mazda tuners
Any one know of good mazda tuners?, mainly the later mazda speficaly the mazda 6 mps transmission, need to find out how good it is in standard form
The transmission is electronic controlled not plated lsd or atb front middle or rear this limits upgrading somewhat the 2.3 turbo has very wide torque band 380nm pretty much everywhere and its not uncommon to snap rear drive shafts at standard power.
The electronic centre diff is will only allow 50% torque to rear any more or overheating it goes to fully open. There is a diff locker but you can only use it upto 5mph otherwise the whole system crashes and kills clutches. The whole thing is linked via ecu and transmission ecu you would need Prodrives DCCD electronics or similar to reprogram everything together you cannot simply fit lsd centre diff front or rear and assume it will work well, far as i know nobody has improved or transplanted the transmission system successfully.
