Zetec oil pump failures - some actual definative FACTS please...
#122
Hi mate no Ian didnt build my engine, although it does have one of his GT28's on it,
The engine was built between myself & Simon & Nick @ Sitech Racing, they done the headwork and cam profiles, and fitted and mapped the Heltech ECU,
Car has proven itself on a few different rollers now and im very very happy with it
The only thing now is this oil pump issue, as the power is still rising when i hit the limiter,
so i need to extend the rev range in order to realise its full potential,
Thats why this topic interests me so much,
I also had thoughts, what about using a dry sump pump and running it with the stock sump, albeit modified, and removing the shitty zetec oil gear,
Is that a possibility, i havent given too much thought to the ins and outs of it as yet, but at least that way you wouldnt have to find space for and oil tank in the engine bay, and you could mount the pump where the a/c compressor usually sits on the focus??
anyway back to the pump , alot of people including me dont think about how the pumps can be mounted and on fwd cars ,like on the fiesta the chassis leg is in the way not allowing you to the oil pump pulley etc , the easiest way would be to mount the oil pump on front of the cylinder head and drive it off the cam pulleys instead of cutting the sump up etc
heres some pics of cam driven dry sump pumps
the only other option i personally believe is remachine the oil pump casing making it deeper so you could run a thicker and wider oil gear adding say double the materials overall strenght . maybe put the gears mounted in a bearing housing which could inturn help with crank nose flex, the question is who would be willing to do all of the development work and then risk a engine?
cheers paul
#123
I should have said one of Ians GT28 Hybrids then lol, its a GT2871 sized turbo from the outside, Im sure Ian will beable to tell you what is on the inside,
#124
Paul, what sort of horsepower are those engines? They look bloody impressive! Does anything change oil flow wise with an engine tilted like that?
#125
[quote=HockeyNomad;5316093]It isnt a conventional GT28 lol,
I should have said one of Ians GT28 Hybrids then lol, its a GT2871 sized turbo from the outside, Im sure Ian will beable to tell you what is on the inside, [/quote
i think he mentioned that he got a stage 5 turbo which could flow 500 bhp but iam sure he said it was a t34 housing etc , still well done mate it must be a right aminal
as for the engine being mounted like that , then no as with the dry sumped engine with the correct pump it will pump oil anywhere, the only down side to doing this is say in the above picture is the scavaging would have to be at the front of the engine as that would be the way the oil runs. in standard engine form you can go front or back giving you more options for pipe runs etc, i believe the little picture the engine was around 560bhp , however the bottom picture is shaun carlson drag racing meguires ford focus with over 1000bhp running on methonal , everything was custom built by esslinger including a custom cylinder head which makes a evo head look small the ports are massive.
cheers paul
cheers paul
#126
[QUOTE=zetaboostboy522bhp;5316145]
Yes all the outlets would need to be on the front of course.. i didnt know if it effected the way the oil drains out the head or oil building up under the rocker cover, you'd think you would have a cam constantly sitting under oil...
Those guys obviously know what there doing though so have no dought they have the solutions behind these problems!! Custom cylinder head... clearly alot of development has gone into this engine! Monsterious power!!
cheers paul
cheers paul
#127
Bulletin Board User
To me the oil pump gears are a symptom of the underlying problem, and I wouldn't be happy simply changing these in the hope they were strong enough to mask the original issue.
The best starting point by far is the black top engine - Ford went to a lot of trouble making a stronger overall unit to make up for the compromise of the shared architecture for 1.6 - 2.0: the silver top 2.0 was always criticised as being harsh, as simply too much metal was removed from between the bores. In contrast the 1.6 was a vey sweet engine.
The problem with the enthusiast Turbo builds is there's no real durability testing - they're just built and considered good if they don't blow up within a relatively short space of time, when in reality parts the architecture (mainly bearing loadings etc.) is pushed way past what it should cope with. I think the sensible ceiling for the standard block is 400bhp.
CGI block is very nice for long term reliability and way better NVH (not that many care about that).
To the original point/question - Data collection is a good idea, but to get anything meaningful you really need:
- RPM limit
- Flywheel power
- Hours of use
- Balancing information
- Pistons/Rods used (ideally weight too)
- Flywheel type and weight
- Crank pulley type
- Ancillaries in use
- RPM limit
- Flywheel power
- Hours of use
- Crank pulley type
#128
- RPM limit
- Flywheel power
- Hours of use
- Crank pulley type
- RPM limit
- Flywheel power
- Hours of use
- Crank pulley type
most engine machine shops can balance a engine etc but whos to say inbalance is the cause of the gears failing, you see we are all guessing
iam not having a dig mate as i would love to see this happen i just dont think it will
cheers paul
#129
Bulletin Board User
Paul,
Yes for sure, but fitting a dry sump system still leaves the crank loading, it would be interesting to see bearing shells in high HP zetec's that have done a few thousand miles.
I've been thinking about this some more and I can't see it is harmonics - if so there would be a direct correlation between failiure and RPM.
My money is on cylinder pressure, which directly relates to crank loading (as some have said) - in which case static CR, boost and cam timing are the key factors.
In an case, Black top and dry sump sounds like the best option.
