little play in it, has anyone done this job? how easy is it,
3 of the bolts are easy to get to but the 4 is behind the shocker which needs to be removed from the hub. to do this the lower arm needs to be seperated from the hub to allow the hub to come down enough for clearance. book time is 1.45hrs and from recent experience not the hardest bearing to do but certainly not the easiest.
ah well you learn something new everyday eh?
did you go looking for a 2 month old thread delibrately just to pick a hole in it?
i'm sure the guys already done it by now, but thanks for letting us know anyhow
no but if it means that it stops someone thinking it's a 20mins job after reading incorrect information i'm certainly going to correct it.
if you can't take being corrected make sure the info you put up is correct when you post.
I totally agree. This is not a 10 minutes job. If it was - I would have done it a long time ago. I have two new bearings but no time for replacing them.
