Help needed!
Old Nov 19, 2010 | 06:17 PM
stimberlake's Avatar
stimberlake
Default Help needed!
I brought a connect tddi on a 2004 plate with a blow engine i have got the right engine and all has been fitted but i have proberlems with the starter motor! When i turn it over the starter motor just makes a clicking noise and doesnt spin i have tryied buying a second hand one and that does the same! Any ideas? thanks
Old Nov 19, 2010 | 06:20 PM
liam-rst's Avatar
liam-rst
shit happens
sounds more like a bad earth or somethin
Old Nov 19, 2010 | 06:22 PM
RichieST's Avatar
RichieST
flat battery?
Old Nov 19, 2010 | 06:24 PM
stimberlake
I have two batterys and both are good!
Old Nov 19, 2010 | 06:39 PM
liam-rst's Avatar
liam-rst
shit happens
another thought, nothin to do with the immobiliser?
Old Nov 19, 2010 | 06:50 PM
stimberlake
If it was the immobiliser i think the starter would still tick over?
Old Nov 19, 2010 | 07:00 PM
BigChuck's Avatar
BigChuck
pull the starter out and test it with a battery and a set of jump leads.
also does the engine turn over by hand ok?
Old Nov 19, 2010 | 07:18 PM
stimberlake
Il try the motor powered by a battery! if it works what do u think it will be ?
Old Nov 19, 2010 | 07:25 PM
BigChuck's Avatar
BigChuck
i could be a few things, but testing the motor eliminates one thing at least.
it could be a miss match between the teeth on the starter and the teeth on the ring gear.
Old Nov 19, 2010 | 07:26 PM
vaughant's Avatar
vaughant
Did you swap all the ancillaries?I've had this before with that very engine,a totally seized alternator causing the v belt to jam up.it could be something easy like that,I cut the belt and it fired instantly but changing the alternator was a pig of a job,didn't help mine had aircon!!!
Iirc there is a pulley system between the alternator and the belts and pulleys which is held on the coupling with three bolts meaning you could just undo them and try it?
Old Nov 19, 2010 | 07:28 PM
vaughant's Avatar
vaughant
Iirc fella,the starter won't slot in and bolt up unless the teeth mesh?
Old Nov 19, 2010 | 07:30 PM
vaughant's Avatar
vaughant
Oh while I remember,we had a fiesta in once where it wouldn't start without the clutch depressed,although im assuming you've tried that already?
Old Nov 19, 2010 | 07:31 PM
stimberlake
Yes all got swaped over! But i dont think theres a prob with the alternator its the starter im having proberlems with?
Old Nov 19, 2010 | 07:41 PM
vaughant's Avatar
vaughant
Only reason i mentioned it is cos my one did the same thing as that but it acted like the engine was seized,I shit myself!!I cut the belt as the engine wouldn't turn at all even with a powerbar on the pulley.I took a guess on the belt but it was right and I've actually had this now on about 4 cars we had in the workshop and it was always something on the v belt drive.
Old Nov 19, 2010 | 09:28 PM
RichieST's Avatar
RichieST
Good idea i didn't think of that. An old engine I bought had obviously been whacked on the alternator which caused it to sieze. Check the engine rotates by hand....
Old Nov 19, 2010 | 11:57 PM
BigChuck's Avatar
BigChuck
i dont know about this application in particular, but the teeth dont normally mesh up until they try to turn it over normally, so the starter would bolt up ok. its only when the solenoid activates the gear on the starter moves into position
to the OP, does the engine turn over by hand as i asked earlier?
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
