wiring the fan to run constant !!!
Old 25-04-2010, 08:27 AM
jamieclements
jamieclements's Avatar
Default wiring the fan to run constant !!!
hey guys , i want to wire my fan so it runs constant as soon as you turn on the ignition , but what is the best way to tackle this ???
Old 25-04-2010, 08:31 AM
j6kyt
j6kyt's Avatar
why not put a switch inside the car and use it when necessary. Take the fan swith wires off the sensor and join them to a manual switch inside the car.
Old 25-04-2010, 08:33 AM
S1 Combi
S1 Combi's Avatar
Do you have a problem with over heating then?
Old 25-04-2010, 08:34 AM
RS500/364
RS500/364's Avatar
Run a relay from after the ing with the switch to turn on before this
Or you will forget and drain the battery
Rick
Rick's Avatar
Very Bad idea, but simply bridge the connections that go onto the switch with thick wire.
Old 25-04-2010, 08:39 AM
S1 Combi
S1 Combi's Avatar
Can do the same thing with a 20/30 amp fuse,did it on mine for a while,anything goes wrong fuse blows
Old 25-04-2010, 08:41 AM
S1
S1's Avatar
Why?
Old 25-04-2010, 08:44 AM
rich123
rich123's Avatar
i would put it on a switch with a relay easy to do take you 10 mins or you could have problems drove mine back from telfod not so long ago got all the way back thought ill put me fans on to cool the engine about 5 mins from my house,pulled in to my village and loads of smoke in the car had a look and it had melted my wiring under the dash and that was double 20amp wire
Old 25-04-2010, 08:47 AM
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
if the switch is wired up as it should be there will be no problems. you dont need to wire up a relay as the car all ready has one!! wire the switch up to "bridge the gap" of the fan switch on the side of the stat housing.
but more to the point why on earth do you want to put your fan on a switch??
Old 25-04-2010, 08:50 AM
rich123
rich123's Avatar
not on mine i was running a 2.9 they have a viscous fan i did away with that and run twin fans now
Old 25-04-2010, 08:51 AM
rich123
rich123's Avatar
plus there is not realy any standerd wiring in the motor anymore
Old 25-04-2010, 08:55 AM
clarke5700
clarke5700's Avatar
i see. i was under the impression we was talking about this guys mk3 escort so would have had fan wiring as standard. as for wiring up fans with no relays thats asking for a fire lol
Old 25-04-2010, 09:01 AM
rich123
rich123's Avatar
yep lol i found that out luckly it was'nt too bad most of the smoke came from the foam crap under the dash
Old 25-04-2010, 09:38 AM
jamieclements
thanks for the replys guys , looks like ive hit a raw nerve with that idea lol , its just that im fed up with it keep getting hot in traffic
Old 25-04-2010, 09:40 AM
jamieclements
not when im driving , just in heavy traffic bloody thing
Old 25-04-2010, 09:45 AM
retro d
retro d's Avatar
Simple switch in the cab mate, run it from you temp switch on radiator etc. but I would fuse it tbh.
Ive just done it on my car as it gets hot in traffic situations.
Old 25-04-2010, 02:54 PM
RichieST
RichieST's Avatar
I'd say you've got more problems then. Does the fan cut in and out as normal? If it does, and its still overheating then i'd say something else is fucked, i.e. waterpump or blocked rad or something.
Old 25-04-2010, 09:04 PM
SS1
SS1's Avatar
Buy some water wetter then
Old 25-04-2010, 09:39 PM
Coldo
Coldo's Avatar
I had my fan on a switch in my old S2 and tbh, it was the best mod on the car!
In traffic on a warm day the temp would naturally creep up, fan switch was a godsend a few times.
Old 25-04-2010, 09:45 PM
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
As Rich suggested, it would be worth sorting the rest of your cooling system before wiring the fan to run permanently. Give it a good flush, change the thermostat and put good quality coolant in it.
If you do want more control over your fan, have it switched and use an illuminating switch - as, if you're anything like me you will at some point forget to turn it on/off!
Old 25-04-2010, 09:54 PM
Rsmat
300+
PassionFord Gold Member (Male)
Rsmat's Avatar
+1
Old 26-04-2010, 09:03 AM
charlie luciano
charlie luciano's Avatar
Its not a good idea to run the fans constantly because
1: they were not designed to do that
2: eventually the fans will burn themselves out
3: the wiring will get hot and melt
4: the fans use power from the engine whilst running
if you are having overheating problems find the root cause and sort it out its better in the long run than doing the quick fix (bodge)
Luciano
Old 26-04-2010, 11:04 AM
jamieclements
no my fan doesnt even work
Old 26-04-2010, 11:18 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
There's your problem then.
Seriously, my RST never used to overheat. Fix it properly.
New STANDARD rad
82° Thermostat
Fresh Coolant
Fix the fan.
Job done.
Old 26-04-2010, 11:19 AM
Christian and Beccy
#1 in Spelling Club
^^^If it hasn't already done the head gasket that is^^^
Old 26-04-2010, 02:02 PM
S1
S1's Avatar
LMAO! No wonder it overheats then!
I have a fan switch on mine with 3 positions, one so it comes on with the thermostat, one so it stays on constant and one with it off altogether. It's so I can run the fan prior to a sprint run, then switch it off altogether for the run.
YODI
30-08-2015 01:12 PM
kosienutter
31
22-08-2015 09:55 AM
Zoggon
10-08-2015 10:39 AM
yawiejon
15
09-08-2015 06:36 PM
Quick Reply: wiring the fan to run constant !!!
