PF plumbers - HELP PLEASE !!!!!!!!!!!
Old Nov 13, 2010 | 09:03 AM
steves24V's's Avatar
steves24V's
Default PF plumbers - HELP PLEASE !!!!!!!!!!!
Right i have no cold water in my bathroom after draining the tank in the loft and replacing the toilet and removing and refitting the shower.|The tank is now full again and i have water out of the hot tapes so the hot water tank must be full too, but nothing what so ever out of the cold.
Old Nov 13, 2010 | 09:15 AM
cabriolet's Avatar
cabriolet
airlock fella i have to join the hot and cold with a piece of hose pipe on the bathroom sink to move it in my house
Old Nov 13, 2010 | 09:28 AM
steves24V's
I thought air lock but i really thought that with a full tank of water pushing down on it, it would clear plus the valve on the toilet was open from when we started filling the tank so thought it would bleed though as thats the furthest point from the tank.
Any way bit of hose between both tapes on the sink and open the cold tape and then turn the hot on to push water up the cold YEAH ????
Ade500's Avatar
Ade500
Fixing Fords
Or use an aquavac to suck it out.
Old Nov 13, 2010 | 09:32 AM
barnard's Avatar
barnard
Put the main onto the cold feed with a ballfix valve then its there for the next time you have an air lock
Old Nov 13, 2010 | 11:55 AM
steves24V's
Right done the hose between the pipes thing and now it's coming out the cold on the sink but slowly, nothing on the toilet tho ????
Old Nov 13, 2010 | 12:00 PM
focusv8's Avatar
focusv8
Have you turned on ALL the valves you shut off when you drained the tank?
The tank will typically have 2 outlets at low level, normally both with valves on, one for the cold to taps one for cold to the hot water cylinder.
Alternately the cold could be mains fed and not from the tank, have you turned off another stop tap other than the feed to the tank?
Old Nov 13, 2010 | 12:16 PM
St3V3_C's Avatar
St3V3_C
Do it some more!
Old Nov 13, 2010 | 12:24 PM
steves24V's
Focusv8
Your right there are 2 valves at the bottom, but only one would turn, that's why I had to drain the tank, my first thought was that the valve I turned off had got stuck but it not because that is the one that feeds the hot water cylinder I've followed the pipes down, also bathroom is not mains as we had no water in the bathroom once the tank was empty but still had water in the kitchen sink ( cold only )
st3v3 c
Have done it some more now, got half the toilet system filled up now stop and it was very slow when it was going.
Old Nov 13, 2010 | 12:28 PM
focusv8's Avatar
focusv8
The ball valve on the toilet may have crap behind it washed out of the tank when it filled up.
Depending on the cold tap type that may be full of crap as well.
Strip the ball valve first.
Old Nov 13, 2010 | 12:29 PM
St3V3_C's Avatar
St3V3_C
so the water you are forcing in is filling up the cistern?
Keep going until its full, and then a bit more.
Old Nov 13, 2010 | 12:33 PM
focusv8's Avatar
focusv8
Did the stuck valve move at all when you tried to shut it off.?
It maybe the gate in that valve has dropped and closed off the pipe
If the valves are in a horizontal run from the tank bottom can you reach in and poke something down the pipe to see if you can get past where the valves are?
Old Nov 14, 2010 | 11:18 AM
Ade500's Avatar
Ade500
Fixing Fords
Mate put an aqua vac on it 30 seconds done.
Old Nov 14, 2010 | 12:37 PM
rsfido_1989's Avatar
rsfido_1989
vac it... if that dont work maby gate valve has snapped nearly shut.
Old Nov 14, 2010 | 09:02 PM
steves24V's
Dont think it turned at all, and have gone back to it since to check and it def dont move, the valves are horizontal so thats going to be my next job to get something done the pipe think i need to go swimming in the tank.
Old Nov 14, 2010 | 09:05 PM
steves24V's
Dont think i can get my hands on a aquavac I really can't think how you can get an air lock like that but i'm no plumber.
Old Nov 14, 2010 | 09:28 PM
CHRISP's Avatar
CHRISP
mate can i start again, have i read this correct
you've isolated your cold water and changed your wc ?
when you've tried to turn on your cold water, its not filling the wc or any water from the taps ?
you have water coming thru' your hot taps but no cold water ?
can i ask you some.
what valves did you turn off and where were they ?
is your cold supply to the wc and taps mains fed or tank fed
dovboy
23
Jun 20, 2008 09:59 PM
Christian and Beccy
13
May 6, 2006 09:50 PM
Fiecos Dan
May 1, 2006 08:25 PM
