Builders?
Old May 17, 2010 | 07:04 PM
It's Czech Mate's Avatar
It's Czech Mate
Default Builders?
I have two water pipes I need to re route, would i be ok to drill two 16mm holes through an rsj ( provided I can ) or should I take some advice. I cant see it being a problem really?
Old May 17, 2010 | 07:13 PM
rscombi.'s Avatar
rscombi.
er , surely theres an easier way?
Old May 17, 2010 | 07:15 PM
Shings's Avatar
Shings
Yep...
Surely?
Up and over and through the joists and down the other side.
You'd prob want slightly larger than 16mm holes too....
Old May 17, 2010 | 07:36 PM
It's Czech Mate
Definitely no other way without smashing a LOT of wall out
Old May 17, 2010 | 08:20 PM
morcheen's Avatar
morcheen
no problem going through th rsj,done it on the job i'm on now.
Old May 17, 2010 | 08:22 PM
cjwood555's Avatar
cjwood555
Depends what the rsj is doing - if you want to drill the holes directly beneath a big point load then perhaps think twice. If it's just holding the upstairs floor up then I wouldn't worry so much!
Old May 17, 2010 | 08:37 PM
It's Czech Mate
Just the floor, no great load.
So any special type of drill/bit, or do a guide hole and use a hole cutter?
Why does what seems like the simplest thing turn into such a monster
Old May 17, 2010 | 09:04 PM
Jay246's Avatar
Jay246
Just use hss drill bits mate... i drilled sixteen 18mm holes in an rsj on saturday.. start with a 5mm pilot, moved upto 10mm, then 12mm, then 14mm, then 16mm, then 18mm... Lots of increments but blasted through it in no time...
Old May 17, 2010 | 09:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it's the distance between the flats of the rsj that give it it's resistance to bending, rather than the strength of the vertical bit.
Old May 17, 2010 | 09:28 PM
It's Czech Mate
Yeah I didnt think it would be a problem, I was just asking the pf massive in case I missed anything obvious, it's been done before
Cheers Chaps. I love this place, the way anyone can ask anything, and bar the idiots theres always a few peeps to offer sensible answers
Old May 17, 2010 | 09:51 PM
TIFF's Avatar
TIFF
Chasing Radders
Yer no probs.....i do it all the time..
Old May 17, 2010 | 09:59 PM
Lee Reynolds's Avatar
Lee Reynolds
Just to concur, yes no problem. Its no different to having to have them drilled when bolting two together when building a cavity wall above
Old May 17, 2010 | 10:01 PM
It's Czech Mate
ricky
22
Apr 26, 2006 07:17 PM
bigwelshlad
32
Apr 5, 2006 07:20 PM
PAULDOLMAN
Mar 14, 2006 12:02 PM
220TC
Mar 23, 2005 07:12 PM
RS2000CUSTOM
Mar 21, 2005 08:30 PM
