YB crank bolt removal
I know theirs a million threads but most replies are with the engine in the car.
Mine is out and stiff as fuck - tried a bolt on the fly side and jammed against the engine stand and it bends the spanner tried a snap on impact gun and nothing.
Any tips - it's not an left hand thread is it??
More boost Igor!
It's a normal thread, not cack handed.
If it were still in the car I'd have suggested a big ass breaker bar with it in gear and someone standing on the brakes. As it's not I'll suggest reinstalling it then use a big ass breaker bar with it in gear and someone standing on the brakes.
If it's got threadlock on it you'll need some proper torque to crack it out, that or heat it up maybe?
I would say use a proper flywheel locking tool and the big ass breaker bar as mentioned above with a couple of mates holding engine for good measure , it will be tight , but it will go , even if you have to put some load on it then get one of said friends to give the breaker bar a wack and I do not mean in direction of removal , I mean towards the flywheel , sometimes the shock does the trick
I assume the engine is out the car for some engine work ?, is the sump coming off, if so simply take off a rod cap off after removing sump, and put a strong piece of wood in the gap where the rod was so it lies across the flats of the block base, undo easy that way, done other engines this way.
Don't use loctite when reassembling, it's seriously not needed.
The sump is off but i can't picture what you mean?
i have in the past put large breaker bar on pully bolt rest against the floor and just turn the ignition key all ways works a treat, was the quickest way on the 1.8 cvh sierras too when doing cam belt!!
competant bodger
tbh mate you shouldnt have any trouble with your electric snap on gun so long as your battery is fully charged as mine removes them no problem, just make sure you are using an impact socket as a lot of tourqe is wasted through non impact type, mine removes vw lt crank bolts easily and they are tourqed to 520nm!
DixieTheKid
11
06-06-2020 11:20 AM
Fudgey
17-09-2015 01:06 PM
