Any hints/ tips
Old Jan 3, 2010 | 03:16 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default Any hints/ tips
Just been out to fill the sapph up and I cant open the fuel cap its stuck solid key twisted(metal shaft bit) so any tips before I drill the lock out
the annoying thing is the lock/ cap is only about 1year old
Old Jan 3, 2010 | 03:19 PM
rstdave's Avatar
rstdave
You sprayed any wd40 down the hole? The cap on my rst goes solid when i've left the car for a while, couple of times i've had to spray loads down the keyhole and use pliers on the keyshaft to open it.
Old Jan 3, 2010 | 05:49 PM
dojj's Avatar
dojj
Resident Wrestling Legend
yup, some of the old dw40 into the lock
and seeing as it's flamable, it's not going to do much harm if it mixes with the petrol either
winner both ways
Old Jan 3, 2010 | 05:53 PM
steviecossie's Avatar
steviecossie
as said wd40 and loads of it
Old Jan 3, 2010 | 06:06 PM
mechanic28's Avatar
mechanic28
and leave it for a day to work its magic
Old Jan 3, 2010 | 06:15 PM
thebigyin's Avatar
thebigyin
wd 40 then grease on the key, work it in to the lock then twist the key left to right , might take a few mins but works everytime.
Old Jan 3, 2010 | 06:38 PM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
I can sympathise with this.... mine does it every now and again. You learn to recognise the symptoms and get the WD40 in before it happens again...
Old Jan 3, 2010 | 06:46 PM
cossiejsy's Avatar
cossiejsy
what a nightmare matt it happened to me last year in the end i got a new cap and barrel and key
Old Jan 3, 2010 | 06:49 PM
KSA-Cossie's Avatar
KSA-Cossie
As above matt,thank fook mines 4x4.
Old Jan 3, 2010 | 07:01 PM
yeh thank fook mine is too. If our flaps ever stick there is always that little bit of rope to pull inside the boot. Matt i hope you sorted it.
Old Jan 3, 2010 | 07:38 PM
dug112y's Avatar
dug112y
passionford pro
try using your spare key too as the keys wear mate plus as above wd40
Old Jan 3, 2010 | 09:04 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Ham-fist-ed bald twat lol
Steve
Old Jan 3, 2010 | 09:17 PM
dojj's Avatar
dojj
what you need to do is fit a later filler cap, with the internal relaese and the boot pull as well
you can then use the internal filler realease if the cable don't work, or you can just fit it and not put the cable in so you can only get to the filler via the boot
tankybaby66
Feb 6, 2016 02:24 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
jonnyenglish
Sep 21, 2015 07:31 AM
Si B
Sep 12, 2015 06:49 AM
