ERST Engine removal. Best Methods?
Old Mar 6, 2005 | 07:47 PM
L33 BYT's Avatar
L33 BYT
Default ERST Engine removal. Best Methods?
I have had my engine out of an older S2 I had. I basically stripped it from the box then undone the nuts on the cross member for the gear box and lifted it out at an extreme angle with gear box still in situ.
Is an ok way I guess but the pulley toook a large scraping of paint from the inner wing.
What is the easiest way for getting the engine out.
May be worth bearing in mind that I would like to clean up the paint work in the engine bay as is a little grubby.
Thanks
Old Mar 6, 2005 | 08:01 PM
BillyCabrio's Avatar
BillyCabrio
Underneath mate, much more simpilar.
Lee Reynolds's Avatar
Lee Reynolds
from underneath
Old Mar 6, 2005 | 08:02 PM
L33 BYT's Avatar
L33 BYT
Is that just a case of getting drive shfts out of the way in this case.
Not sue if I am going to get the clearance as I will not be using a pit or ramp.
Old Mar 6, 2005 | 08:06 PM
BillyCabrio
Place the engine in position mate on a trolly jack, get a mate and between the two of you lift the car over and down.
Jack the engine up and bolt in to place (not directly off of the sump tho, put a board inbetween)
Easy
Old Mar 6, 2005 | 08:08 PM
L33 BYT's Avatar
L33 BYT
Spose that is the best idea, least I Can renew all the Drive shat seals etc with ease and give the underbonnet a G3 and polish
Cheers guys
Old Mar 6, 2005 | 08:20 PM
flashpoint's Avatar
flashpoint
Separate the engine from the gearbox in the car; remove the turbo, alternator and the bottom pulley and jus lift it out, no problem
Steve
Old Mar 6, 2005 | 08:21 PM
L33 BYT's Avatar
L33 BYT
I did it this way last time steve. Was a real tight fit and took a fooking great gouge out the paint work.
Old Mar 6, 2005 | 08:31 PM
Lee Reynolds
thats why underneath is best.
I remove the inner bolts for the lower suspension arm, the rod ends,pull out the shafts, then undo the ARB bolts, undo the top strut bolts and remove the suspension and shafts all out the way in one! Loads of room then! Ya need about 27 inches clearance to get the engine out/in the front
Old Mar 6, 2005 | 08:32 PM
flashpoint's Avatar
flashpoint
Hi lee it can be a tight fit, you must remove the bottom pulley, the best way to stop the inner wing paint from being damaged, is to place a suitable piece of hard board or thin plywood (3mm) down between the inner wing and the end of the engine
Problem solved
Steve
Old Mar 6, 2005 | 08:35 PM
Ginge !'s Avatar
Ginge !
just finding my feet
take the brake resiviour off and the thing with the brake pipes on and take it straight up , never had a problem withn was and also get the engone ion that way too, thats with a machined 1.8 bottom pull too and ya know what there like for clearence
hopper350
Sep 4, 2015 12:53 AM
Ellsa
Aug 9, 2015 07:03 PM