Cheers,
Mark
Cheers,
Mark
#130
Paul,
Cheers,
Mark
Cheers,
Mark
all i can say is fit a dry sump system and steel crank if you can afford it lol
cheers paul
#131
XRT si thanks for putting this thread up. my car is just about ready to come out and you've got me wanting to take the engine back out
i think am going to try to get a standard zetec flywheel on as soon as.
never seen a electric oil pump mate would be good to look in to
lee
lee
Seems it's got a lot of people worried which wasn't the intention. Just to be clear it's only really a concern for cars above 350bhp IMO.
I'm looking into it as I'm hoping to put 2 bar through a GT30 on my engine
#133
im only planning on running up to 300 bhp..........but still.........
#134
http://www.lancerregister.com/showthread.php?t=333816
What is required is for somebody to just take the time out to develop something similar to this.
The difference with the EVO oil pump failures is not flex causing shattered pumps, but oil surge on right hand corners over 1G.
#135
Burton do a pace dry sump kit and it dosnt say anythink about it being FWD or RWD that i can see. If pace make a dry sump kit they should have made it to fit the car the zetec engine come from ie fwd cars i would have thought.
If i get the kit will my drive shaft clear it because it says the pump is under the inlet
lee
#136
Bulletin Board User
from speaking to ian howell , i can honestly say ive asked him this question many times and all the high powered rebuilds like sunny , p.johnson he said that the bearings where in near as perfect condition as when he fitted them , he said that if there that much flex in the crank then hes sure there would be more failures around.
cheers paul
cheers paul
#138
#139
Bulletin Board User
#140
YES I KNOW I CANT SPELL
my oil presure light goes out on cranking quicker than the battery light
#141
like creator says Ł50,000 is alot of money and no tuner is going to spend all that money unless there building i would say 3 big bhp engines a month and the last time i checked with ian hes lucky if he gets 3 a year.
anyway back to the question about is there a dry sump for fwd cars
i dont know is the answer as its all about how close your crank pulley is to the chassis leg . i have a friend who is fitting one to a focus , s2 ecort rs turbo so they maybe can shed on light on this for us
as for the mk3 fiesta then no as theres simply no room to get the oil pump pulley to fit onto the crank pulley as theres no room that why luca had to cut his sump up reweld the bottom section and mount the pump in a different position , i would think that this is the same with the pace dry sump kit . so like i said the next option would be to buy either kit and custom mount the pump next to the head and drive it off the cam pulleys, that way you would not have to cut the sump pan up but you would have to spend a little more on pipe runs.
because i brought another pump i had to make a custom bracket on which to mount the pump but iam going 4x4 so no room problems for me , but making one bracket is not rocket science and getting mk motorsport to make it is easy enough.
i think it can be done for Ł1500 max if you not using posh anodised fitting etc
Ł850 sump kit
Ł50 bracket
Ł200/300
Ł300 pipes and fittings (no goodridge)
cheers paul
cheers paul
the titan kit
Ł850 sump kit
Ł50 bracket
Ł200/300
cheers paul
cheers paul
the titan kit
#143
Lukesville
Ł850 sump kit
Ł50 bracket
Ł200/300
cheers paul
cheers paul
the titan kit
Ł850 sump kit
Ł50 bracket
Ł200/300
cheers paul
cheers paul
the titan kit
Its difficult to design a kit for FWD becuase every car is different although the engine and pump may be the same.
My car we even had to cut out the chassis rail and box it in to clear the bottom pulley for the dry sump pump. If it wasnt for an alternator on mine then it would have made it so very much simpler.
Due to that though, the sump pan was cut and a plate mounted underneath for the pump to run off. The underside is slightly vunerable now though, so this needs sealing/protecting from debris.
#144
thats the main problem luca youve hit the nail on the head every application is different .
cheers paul
cheers paul
#145
#147
#150
im looking at bulding an engine for my project car
problem is im fitting itb's and was wanting to raise the rpm limt to around 7500-7600.
i was gonna change all seals,piston rings,timing belt,tensoners etc
but was looking at upgrading a few things to help achive the rpm i want
such as
apr main+con rod bolts,fit my tage 2 crawler cams,and adjustable cam pullys
if i did that and fitted a harmonic crank pull do you rekon this would prevent the oil pump shatering?
any other items u would sugest fitting to it aswell?
such as
#151
Lukesville
Fit an oil pressure switch too that comes on at 20psi, will blink when on idle once hot though but will give you good warning if somethings not right when on it!
I have this fitted on mine now and wired up to a blinding bright red led bulb.
If that lights up I know to shut down ASAP.
#152
thanks
#153
Im sure, on a blacktop (atleast mine sat in my shed) the alternator is at the top back of the engine beside the inlet mani.
I think a dry sump pump could be mounted where the aircon pump would usually sit, similar to the location on the evo kit I posted about above which is why I suggested it in the first place.
Im not saying go out and spend 50k developing a kit like ND, but surely the design is not too far off regarding pump and sump
#154
#155
such as
such as
Basically don't worry about pump failures unless you're going past 350bhp AND 7,200rpm.
#156
#159
Lukesville
It may help!..
I know 3 others with shattered pumps and all they did was fit new pump and shells.
I had to fit..
Block
Pistons
Rods
Crank
I am pretty sure if I was aware of the oil pressure issue, I would have shut down sooner
I was about 7000rpm in 6th gear at the time when I noticed the standard oil pressure light on.
#160
Bulletin Board User
Ouch!
Humans can't react fast enough to a warning light when you're talking in terms of thousands of RPM. What's needed is an ignition cut driven by a low pressure switch.
