Zetec turbo or Cossie power??
Old 29-01-2012 | 05:47 PM
Luther-The-Escort-Van's Avatar
Default Zetec turbo or Cossie power??
Which is best??
Which is most reliable??
Which is cheapest to built to 300 bhp??
Old 29-01-2012 | 05:52 PM
Red16's Avatar
Red16
In my opinion
Originally Posted by Luther-The-Escort-Van
Which is best??
Cossie
Cossie
Cossie, unless you risk running a budget spec Zetec
Old 29-01-2012 | 05:54 PM
Cheers mate, just chucking some ideas about for my RWD Escort mk4.
Only got about Ł1500 so being realistic I prob wont be able to go the cossie route!
Old 29-01-2012 | 06:01 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Ł1500 to build a decent ZT to make a reliable 300bhp is going to be pushing it too IMO.
Cheers,
Grant
Old 29-01-2012 | 06:10 PM
luke19790_3's Avatar
luke19790_3
Cheap option. St170 block, blacktop head. Focus rs manifold and turbo. Megasquirt. Not about the flywheel with rwd.
Old 29-01-2012 | 06:13 PM
phil_rs's Avatar
phil_rs
yam yammer
For rwd application I reckon a yb would be the easiest and cheapest option
Old 29-01-2012 | 06:17 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
300bhp, cossie engine possibly, if you can find a standard one cheap.
zetec turbo, grand in bottom end, new gaskets and valve springs and you'll piss 300bhp.
not much in it, it's all the other bits that cost money like injectors, manifolds etc.
Old 29-01-2012 | 10:08 PM
rsmark86's Avatar
rsmark86
But everyones forgetting it's rwd
Needs custom sump, mounts and water rail and pipe work, exhaust ect ect with the zetec
Cossie most bits are off the shelf for it and a few hundred quid will see 330bhp stage 3 on standard engine and turbo
Old 30-01-2012 | 10:32 AM
XRT_si's Avatar
XRT_si
Realistically, both are out of your price range if you're going to do it properly.
A Zetec turbo could be done the cheapest if you can make your own sump and water rail kit though, and it will piss 300 bhp.
Old 30-01-2012 | 12:05 PM
mgtkr1's Avatar
mgtkr1
i get the impression the zetec is a blinder of a setup and very tuneable. however the yb is a masterpiece and purely for bragging rights, its worth 50hp alone. when someone asksd wqhat engine your running, and you can just say cossie in one word, its enough said. also bear in mind the std internals are more than upto 400hp. after the initial outlay its probably the cost effectrive option aswell. also has the best looking cam cover out of all the performance fords.
Old 30-01-2012 | 01:06 PM
rsmark86's Avatar
rsmark86
Don't get me wrong, me personally could do cossie cheaper, because I know where to get bits
Zetec is alot lighter.
Why not fit something like a st170 engine with 1.8 mm frs gasket will be upto 300 bhp
You will just have to set the vvt on a switch unless you buy proper management
Also a t34 at mild boost will be ample too
Old 30-01-2012 | 01:36 PM
McGoo 69's Avatar
McGoo 69
im also wondering this myself, ive recently changed plans and ive gone from fwd to rwd
i have a full focus rs kit (everything minus the engine) so am i best building a zetec turbo using these bits and running it rwd or should i sell the bits i have and go yb?
how will a std focus rs engine cope rwd?
Old 30-01-2012 | 02:24 PM
rsmark86's Avatar
rsmark86
Ring nick at gatwick motors he has a bare focus Rs engine in need of a rebuild for Ł300
There's a guy on here with a mk1 frs on stock bottom end and modded head doing 390bhp
Totally standard engine with decat, actuator and decent cooler and remap can see 290bhp and over 300 with a decent manifold
Old 30-01-2012 | 02:50 PM
XRT_si's Avatar
XRT_si
What exactly do you have? Fitting a Zetec engine the other way round can be a little involving.
Depending on exactly how far back the engine is mounted the exhaust manifold and inlet manifold won't fit. And they will look ugly that way round too IMO!
The Zetec engine itself will need a new sump, a water rail kit and an alternator kit as well more than likely.
Also a custom flywheel will be needed ideally to match to a T5 gearbox and Cossie clutch.
Old 30-01-2012 | 04:14 PM
McGoo 69's Avatar
McGoo 69
its a mk5 xr3i with a sierra floor pan, and escort wrc pannels
ive seen flywheels available of the shelf for the t5 so that shouldnt be a problem.
i mean im happy to sell the zetec stuff i have and buy a cossie engine but i doubt ill find a yb engine for around 800-1k..
what do you think a focus rs inlet manifold, exhaust manifold, turbo, wiring loom, ecu, charge cooler stystem and a cat convertor is worth? plus a few hoses
Old 01-02-2012 | 05:44 PM
Thanks for all the advice chaps. Much appriciated!! Still in two minds on what to do. Lol
Old 01-02-2012 | 08:29 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
For RWD i would have thought a standard sump would be fine or at least need little work to get it in place, the bottom of a blacktop is just steel and pickup pipe could be modified easily.
manifolds will need to be custom though.
my pretty average forged zetec aimed towards 400-450bhp has cost around 4.5k with pipework etc into a fiesta, rwd would be a little more.
cossie would be a chunk for engine itself, then few modified parts after that, i can't see there being much in it really, but depends on level of tune you aim for really though.
Old 02-02-2012 | 03:19 PM
R4N SS's Avatar
R4N SS
Dojj has a focus RS engine for sale cheapy cheap
Old 02-02-2012 | 03:53 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
RB20DET
Done
oe YB
robnock
21
13-05-2019 05:29 PM
Billy_RS
15
05-09-2015 12:04 PM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Zetec turbo or Cossie power??
