Subaru knowledge needed!!!
Old Sep 27, 2011 | 07:56 PM
COCHYN's Avatar
COCHYN
Default Subaru knowledge needed!!!
A mate down the road has a turbo off an STI he wanted me to fit to his MK1 WRX, along with some bigger injectors. Don't know anything about Scooby's I'm afraid, I'm just a wrench turner
I fitted the turbo and left the injectors until I find out exactly what they are, because he hasn't got a clue. Even sceptical about the turbo
But she flashed up fine and holds 1 bar of boost, but then stopped and left it until I can find out what's safe to run so he can make his way to a tuner and get it set up.
What boost should I set it at and what's the standard boost pressure supposed to be for this Jap crap?
Old Sep 27, 2011 | 08:16 PM
Nick 172 Sport's Avatar
Nick 172 Sport
he must be mad lol car will at least need mappin you cant just stick any turbo on a impreza engine build looming
bazpro's Avatar
bazpro
dont know loads about scoobs but did have one and got told if you change the turbo ect without a remap you run serious risk of blowing it up hence why most of them blow up and get a bad reputation.
i would just leave boost as it is and take it easy til it gets looked at.
Old Sep 27, 2011 | 08:23 PM
COCHYN's Avatar
COCHYN
Ticking time bombs the lot of 'em
I'll just finish it off and leave it at 0.9psi then (from what I read is stock boost pressure).
Old Sep 27, 2011 | 08:25 PM
RS Grant's Avatar
RS Grant
Made in Scotland
LOL!!
You can't fuck around with Subarus, they shit engines from time to time anyway, so bolting on a different turbo and razzing it up the road isn't gonna end well... set your mates right foot to zero boost until he can get to someone to map the car for the uprated turbo.
What are the markings on the Turbo??
Cheers,
Grant
Old Sep 27, 2011 | 08:27 PM
COCHYN's Avatar
COCHYN
Don't worry mate, not the first turbo I've worked on
But just interested in others views on these engines, I don't know loads about them, but I know enough to NOT want to have one
Old Sep 27, 2011 | 08:35 PM
st3v3's Avatar
st3v3
as said set boost to zero, then:
a) you cant be blamed
b) he will have to get it set up (then see a)
Scooby engines arent that bad,most who think they are havent had a scoob or if they have theyve DIY'ed them and not had fueling check/remapped.
Old Sep 27, 2011 | 09:02 PM
dingla rs's Avatar
dingla rs
i had a roller bearing turbo on mine easy to change after taking ten heat shields off ,mine run 3bar boost till i had it mapped an turned down ,mates had 0.9 on sti turbo and shit the engine but think it was more down to the mushroom filter and wrong oil
Old Sep 27, 2011 | 09:06 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Running around on 3 bar of boost isn't shy... was that peak, or held??
Cheers,
Grant
Old Sep 27, 2011 | 09:09 PM
dingla rs's Avatar
dingla rs
Cheers,
Grant
peak it was 480 brake and badly mapped and set up hence turning it down held 2.3 bar no problems after set up on rollers ,never missed a beat till it went up in smoke
Old Sep 27, 2011 | 09:14 PM
slammedorion's Avatar
slammedorion
They run between 14-16psi standard.
What colour are the replacement injectors? Yellow?
Should run a safe 300bhp.
Old Sep 27, 2011 | 09:50 PM
daz1968's Avatar
daz1968
Suburus are not bad or weak at all most problems stem from running Jap maps designed for 100 Ron fuel on our 97 or 95 Ron. I have had 2 my current one a twinscroll jdm and are very strong I would defo get it checked out as any engine run outside what it's mapped for is looking for trouble. Although the maf does measure air entering engine and adds fuel to suit but a larger turbo would draw more air and if the maf scaling can't measure the airflow correctly it will calculate fuel incorrect and probably run lean with disastrous results. Any car run outside of it's map tables is on borrowed time
Old Sep 27, 2011 | 10:39 PM
jameswrx's Avatar
jameswrx
What 'sti turbo' was it.
The early wrx has an upswept turbo inlet on a td05 turbo. The only 2 turbos that are a direct swap are upswept td05's and td04's (it's smaller brother that comes on early wrx wagons)
If it was an sti v1/v2 turbo with upswept intake it's the exact same td05 as the wrx.
Or have you fitted a front entry VF23/24/28/30/35/34 turbo and used a silicone 90' elbow?
Old Sep 27, 2011 | 10:52 PM
stevieturbo's Avatar
stevieturbo
C**t
Sounds like a bit of a knob ? Why would he want larger injectors with no way of remapping to suit ?
And are the injectors even the correct fitment ? There are quite a few types.
And as James said, what year of car has he, and what turbo is it ?
And various models run different boost pressures. Once yo start swapping turbos etc, the standard boost control setup will not be correct, so obviously this will need addressed.
And the biggest problem with Subarus, is their owners. Bodging tuning work etc or crap maintenance. Is it any wonder so many suffer damage.
