Supra Rear Diff Conversion nearly complete
Old Nov 13, 2011 | 05:43 PM
fraser9764's Avatar
fraser9764
Default Supra Rear Diff Conversion nearly complete
Supra rear Diff and fully adjustable 6 degree beam is now fitted, Uses standard driveshafts and prop
this should be a pretty bombproof conversion, the diffs are taking 1200bhp or something daft on these crazy Japanese supras. Beams and diff conversions are available through 'A RS Licker' on here, or turbosystems
Old Nov 13, 2011 | 05:49 PM
boy-racer-1's Avatar
boy-racer-1
how much has it all cost?
Old Nov 13, 2011 | 05:52 PM
fraser9764's Avatar
fraser9764
less than a 9" you would have to speak to John for that.
Edit : Price is £550 plus diff and propshafts conversion which hopefully will be an adapter.
Old Nov 13, 2011 | 06:19 PM
ts.tm.jb.fingers's Avatar
ts.tm.jb.fingers
looking good m8,should have the last piece off the puzzle to you very soon,bang tidy
Old Nov 13, 2011 | 06:40 PM
slammedorion's Avatar
slammedorion
Looking good. What next then? Lol
Old Nov 13, 2011 | 06:49 PM
fraser9764's Avatar
fraser9764
Gearbox probably
Old Nov 13, 2011 | 06:55 PM
robrs2's Avatar
robrs2
Got a 2 way in that diff
Old Nov 13, 2011 | 07:52 PM
fraser9764's Avatar
fraser9764
A what?
Old Nov 13, 2011 | 09:25 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
What ratio is the diff ?
Steve
Old Nov 13, 2011 | 09:32 PM
fraser9764's Avatar
fraser9764
3.7 i believe
Old Nov 13, 2011 | 10:45 PM
robrs2's Avatar
robrs2
Originally Posted by fraser9764
A what?
As you are fitting it thought you would know about them.
http://en.m.wikipedia.org/wiki/Limited_slip_differential
Look on types
Old Nov 13, 2011 | 10:59 PM
TRUEBLUE1968's Avatar
TRUEBLUE1968
Beat it to death.....or at least try
http://youtu.be/TbmG0VMejd4
Old Nov 13, 2011 | 11:33 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Nice conversion
Old Nov 14, 2011 | 12:03 AM
janvanv's Avatar
janvanv
www.rallyanarchy.com
Look at the one just above this post by Trueblue in accross the ocean:
That kit is about USD320 or 198 English Squids.
And its all bolt in--except 2 weld nuts up into the body on a wider spacing than the normal Ford 4 bolts
And there's a flange and weld in part into the propshaft and a Spicer 1310 u-joint for another 60 squids.
Post to UK ain't near as dear as post the other way.
Old Nov 14, 2011 | 12:15 AM
janvanv's Avatar
janvanv
Originally Posted by RWD_cossie_wil
Nice conversion
Thank you. These Supra diffs are amazing diffs. Yhe pinion and diff bearings are larger than US Ford 8.8" parts, the diffs are all 4 pinion diffs and strobger than hell and alternate gears cost second had from USD 10-30 and new under $150 or so depending on ratio...
I got one for my rally Sierra from a You-Pull-it scrappie for $29.75* with the LSD and a 4.3 ratio (with gravel tires at 64cm tall and 1:1 forth gear 7000 rpm gets ya 123 mph.
Our Borg warner T5s all come with really tall 5th gears (either .63 which is really toooooo tall, or 0.73 which is fine) So 1st thru 4th its a case of Yeeeeeee Haaaaaw!, then 5th is slightly less rev than a bog standard car.. Nice for transits and MPG
Now they're up to a shocking USD55 at the same scrappie and private sales from $75 to 250
8" Toyota is very popular in the desert race and rock climbing crowds and of course those afflicted with Driftosis. Very reliable.
We didn't get any LSD in US and Canajian model Xratties and there's not much choice in final drive (3.36 or 3.64 in what's a Scorp fiff you you guys) so we had to do something.
Old Nov 14, 2011 | 04:20 AM
Can these diffs be fitted to the 4x4 cossies then or are the ratios different.
Old Nov 14, 2011 | 06:33 AM
B13 JUS's Avatar
B13 JUS
for the £550...
do you get the 2 adaptors for drive shafts and the diff mount bracket?
Old Nov 14, 2011 | 06:43 AM
COCHYN's Avatar
COCHYN
Holy shit! That's so cheap for a near enough bomb proof conversion, as apposed to the rip off prices from Quaife and Bara
Old Nov 14, 2011 | 06:48 AM
JamesH's Avatar
JamesH
Good work
Old Nov 14, 2011 | 08:15 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
i think that the hardest part of the conversion if finding out what model the 3.7 ratio diff came in pmsl
Old Nov 14, 2011 | 09:03 PM
Daviet's Avatar
Daviet
Any links to where these can be found for that price?
im sure there would be lots of interest on here
Old Nov 15, 2011 | 03:25 PM
janvanv's Avatar
janvanv
That depends on the ratios, naturally.
These diffs in US market come in early turbo manual trans= 3.9
later like 89 on turbo manual= 3.73
all years turbo autotragic= 4.3
non-turbo manual= 4.3
For my own car it just so happened that a front 4x4 diff I bought off some galoot over there was a 3.9 so I was all set with 3,9 in both ends.
Some alternate ratios I've come across buying Supra diffs and (since I invented this kit (nudge nudge, wink wink) out of other Toyota 8" solid axles which share the same stuff inside--smart--- is 4.1; 4.37; 4.56
See we have all kinds of junk you guys don't but we don't get some things very easily.
Like we never got rwd Escorts so for 20 years I've pointed out to rally boys here that the lowly 240 Volvo is for all purposes a scaled up Escort with a killer engine that they can't break.
And that our version of the Sierra is an excellent and cheap rally base chassi...
So them we have to have real rally parts or at least really durable stuff since most guys here don't work on much of the car.
So: Supra diff into Sierra, or "Xratties" *
Toyota pick up 8" into 240 Volvos
Volvo Dana 30 into AE86 Corolla, Mazda, Mitsubishi Colt rwd old cars.
Our Sierras are same as your MkI XR4i except the Cologne V6 is out, and the Brazilian made 2300 SOHC 8v turbo in, and they became XR4Ti The were a serious sales flop here and many have sat around , neglect and abandoned and gotten kind of "ratty" over the years... We bring 'em back to life, spiff 'em up and make 'em all purdy again so they hain't "ratty" anymore.
They're "ex-ratty" (this all stems from the font for the 4 in XR4Ti looking like an 'A' from a few feet away, least according to an ex-wifie)
Old Nov 15, 2011 | 03:42 PM
janvanv's Avatar
janvanv
You could Google John Van Awful Bastid
If you get a water pipe and sewer contractor in the Stockholm Sweden area that ain't him, although he used to live near by and ride at a motor-cross track right where the wrong place is.
No, look in the Far North West Corner of USA, almost up into Canada...
3drRich
Sep 13, 2015 07:32 PM
yatta
Sep 1, 2015 11:28 AM
RsS2daz
Aug 14, 2015 05:26 AM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
xr4x4rs
Aug 6, 2015 09:03 PM
