is their eny differance between oversized rings and oversized pistons
I think i have std pistons with oversized rings and was wordering if they would last or would i be better off getting oversized pistons
I would not skimp on such a critical part of your engine best get the bores sized then get the correct piston and rings maybe just get them rebored ,did try this on a mini years ago the piston and rings were right on the limit so I just got new rings within months she was a real smoker an oil burner ! so do it right !
i havent taken the pistons out yet, I just asumed that it was std pistons with oversized rings as the guy I baught it from said he put oversized rings in it and that it had been boared out
*** Sierra RS Custard ***
Pistons should have an appropriate clearance for the bore, on a typical 80-90mm bore it will usually be a couple of thou on a standard engine and double that on a forged turbo engine.
Rings have an appropriate clearance as well, normally in the 15 thou or so ballpark on a similar sized bore.
You cant increase the size of either one without altering the other as the other would end up far too loose.
its an rs turbo engine mate, my engine is needing a few quid spent on it so i baught another 1, the guy said it had bottom end rebuild used the engin then took it out because the shell was fucked and the engine was left laying for 2 years, so i took the big ends and mains out to check them and the shells are quite worn
passionford pro
[quote=dug112y;5759058]you could run an engine on same oil for a few years and have no damage mate.....i think you have been shafted with a fucked engine.[/qu
A think so mate cheers fur the help
wowk
30-03-2021 07:49 PM
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