Old Sep 27, 2011 | 11:27 PM
botters's Avatar
botters
competant bodger
for those saying scoob engines are not weak , i disagree strongly, my local engine builder pays his mortgage with them lol. they love spinning bearings on the crank for fun. my mates standard sti type r thingy did for no apparent reason at 40k, it had full service history at the time, he called scooby clinic from the side of the motorway and they said jokingly "we have lowered our labour rate for these type of repairs as we have had that much practice at them we can do them with our eyes closed lol"
he then took it to my engine guy for a listen and full diagnosis, his reply was come through to the build room ill show you whats up on these 5 scooby engines i have in now for repair!
fookin chocolate crank jap taxis!
Old Sep 28, 2011 | 07:41 AM
COCHYN's Avatar
COCHYN
As said boys, he asked me to fit it and I have. I've left the injectors as I'm not convinced they've been serviced nor are they the capacity he says they are. So its now boosting minimal pressure and I've left him with a few numbers for decent tuners and requested he not boot it everywhere he goes....there's only so much you can suggest. After that, its up to him
@ Stevieturbo
So my work yesterday would be considered bodge then would it?!
Old Sep 28, 2011 | 11:20 AM
stevieturbo
C**t
@ Stevieturbo
Fitting a different turbo, and not retuning to suit. Mmmm how else can it sound ?
Or did you at least check afterwards to ensure fueling and timing were safe ?
Old Sep 28, 2011 | 11:25 AM
stevieturbo
C**t
The engines certainly arent perfect. More failures are down to poor maintenance than anything. And even at 40k, many dealers dont even put proper oil into the engines. So it isnt really surprising some fail.
But Ford mechanics earn their living repairing Fords. Mitsubishi mechanics earn their living repairing Mitsubishis. French mechanics need their heads examined.
Old Sep 28, 2011 | 12:22 PM
st3v3's Avatar
st3v3
Your mate will have to get it mapped, not remapped
as you can't on the older cars.
You have two options get a Scoobyecu from Scott Taylor (Via ebay)
and give him your cars spec, he will then provide a chip to suit the cars
current state of tune, or...
go for a full replacement ECU such as the Apexi Power FC.
The FC is a stand alone unit and has multiple mapping points, so in the
long run if you decide to take the car to another level it can quite easily
be done.
Speak to Pavlo (Paul Balamire @ Zen Performance)
He will provide and map for Ł800 + VAT (Include Commander)
personally I think your mate has opened a can of worms unless he's willing to spend money.
Old Sep 28, 2011 | 12:28 PM
COCHYN's Avatar
COCHYN
Thanks for the valid advice mate, much appreciated. As said, I've only done what I set out to do, fit the turbo and keep it on standard boost, advising him not to run it stupidly until its booked in with a reputable tuner. Never said I'd map it or anything along those lines, simply fit it.
So at least he's aware that after its fitted, I no longer have any involvement.
@ stevieturbo
You're a cunt
Old Sep 28, 2011 | 12:59 PM
stevieturbo
C**t
You can fit a daughter board to the old ecu's which allows remapping. ESL offer this product/service, as do various mappers.
But given it is almost the same price as a proper aftermarket unit which chucks the MAF in the bin, and you are tied to certain individuals to remap, it isnt very good value for money IMO.
Best option on a budget is SimTek, but it is still close to Ł1k
And I may be, but I'm still right
Old Sep 28, 2011 | 01:34 PM
chaffe's Avatar
chaffe
Turbocharging Technician
just leave the wastegate rod off until he gats it mapped/chipped/piggybacked.
Old Sep 28, 2011 | 01:59 PM
R4N SS's Avatar
R4N SS
go for Omex at around 600 for the ecu
Old Sep 28, 2011 | 02:07 PM
massivewangers's Avatar
massivewangers
Why is everyone saying he's a moron for doing it? I'm pretty sure in the OP it said that the turbo was just being fitted, and he was being told to go and get it set up before giving it the beans.
I don't see mention of just chucking a turbo on and going everywhere foot to the floor?
Old Sep 28, 2011 | 02:25 PM
COCHYN's Avatar
COCHYN
Its because knob heads want to dilude themselves and crucify you regardless of your experience and what you've built, clearly showing how competent you are. But you tend to humour and laugh at them
Anyways, he tell me its going quite well from A to B without any problems or flooring it. I trust his word, he's too paranoid to go against advice, especially from the person who fitted the turbo. He's booked it into a Subaru specialist, I believe its Silverstone in Deeside who also build those MK2 Escorts with rotary engines
Old Sep 28, 2011 | 05:53 PM
stevieturbo
C**t
People rarely do what they are told though. And then when it shits itself...they will blame everyone else but themselves.
Old Sep 28, 2011 | 05:59 PM
Rollinz's Avatar
Rollinz
need to have a word with gaz at gr performance mate,
he works on 2x scoobs that compete in TA and they are both fron runners
he has done LOADS of big power road ones too!
www.g-rperformance.co.uk
Old Sep 28, 2011 | 06:47 PM
massivewangers
Well, that's tough shit isn't it
JoeyBoyden
Jan 4, 2024 02:36 PM
turbojoe69
Sep 17, 2015 07:07 AM
borboyous
Aug 22, 2015 11:17 AM
turbojoe69
Aug 18, 2015 06:41 AM
col93saphcos
Aug 7, 2015 03:21 PM
