cosworth crank pulley removal tool???? UPDATE: got it off !!!!
I need to get myself a cosworth crank pulley removal tool for the inner pulley, trying to change all the seals and unbolted the bottom plate but the pulley wont budge, need the right puller....what one did you guys use. my puller isnt suitable....
For the crank pulley i used an air gun and one of these and it worked straight away http://www.ebay.co.uk/itm/Cosworth-Y...item43a852ace6
As Brammer says that puller is the one to have, when I first did mine(belt) I made one the same as needed it there and then, a lot cheaper than a broken pulley!!
When the pulley is off, if you tap out the woodruff key, use some fine lapping/valve paste between pulley and crank nose it gets rid of any crap and when worked for about 1/2 hour makes it a snug fit rather than stupid tight, my one now comes off with just 2 fingers easily but no play, the way it should have been to start with, just be super sure to wipe off all traces of paste afterwards.
you should be able to remove the ttothed pulley relatively easily, i would imagine a good soaking in plus gas or similar will free it, its probably just sticking on the surface rust or woodruff keyway. a tap with a rubber mallet or deadblow hammer should free it off.
Soaked it in wd40, gave the end of the crank a tap with a 2 pound hammer and still nothing mate,
I was in machine mart earlier and all the 3 leg'd pullers are too big, even the small ones. Saw this though; wiper arm puller
http://www.machinemart.co.uk/shop/pr...per-arm-puller
might be able to get it down the sides but its not long enough, might try to cut the arms and lenghten them.......
Superaly aka escort700bhp - the nice man building my car says i might need to take the crank out to get thsi thing off.....really dont want to do that just to change the crank seal.
google maps says...........249 mi,4 hours 14 mins
so by my watch i should be there about 02:55...have a cuppa ready for me! haha
not been down to the machine shop yet, will be calling them soon by the looks of it.
Thought I would let you see how I managed to get off the sprocket.
Went down to machine mart the other day and everything they had wouldn’t fit so I came home had a wee think about it and remembered the only thing that had a chance of fitting down the side was a wiper arm puller, no way near long enough but the widths on all the bits sorted worked. Went down yesterday and bought it, dropped it off at the workshop and they extended them to the size I wanted.
![Name: 2011-07-22162122.jpg
Size: 305.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/136695d1501884623-cosworth-crank-pulley-removal-tool-update-got-it-off-2011-07-22162122.jpg)
Took it home and got on the grinder to shave all the bits down so they would fit.
![Name: 2011-07-22161710.jpg
Size: 119.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/136696d1501884623-cosworth-crank-pulley-removal-tool-update-got-it-off-2011-07-22161710.jpg)
Stuck it on and POP it moved, once it started moving it was easy enough to pull off, just the initial bit was a bitch.
![Name: 2011-07-22161809.jpg
Size: 129.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/136697d1501884623-cosworth-crank-pulley-removal-tool-update-got-it-off-2011-07-22161809.jpg)
A little bit rusty!!
![Name: 2011-07-22161822.jpg
Size: 93.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/136698d1501884623-cosworth-crank-pulley-removal-tool-update-got-it-off-2011-07-22161822.jpg)
![Name: 2011-07-22161842.jpg
Size: 80.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/136699d1501884623-cosworth-crank-pulley-removal-tool-update-got-it-off-2011-07-22161842.jpg)
Well happy, thought I was going to have a nightmare getting it off! So if you are ever stuck guys hopefully my idea will help.
JoeyBoyden
14
15-08-2015 09:51 PM
Zoggon
10-08-2015 10:39 AM
