Mondeo Diesel problem starting
Right My MK3 mondeo ghia x 2.0 tddi wont start... yesterday I broke down found out that the fuel wasnt getting to the engine, anyway found out where the problem was..1 tiny rubber seal had split in half from the main fuel supply line, just as it comes out of the top of the fuel tank so replaced it today.. charged the battery/now battery's half dead now but will it feck start fuel's now getting through and around the engine..so anyone got any ideas cause it's bugging the hell outta me... AL
you need to get a vac pump and pull the fuel through the entire system by disconnecting the return pipe after it comes out of the fuel filter and then using a pump in the pipe.
Or maybe try a tow start, used to work in the old days
well fuels deffinately coming out of each injector..i cracked each one free just to check too see if the fuel was actually getting where it was supposed to... only problem batterys nearly dead...anyway got someone coming to give me a jump start... as for towing not a chance..as the person coming is a woman...and she aint towed before plus i aint got the towing eye or a rope lmao..so will see if it will start once she's here with her car...fingers crossed twat better start..
right just been outside with a jump start got the car running for about 30seconds.. then it cut out..so cracked off each of the injector nuts made sure diesel was coming out tightend them up again..turned the car over it ran again for about the same time then cut out again.. so I think it still has an air block in the pipes...so will try again tomorrow.. after Ive checked for any air leaks..and hopefully get it running..
Do not try and tow it mate you will jump the chain. just fill the fuel filter up and once it starts keep some rev's on. the fuel pump cannot pull fuel up from the tank if the system has draned or you run out of fuel. you mite need to fill the filter up a cupple of times until the fuel pump fills up and pressures the rail. if it dosnt start after that then you have another problem.
the only problem Ive had is the fuel guage reading on the computer..ie what miles is left...keeps saying there's less than what I know I've put in ie Ł20 fuel and after i stopped the car then started it up again, the reading was showing nearly empty until it showed no fuel at all... but it was running fine no problems at all...until monday..when it broke down..
even the recovery bloke said it's a fuel problem..
Well if anyone's intrested found the main problem...fucked fuel pump so just waiting for a lift to go and get a replacement..then finally get it sorted... mind you rather be working on a RS than a derv..but daily runner needs sorting..
