Pectel T2 diagnostics
Old Feb 4, 2012 | 11:04 AM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default Pectel T2 diagnostics
Hi lads.
My car uses a Pectel T2 but I can't find anywhere that does diagnostics. So I want to get software and lead so I can do my own. No mapping etc just diagnostics and sensor logging.
I have a Pectel monitor downloaded from an Escos website but maybe for those ecu's. I've had some software sent to me by email by a pal who also has a T2 and his is working only on Windows 98. I'm windows 7 and it won't run, even using WIndows 98 compatibility mode (unless it needs a lead all connected up first to work?)
I need a lead too but again no idea where to look. I have a VCDS lead but doesn't seem to work.
Anyone able to help?
Old Feb 4, 2012 | 11:13 AM
studabear's Avatar
studabear
I've just sold the laptop and lead I had to somebody who i thinks is running pectal, on a cossie mk2 escort, I had a lead made by my mate, it was for cossie management though, the pc also needed a serial port.
Have you had a look at the set up msd sell
http://shop.motorsport-developments....weber-91-p.asp
This might be of use?
Old Feb 4, 2012 | 05:18 PM
Camel Fiddler
I have a Dell laptop and a Samsung notebook and neither has serial ports
Old Feb 4, 2012 | 05:56 PM
pectelboy's Avatar
pectelboy
I brought the computer and lead mate ,can send you the software to do it and you the diagram to make the lead,but you need a computer with a serial port nothing else will work .
Old Feb 4, 2012 | 08:33 PM
Camel Fiddler
If you don't mind mate that would be excellent. My lasses bro is into his computers so I'll ask him about serial ports, even if I change my laptop or summit.
Old Feb 4, 2012 | 09:03 PM
pectelboy's Avatar
pectelboy
send me your name and address and will send you a copy and the lead diagram
Old Feb 4, 2012 | 09:24 PM
studabear's Avatar
studabear
you could chance a serial adapter, listed halfway down this page
http://www.extraefi.co.uk/Misc_products.htm
Old Feb 5, 2012 | 01:04 AM
Camel Fiddler
This the diagram?
Will pm my details over
Old Feb 5, 2012 | 08:23 AM
johnyjn's Avatar
johnyjn
Pm sent
Old Feb 5, 2012 | 08:37 AM
studabear's Avatar
studabear
thats the diagram yeah
Old Feb 5, 2012 | 08:59 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
That lead drawing suggests it is for IAW monitor which works with the Weber Marelli L8 & P8 ECUs.
To monitor datastream from a Pectel T2 you'll need a male jack plug to 9pin serial lead and a copy of DESCPRO.
Old Feb 5, 2012 | 09:10 AM
J1mbo's Avatar
J1mbo
B1mbo
and the correct map base for the type of ecu!
Needs to be loaded onto the laptop for the descpro to work with the ecu
Old Feb 5, 2012 | 12:57 PM
pectelboy's Avatar
pectelboy
i have descpro and pi tool box i will send you that as well ,not a problem its easy to make the 9 pin jack pin one up. looks like large headphone jack, had it on my t6 pectel ecu
Old Feb 5, 2012 | 03:55 PM
Camel Fiddler
Yeah I have the jack connector there too so ideal
Old Feb 5, 2012 | 06:46 PM
studabear's Avatar
studabear
I may be able to possibly get more leads made up.
Old Feb 5, 2012 | 06:59 PM
pectelboy's Avatar
pectelboy
Let me know how much stu thanks
Old Feb 5, 2012 | 10:42 PM
polly_x's Avatar
polly_x
You will still need the correct profile on the laptop to access the ECU even if you have Descpro and the correct lead so it depends which ones come with the Descpro install you get. There are lots of versions of Descpro and even more profiles.
That diagram above is totally wrong for what you need cable wise. You need a simple TX/RX/Comms Ground cable. (3 wires)
You may also find that the ECU is locked as well.
Good luck!
Old Feb 6, 2012 | 05:54 AM
pectelboy's Avatar
pectelboy
Yes polly x the leads for a weber iaw software motitor, not for the pectel it just reads the data stream from the ecu
Old Feb 6, 2012 | 01:55 PM
polly_x's Avatar
polly_x
Like I said. The lead is the least of your worries!
Old Feb 6, 2012 | 04:17 PM
pectelboy's Avatar
pectelboy
I have some profiles ,and maps that Ahmed give me that's if its not locked if so it's off to pectel
Old Feb 6, 2012 | 05:27 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
If you a fancy a trip to Brum I will put it on a car and see if I have a profile for it.
Old Feb 6, 2012 | 05:28 PM
Martin-Hadland
Sorry but I cant understand what you're trying to say there!!
Old Feb 6, 2012 | 05:37 PM
Camel Fiddler
I've emailed Mountune themselves to ask if they can help with any of it with regard to profiles etc as they mapped it but awaiting their response. But I know a lad with a T230 and same ecu as mine who has been successful in getting the software working. He got his from Paul Hills but my laptop doesn't like it for some reason (as said in first post)
Does the lead and everything have to be connected for the software to load or should it load up anyway?
Old Feb 6, 2012 | 06:23 PM
pectelboy's Avatar
pectelboy
Sorry martin it sound right have some maps on my laptop from my t6 pectel for different injector boost air injector and other things but have no way to unlock it as don't have the pectel dongle
Old Feb 6, 2012 | 06:28 PM
Martin-Hadland
If its a T230 ecu then it will be locked, you will either have to have the ecu fixed for 'any developer' (in which case you will loose the map) or try and get a dongle (good luck with that option!).
Old Feb 6, 2012 | 06:41 PM
Martin-Hadland
So you can't look at the maps you have off line on your laptop?? If they need a dongle then I'd bin them off, if they're simply password protected then maybe try and get hold of the password?? Btw puctuation would make it easier to read
Old Feb 6, 2012 | 07:13 PM
pectelboy's Avatar
pectelboy
its this bastard iphone martin, and i was dragged up lol
Old Feb 7, 2012 | 06:32 AM
Camel Fiddler
As I say Martin, I know a lad who has his T230 running on the software and his is locked and he can see what each sensor is showing up in real time.
Old Sep 25, 2014 | 11:00 AM
OZHCR32's Avatar
OZHCR32
Bump...removing my SCS T38 and installing a new EFR turbo so need a cable to tune the T2. Anyone able to help me out with where I can get a cable or drawings so I can make one?
Old Oct 3, 2014 | 06:51 PM
RS Bowk's Avatar
RS Bowk
You have pm
Old Oct 4, 2014 | 03:58 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Look on ebay for the data cable.last time i looked there was one for sale on the
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
